Question about Intel Celeron -D 2.26Ghz Computer System PC Desktop
My computer screen has a green tinge, how do i change it back to how its supposed to be?
  • 374 Answers
if still have the system windows you can put it back,click the all program,go to accesories,then click system tool,click restore system,on restore system select and click a previuos date that your windows run normally to put back your system.follow the instruction,this will restart your computer after you select date then it restore your windows just wait,until it tell you it was finished.
if still the same thing,try to switch off your computer,then open the cover of your computer .disconnect vga cable on video card loosen quick lock bolt,pull out video card try to clean by eraser head of pencil srcub on slotted multiple terminals then put it back
also include your memory card clean by eraser head also,put it back,disconnect ide cable of hardisk and put it back to refresh,closed computer cable.and switch it on.if still have the green thing install your windows installer and have it install the windows again.just follow the instruction.have a nice day.dont forget to rate me,thank's
Posted on Apr 23, 2009
Hi im having trouble with my laptop i get a green tinge to laptop screen, black in a photo or website shows up green, ive tried a new screen cabke n it didnt work, i tried a new laptop screen it didnt...
It's the graphic chip in the laptop. Sadly you have to change the mainboard, so my recommendations is just to get another computer, as the mainboard is expensive and the warranty is not good.
Mar 03, 2011 | Acer Aspire 5630 Notebook
Everything on the screen is in a blue tint. Applications work, but nearly unreadable due to the tint. I made no changes to any settings.
Check all connections to the monitor and try it on another computer. If the tinge is gone on another computer, check graphics card on your computer. If the tinge does not go, the screen is failinga nd will need repairing (but most likely replacing)
Jan 12, 2011 | Acer AL1914 19" LCD Monitor
Acer X193HQL LCD Monitor Colour Problem
Hello Sales, hi, try to reconnect the VGA cable from the PC, and wiggle it a little and see if the green tinge thing disappears on screen, if it does there are loose contacts, you can also try to replace you VGA cable, see if it solve the color problem.
Apr 27, 2010 | Acer AL1912 19" LCD Monitor
This monitor is great. Just recently, after 3
It seems so.
1. Change the monitor cable and see if this still happens
2. Attach this monitor to another PC and see if this still happens
If it is still happening, then yes, it seems that it is failing.
Mar 14, 2010 | Gateway FPD1760 17" LCD Monitor
I own a KP-57HW40 set that has a color and shut off issue. Started as a green tinge problem to the screen after watching for a few hours. Started becoming more and more frequent a couple months ago....
IF YOU HAVE A RA 6 CHASSI THE TUBES RUN HOT ANOID CATHOD SHORT IF YOU TAP ON THE NECK OF THE TUBES AND GOES TO SOLID COLOR THEN SHUTS OFF YOU HAVE TO REPLACE THAT TUBE ALL 3 TUBES WILL HAVE THIS PROBLEM
Feb 09, 2010 | Sony KP-57HW40 57" Rear Projection...
I am borrowing a friend's VA1703wb monitor. The screen has a definite green thing going on.. I see everything nicely, but with a green tinge to it. Killing my eyes after only 10 minutes. Used the four...
your screen or the screen you borrow is defective and the only way to repair is buy a new one or send the screen to the manufacture and if is killing your eyes you need to stop use it because can damage your vision and you dont what that ok thanks
Nov 11, 2009 | Computers & Internet
Acer Laptop TM240 , display has green tinge....
This is one of two things.
The first is that the color settings in the advanced section of your display properties has been altered.
The second and unfortunately the more likely is that your lcd screens back light or cfl (compact fluorescent lamp) has began to fail, usually due to age.
If this is the case you can either replace the entire lcd panel or just the cfl. Changing the lcd panel is fairly straight forward, but changing the cfl while it is the cheaper option it is a much more technical job to complete.
Jul 02, 2008 | Computers & Internet
Open Questions:
as some sites suggest about cheat for igi game i tried it and make changes under Project IGI- I'm going in Cheats----hi friends in this game it is difficult to get the blood/medipack to get this use the folowing instruction. 1)first go to the igi installed folder then go to weapon folder u will find some folders like Ak47,binoculars,colt anaconda,medipack etc. 2)then go to Ak47 folder you will find a folder like weapon the open in hex editor u will find a string like weapon_id_Ak47 by using hexeditor edit the string to weapon_id _medipack. then similarly go to medipack folder u will get a folder like weapon then open in hex editor edit weapon_id_medipack to weapon_id Ak47 the save it. 3)when u will kill a soldier u will get a medipack. for hex editing i installed HEXED30f.zip software and changes in hex file as i described above but due to mistake my igi game not start well aND , SHOW A error like igi stopped and shows problem detail Problem Event Name: APPCRASH Application Name: IGI.exe Application Version: 0.0.0.0 Application Timestamp: 3a1d74c6 Fault Module Name: StackHash_169c Fault Module Version: 0.0.0.0 Fault Module Timestamp: 00000000 Exception Code: c0000005 Exception Offset: 00000000 OS Version: 6.1.7600.2.0.0.256.1 Locale ID: 1033 Additional Information 1: 169c Additional Information 2: 169c69b50cca39ebafad90cf9acfe712 Additional Information 3: 166e Additional Information 4: 166ed9faa1184e606930c56f1ef84d85 please send solution ... or reply
Dec 31, 2010 | Intel Celeron -D 2.26Ghz Computer System...
Intel Celeron -D 2.26Ghz Computer System PC Desktop Logo
55 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
