Question about Roper Dryers
The drum started making a terrible racket and then it sounded like something hit the floor. Now the drum won't spin. what's wrong and can I fix it myself?
    Master:
  • 410 Answers
Need to check to see if belt is still around dryer drum. also check to see if the moter that turns the belt still works.to do this you have to take the dryer shell off.
Posted on Oct 10, 2013
Illeagle
  • 525 Answers
SOURCE: Sounds like I have a cat stuck in the dryer when
"Cat" noises in a dryer are usually related to a faulty set of drum support rollers or an idler pulley. You can visit www.repairclinic.com, for a complete parts list and disassembly diagrams if you are going to attempt a DIY repair. Always remove the dryer from its power source BEFORE attempting repairs.
Posted on Jul 05, 2009
  • 1218 Answers
SOURCE: Amana Gas Dryer LG3912W When dryer is turned on
Good day,
If your sure it is getting gas, then the problem is with the gas valve. There are 2 coils mounted on top of the gas valve and they are either shorted or open. In either case they need replace.
Simple job, just remove both wire connections, then the bracket is held on with one screw. Remove the bracket, and the coils will lift right off. Very common problem.
P.S. When purchasing the dual coil kit, if the Amana seems pricey, check with the counterman and ask for the Whirlpool kit. It's identical except for the part number.
The rollers are an obvious solution. You'll have to inspect them first. The belt tensioner is another item, and in rare cases the blower wheel attached to the motor.
Posted on Dec 16, 2009
  • 401 Answers
SOURCE: Dryer is making a terrible racket, but drys perfectly.
It depends on the noise. It could be a drum roller going bad, the idler pulley, or even something caught in the blower wheel. Can you describe the noise?
Posted on Jan 02, 2010
Testimonial: "I found the expert's diagnosis very helpful. In my case I decided I better call a repairman since I cannot disassemble my gas dryer."
apart4u
  • 213 Answers
SOURCE: Bosch Axxis WTL5410 condensation dryer does not heat up
Common faults -
1 The heating elements can fail (meaning open circuit)
2 There are cut-outs (T.O.C's) that might need resetting
3 The thermostats (stats) can trip out or burn out (meaning opencircuit)
4 Moderntumble dryers also have sensors and pcb's (Printed circuitboards) thesehave programs that can fail and circuitry although most should produce an errorcode showing you were the fault is.
5 Faultyconnections and burned wires may also be the fault.
Free tumble dryer repair videos
We have a Free full video library on appliance repair video’s
Posted on Jan 13, 2010
heatman101
  • 43501 Answers
SOURCE: Dryer is making a banging noise? Sounds like
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Asker's Testimonial " This should give me an ida of what to look for once I open er up " -
Posted on Apr 18, 2010
Hotpoint wlm540 troubleshoot
Check bearings aren't worn,,,causing up & down movement on drum
Jun 14, 2013 | Washing Machines
My Whirlpool duet sport makes a terrible noise during spin cycle like drum hitting something or belt slipping. There are no error codes or smell of burning belt. HELP!!
the drum bearings are shot,you need to get them replaced,if the drum is actually hitting the sides if the tub this could be a broken spider thats on the rear of the inner drum that holds the drum on if this comes loose it can cause serious personal injury
May 29, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My dryer (maytag atlantis) has started making a loud clunking noise with each revolution. its still drying fine but sounds terrible. any thoughts?
A loose belt will allow the drum to slip when clothes hit the paddles in the drum. It sometimes sounds like a pair of tennis shoes are in the dryer when it slips and is usually rythymic.
These machines also use drum rollers that can make a racket when they go bad.
http://www.repairclinic.com/Maytag-Dryer-Parts
Good luck.
Mar 02, 2011 | Maytag Dryers
My Kenmore Elite He4t front load washer is making a terrible noise when it starts spinning the clothes. What could be wrong?
Sounds like the rear bearing. If you hear the noise when you manually spin the drum or if the drum has any movement when you lift up on it then you need major repairs
Feb 27, 2011 | Kenmore Elite 45986 Front Load Washer
I have an epic front loader by may tag... When it is on spin it soundS like there are a bunch of pieces flinging around inside making a horrible racket. It never used to do this. I have checked and there...
Hi from retired Englishman in SW France @ 21:20 Mon evening.
As your husband is a technician I would persuade him to have a look- it's the cheapest answer!
REMOVE POWER FIRST!!!
I just have lots of years experience of taking things apart and (hopefully) fixing them! It sounds as if something has got through between the drum and its container. It should be possible to actually listen with head almost inside the drum whilst at the same time rocking the drum. If there is something there it should make a noise at the bottom.
Question- have you had a look in the lint tray/filter to see if there is any sign of naughties getting into the drum? That's also worth a try.
Lastly I am assuming that the washer is absolutely stable- that all 4 feet are FIRMLY on the floor and the machine is not moving even the slightest(?).
Like my wife, you are lucky to have a (cheap) technician ;-0)
Good luck,
John C
Feb 07, 2011 | Washing Machines
Our dryer has a terrible squeak. We replaced the
The terrible squeak is probably the idler pulley shaft spalling in the idle pulley mount. When the idler pulley siezes to to pulley shaft it spins in the mount and makes a horrible racket.
It can be the motor bearings also but I doubt it at this time. With the belt off you can spin the motor and listen for any odd sound. If you hear nothing then the problem is definately the idler pulley assy.
It is normal for the drum to float in place. When there is a problem with the drum or drum felts, you usually hear a cyclic scrape or grinding sound that is concurrent with each rotation of the drum.
Thanks for using FixYa.
Kelly
Mar 05, 2010 | Frigidaire GLGT1031C Dryer
Washing machine - terrible noise during spin cycle
sounds like the drum is rubbing on some part of an exterior wall of your washer,.or you have a bearing going, or worst case scenario you have transmission problems and need to get a serviceman in to check your machine.But firstI would call the manfacturer and explain the problem they may be able to resolve it over the phone give them model no. Make and year of manfacture they hopefully can help you with this
Jan 07, 2010 | Hotpoint Ariston Aquarius WD420 Front Load...
Jan 01, 2010 | Dryers
Out of balance drum WM2277HW?
More than likely it did not get reinstalled right after the move. All four of the leveling legs must be firmly touching the floor. If one is even the thickness of a piece of paper off the floor it will start to rock during spin and the problem just amplifies itself. Make sure it's perfectly level and that all the feet are firmly on the floor.
Jul 28, 2008 | LG WM-2277HW Front Load Washer
Dryers Logo
62 people viewed this question
Top Roper Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Roper Dryer Expert? Answer questions, earn points and help others
