Question about Saws
Blade will not lock - Saws
  • 438 Answers
I advise you to jam the blade against a piece of wood to jam the blade for removal, remember that the bolt holding your blade on is reverse threaded and self tightening so don`t over tighten.
I always use this on the job-sight for it is easer than fumbeling for the lock button with gloves on
Posted on Oct 14, 2013
Cutter blade remains locked.
when you release the blade, sometimes you have to reengage it manually, turn it to unlock, machine off (safety only) push up on bottom of upper blade until it stops. turn hand wheel and watch if blade is moving. If not repeat. When it moves your good to go.
Feb 15, 2014 | Baby Lock Imagine
Sabre saw- craftsman - 17256 - change blades
This saw uses a tool-free blade change. 1. Unplug the jigsaw 2. Place your finger on the lower edge of the see through blade guard, and pull it forward until it locks up in place 3. Lift the tool-free blade change holder (bright yellow piece above the blade), and insert the blade into the slot of the tool-free blade change holder. 4. Release the tool-free blade change holder to lock the blade in place. 5. Pull down on the blade to verify that the blade is securely locked in place. The teeth of the blade should be pointing forward and down. 5. Put the blade guard back down.
You can use with both 'T' & 'U' shanked blades.
Feel free to ask me any other questions about this saw.
Jan 06, 2011 | Craftsman Evolv 45 amp Jig Saw 17434
How do I change the blade on a dewalt compound (12 in) miter saw?
With the saw unplugged - The blade needs to be locked in place so it will not turn when you put a wrench on the nut located on the left side of the blade that holds the blade on. This is done with a locking pin on the right side of the blade. Push the pin in and rotate the blade by hand until the pin locks into the blade and prevents it from moving. With the pin pushed in put a wrench on the large nut on the left side of the blade and turn it. This may be reversed threaded, so you may have to turn the nut clockwise in order to loosen it. When tightening the nut after replacing the blade, you will have to once again lock the blade with the same pin.
Perhaps this video will help you locate the locking pin.
http://www.youtube.com/watch?v=oKmIB-0AE1w&feature=related
Aug 28, 2010 | Dewalt Saws
How do I replace the blade on a Skill saw circular blade? The blade keeps turning. Is there a locking mechanism?
on most of the new saws there is a button that you push in to lock the blade, you have to hold down on the button and tighten blade.after you release button turn the blade to make sure the lock released befor you hit the trigger
Jun 28, 2010 | Saws
How do I remove the blade from a Makita MK470 tile saw? I can't figure out how to hold the saw blade so that I can turn the nut hodling it on. The nut is on pretty tight and I need to lock the blade so I...
There is not a lock on this saw. If the blade is to tight to hold by hand you need to use an impact wrench. It will loosen the nut before the blade has time to start spinning.
Nov 11, 2009 | Saws
I do not know how to install blade and have no manual
Most of the skil jigsaws have a plastic piece with a spring and catch behind it. Just push your blade into the tool and it should lock. When you want to remove it you need to press the plastic lock collar up and it will release the blade. Some of the earlier models weren't as easy to set the blade in and you have to press the lock collar up insert the blade and let the collar down around the blade to lock it.
Sep 09, 2009 | Skil Saws
Replacing saw blade
there is a spindle lock button between the handle and the blade housing, rotate the blade by hand while pushing in on the lock buttonwhen it goes in all the way the blade will be locked in position so you can loosen the bolt with a wrench
Mar 31, 2009 | Sears Craftsman 7-1/4 in. Circular Saw...
Loose lower blade lock
Hi is the lower blade lock warn & needs to be replaced? Had a similar issue with another brand. Good luck
Mar 16, 2009 | Saws
Blade wont stay in Bosch 1882VS jig saw
ARE YOU USING BOSCH BLADES IF NOT GET SOME THEY ARE MADE A LITTLE DIFFERENT THAN SOME OF THE OTHER BRANDS AND FIT A LITTLE BETTER , IF YOU ARE THEN DO NOT KNOW
Feb 22, 2009 | Bosch 1587AVSK 5.0 - AMP Top Handle Jig...
How does one remove a broken blade from a Bosch rs20 blade holder
twist the collar around where the blade fits in the saw. It will lock in the open position. When you insert the new blade, do so firmly until the collar releases locking the new blade in place. Give a tug at the blade to make sure it is locked in.
Nov 27, 2008 | Bosch RS20 13 Amp Reciprocating Saw
Saws Logo
37 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
