Question about GNC On-The-Go Blender - Black
Does not run - GNC On-The-Go Blender - Black
Motor runs Blending spindle not moving
probably stripped the blender drive off the motor shaft
if it is still under warranty ,take it back
if not , with all the failing units you may get parts from the manufacturer
Jan 20, 2016 | NINJA BL770 Blender & Food Processor, Mega...
Why is my pressure cooker not running the length of time set?
You probably need to push set again or something when it appears you should be done. I have a slow cooker and they work that way. It appears to be running but you still need to push one more button or the program will stop after 15 minutes.
Sep 21, 2014 | Cuisinart CPC-600 6 Quart Electric...
When turning my Vitamix product on high it runs for about 45 seconds and then it shuts off. I then have to wait another 15 to 20 minutes before I can reuse the product.
It sounds like the motor is overheating, how long will it run with no beaker on it? If still 45 seconds I'd say new motor time. If it runs for 5 or 10 minutes then I would say replace the blade and bearing assembly in the beaker.
Aug 27, 2013 | Vitamix Blenders
Blender seems to run right until you put glass jar on.runs very slow.
Disassemble the base from the jar, and check the placement of the gasket. Reassembly, with the jar upside down is gasket, blades, then base. While disassembled, rotate the blades by hand just to make sure that they aren't in a bind. Replace if defective.
--W/D--
Mar 06, 2011 | Hamilton Beach 50754 WaveStation 10 Speed...
I was grinding rice......after that fumes came out and its not working now
The motor has burnt up... you will need to replace the blender.
There is an old saying that motors run on smoke...once the smoke comes out of the motor the motor will no longer run... :-)
heatman101
Sep 27, 2010 | Black & Decker BL9000 Blender
Waring blender motor makes a noise, and a burning smell when running.
The motor is "burning out" It is not economically feasible to repair it. It will soon stop completely and could possibly overheat the cord or base of the machine. I would recommend throwing it away. If you want to use it until the last second, always unplug it when not is use and do not leave it unattended while running. I wish I could give you more hope than that, but there is no way to repair it.
Sep 11, 2010 | Blenders
I am unable to get the blending cup out of my Bella Cucina Rocket blender. I recently purchased this have and only used this a few times including once just before the ''cup'' stuck. It appears to have...
Hi! I just had the same problem and actually called the service number that came with the rocket blender. The lady on the phone said that the plastic cup must have expanded (from heat), and to stick it in the refrigerator for 24 hours until the plastic shrinks back down to normal. After the 24 hours the cup should be able to come off. Kind of makes sense, but I hope it works!
May 11, 2010 | Bella Cucina 13330 Rocket Blender
Motor sounds like its running, but the blades
It sounds like a gear might of broken either under the blender jug or in the unit itself. Best bet is seek out an appliance repair shop locally.
Feb 02, 2010 | Krups KB720 5 Speed Blender
WHEN i PUSH ANY BUTTON TO TURN IT ON, IT WORKS FOR A FEW SECONDS THEN IT STOPS, i HAVE TO UNPLUG IT AND SHAKE IT, IT WORKS FOR ANOTHER FEW SECONDS THEN IT STOPS AGAIN. wHAT CAN i DO TO FIX IT?
Sounds like the brushes are not making good contact or you have a defective switch. Run the blender witout the container or blades . Free run it for 5 minutes id you can and see if that helps.
Oct 20, 2009 | Krups 574 Power Xtreme VI Premium Work Top...
KitchenAid 5 speed blender
Are you saying there's something wrong with the blender and it runs on high when it should be running on stir?
Aug 28, 2006 | KitchenAid KSB5 Ultra Power Work Top...
GNC On-The-Go Blender - Black Logo
49 people viewed this question
Top GNC Blenders Experts
eyecam
Ross Keen
Are you a GNC Blender Expert? Answer questions, earn points and help others
