Question about Refrigerators
Kelvinator no frost 480 Hi Mum's fridge is not cooling freezer is fine she has had it for over 30 years and is broken hearted to part with it can you help
SOURCE: Jenn-Air JFC2089HES (French Door) Fridge not cooling enough
Hey Northrock,
Did you ever get your fridge fixed? I have the exact same fridge and the exact same problem.
Posted on Dec 10, 2007
SOURCE: kelvinator 380 fridge
called the experts....all fixed.
problem- flty sensor terminator
Posted on Sep 05, 2008
tech master
  • 120 Answers
SOURCE: kenmore fridge model#596.52679200 side by side
remove back cover on evaporator inside frezeer if is full of ice all over then you have a defrost problem and you might have a faulty defrost timer or defrost thermostat repl both so you wont go wrong if the coils are clean and not frost is on coils then check compressor to see if its running just by touching you can find out if it si not running then you have a faulty relay or overload repl and compressor should start.if there is only partial frost then you have a leak or restriction depending when you bought it most refrigerators have a maufactures warranty on compressor for about 5 years call for service on the number on the sticker inside refirgerator
Posted on Oct 14, 2008
  • 212 Answers
SOURCE: Amana energy saver not keeping fridge section cool enough. HELP!
if there is frost build up on rear wall of freezer section the unit is not going through defrost cycle which builds up frost on evaporator and restricts cold air flow to the fresh food section. one of three things are bad. defrost heater, defrost thermostat or defrost timer. if no frost on rear wall you might be low of freon.
Posted on Jun 24, 2009
mgprice
  • 744 Answers
SOURCE: The frdge side stopped cooling. the freezer side is fine - help!
Hi, With the information you supplied i'm going to assume there is an ice build up at the rear of the freezer. Your problem is going to be with your defrost system. I will also assume you have the ability to repair this yourself. This is going to be one of three problems with your refridgerator, 1st thing to do is remove shelfs and panel in the back of the freezer...you should see ice build up on the evaporator...don't worry get a hair dryer and melt the ice. Next locate the wires for the heater...using a multi meter test the heater for condinuity...if the heater is bad replace it, If the heater is good replace the defrost thermostat..the stat normally is a barrel looking part clipped onto the evaporator pipe. The last possible problem could be the evaporator fan, have you heard the fan running in the past few hours?..if you are not sure pull the panel out to where you can see fan and watch it over an hour to see if it turns. I have included links with pictures of what the parts you need to check are: http://romulusappliance.com/manufacturers/maytag/refrigerators/575432.JPG defrost stat http://www.hotekalliance.com/UploadFiles/2008627111553382.jpg heaters http://www.applianceblog.com/archives/EvapMotor1018185.jpg evap fan. Hope this helps. If you have any other questions please feel free to comment again. If you decide to get a repair guy in should not cost you any more then $120 - $200 depending on make/model/problem Good luck & thanks for using fixya! Mike p.s. please don't forget to rate this free solution.
Posted on Aug 18, 2009
Kelvinator no frost KBNT23AS back plate in the freezing compartment is icing up but the ice trays are not freezing. The lower compartment is not getting cool enough.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Apr 05, 2011 | Frigidaire Freezers
Kelvinator fridge freezer, fridge too cold frosting at back
Fridges that are less then 10 years old have a lot of POWER. To get rid of the frost, wait until you have eaten most of the food up (maybe a few days), then unplug the fridge and leave the doors open. This will take care of the frost after several hours.
From then on, make sure that when your fridge is full, use a higher setting, and when it is near empty or half way full, use a lower setting. Keeping the freezer at a mid to low setting all the time should be fine, because its usually the fridge part that gives people trouble.You will have to judge on your own which setting is best (i.e you can tell when its good based on how cold the juice is in there, etc).
By adjusting the setting based on the amount of food in your fridge, it should prevent frosting.
Hope that helps!
Mar 28, 2011 | Kelvinator KBM5100MB
I have a Kelvinator Opal Fridge/Freezer. The freezer is working fine but the food compartment wont cool. It used to run too cool and freeze stuff on the top shelf. The fridge seals are fine, the fan runs...
The vent from the freezer to the fridge can be blocked with frost and is preventing the flow of cool air to the fridge.
This can happen if there is frost build up due to failure of the auto defrost timer.
So please check on the fan section , remove panel and see if there is frost or block, if so check the timer Heater and the thermostat.
Jan 24, 2011 | Refrigerators
I have an old (35 years) Kelvinator No Frost 480 which seems to be functioning, but not cooling the bottom half of the fridge as it should. The cooling elements seem to freezing up. The fan and compressor...
gfhgfhgfh
fghf
Sorry to hear about your problem.
Sounds like you have a defrost issue. Hence your unit is not defrosting. All of this apply's if your freezer side has ice on it. If not. you have other issues, this does sound funny, but this is why your refrigerator side is warm, or not cooling.
Here is a list of some things that can go wrong.
1. Defective heat coil
2. Defective defrost timer
3. Defective defrost sensor
4. Defective Fan
5. Defective compartment inlet damper (on some models)
You should call a service company to resolve your issue.
Since I tried to help you, Please help me and Rate/Vote on the response. Thanks
Jan 02, 2011 | Kelvinator Refrigerators
Jun 24, 2009 | Amana ABB1927DE Bottom Freezer...
Kelvinator 380 fridge
Sep 04, 2008 | Refrigerators
Have a 17 year old Kelvinator N640T side by side no frost fridge freezer. Runs well except ice builds up on the bottom of the freezer compartment and when it builds up too much some melts spilling water...
You problem lies in a blocked drain or a broken drain connection to the metal drip tray at the bottom of the freezer heat exchanger. You could try blowing the drain out from beneath the fridge, which is difficult as it is very hard to access. Alternatively you will need to remove the tray. This means you have to remove the contents of the freezer, remove the lower long white metal cover and blow out the drain. Then test the drain with a cup of water. If it leaks into the bottom of the freezer compartment you will have to remove the drain and epoxy the joint together again.
Not a job for the faint hearted!
JB
Apr 07, 2008 | Refrigerators
Refrigerators Logo
26 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
