Question about Philips CD535 Cordless Phone
I have a Philips CD535 Cordless Phone which does not ring. I can make outgoing calls and can get incoming calls if I pick up the phone when getting an incoming call. I have increased the volume of the ring, but I still get no sound. Any advice?
2 Suggested Answers
  • 7993 Answers
SOURCE: I have philips landline phones. My main phone does
Looks like the basic functions of the phone are correct. Remain the answering machine. Are you sure it can act as an answering machine?
If it can act as answering machine the reason it is not doing so may be the following.
  1. Answering function is turned OFF
  2. Answering function may be ON but the number of rings before it answers is set too high.
I suggest you try the following
Call you phone. Let it ring at least 10 times. If it can act as an answering machine it will pick up the phone and read the welcome message, because most answering machines (the recent ones at least) answer after 10 rings even if answering function is turned OFF.
The phones that can be answering machines usually do have a display that shows the number of incoming messages, or a LED that flashes to let you know that you have new recorded messages.
Posted on Jan 03, 2010
I have a Uniden cordless unit hooked in 4 lines. Incoming calls ring briefly for about 1 second and go out! You can talk if you pick up but not sure why no normal rings. There is no problem calling out....
When someone calls you and your phone behaves this way, does the caller get disconnected? The phone may be causing this, but it may also be due to trouble in the telephone line itself. The trouble is caused by defective wiring, a partial short circuit. When you pick up your phone to call out, the voltage on the phone line is low and it works normally. When you get an incoming call, a high voltage is sent to ring the phone. Because of the partial short, the phone company's equipment thinks you've answered the call as soon as the ringing starts. But you haven't picked up the phone, so the phone company's equipment thinks you've hung up and disconnects the call. The result is that short burst of ringing.
Disconnect the cordless phone base unit from the line and try another phone. If you still have the trouble this confirms the line is at fault. You'll need to contact your phone service provider for service. If it's in the outside wiring, they're responsible for repair. If the problem is in your home wiring, you may need to pay them unless you have a wiring maintenance plan.
If the problem goes away when the cordless base is disconnected, then it's time for a new phone.
Jul 16, 2011 | Uniden Cordless Phone
I can record an outgoing message. However, does not respond on an incoming call, therefore no messages are being left on my phone.
try to reduce the number of ring before the voice mail pick up. if it setup on 6, reduce it to 4 sound.
Jun 15, 2011 | Sony SPP A973 Cordless Phone
Panasonic cordless phone model kx tg3521 is keypad locked I can atten incomeing call but I can't do outgoing calls
panasonic cordless phone model kx tg3521 keypad locked .I can attend incoming calls but I can't do outgoing calls .its say dial is locked
Feb 25, 2010 | Panasonic Lands Phones
I have philips landline phones. My main phone does not ring or flash when an incoming call comes in. I t won't go onto answer phone either it just rings out. I can pick it up and answer the call. i can...
Jan 03, 2010 | Philips Lands Phones
Phone sees call, but can't pick-up. Can't get d-tone to call out?
Just a suggestion (without knowing what troubleshooting steps from your manual you may have taken): Remove the batteries from the back of the handset and then put them back in after a few moments. My Panasonic KX-TGA8231B (DECT6.0) phones were acting up just like your Uniden is. All functions returned after this power interrupt "reset" with the batteries was done. Hope that helps. Good luck. - - -Gerry
Nov 30, 2009 | Uniden TRU9485 Cordless Phone
Philips VOIP8411B/37 IP Phone - Cannot make outgoing Skype calls
the internet connection's outgoing is too slow. ALl internet connections have an outgoing and an incoming speed. Make sure you are not uploading anything to the internet or get a faster internet service provider
Apr 29, 2009 | Philips VOIP8411B/37 IP Phone
Event LED on my new Philips CD535 Duo Phone
go into call lists (centre button up then call lists) and delete the calls in there this will solve the problem
Aug 24, 2007 | Philips DECT 2252S Cordless Phone
Philips CD535 Cordless Phone Logo
Top Philips Lands Phones Experts
Are you a Philips Lands Phone Expert? Answer questions, earn points and help others
