Question about Car Audio & Video
When i plug in to the low side of the amp very little sound as compared to the hi imput jack
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 117 Answers
Turn up the gain on the low side.
Posted on Nov 15, 2013
Trying to connect pc with hdmi cable have great picture no sound on TV Used HDMI imput 7 tried imput 6 with hdmi and audio imput from PCF to TV still picture and no sound any suggestions
Hi Scott,
On your PC, you'll need to go into the Control Panel --> Hardware & Sound --> Sound (Windows 7) and click on "Playback". Here, you'll need to change the sound settings to reflect the audio to be handled by the video card / audio chipset / HDMI jack on the motherboard. You should also check for other settings such as Digital Output that are usually associated with and HDMI jack on the card and not an analog jack.
As it is now (or is likely to be the case anyway) the picture is being handled by the HDMI on the video card / motherboard; but the audio is still coming from the the speaker jack(s) on the motherboard or audio card. Making the changes above will redirect the audio from the speaker jack(s) to the HDMI jack instead.
Mar 27, 2015 | Sharp 52"" aquos lc-52sb55u 1080p...
Rms b80 bass guitar amp has little volume in the low side jack , hi side jack is fine just not as much bass
The low in side jack has a lower vol. but should only be1/4 less than the high in jack on most amps, --try this,-- plug guitar in high in then take all the treble off and 1/2 mid. range bring up bass range and if you have equauzation bring down 26k 5k 10k about 2 notches or points. See if that give you better bass tone.
Oct 10, 2013 | Bass New Rms 40 Watt Bass Guitar Amplifier
Peavey sp2xt speakers horn makes no sound when plugged into normal input. Horn works fine when plugged into the high side of the crossover.
High side speaker input jack defective, as they are switch also and if you plug the wire from the amp in full range and no hf sound but connecting directly to the bi-amp hi does, then your female 1/4 plug at crossover is defective for sure.
Jul 28, 2012 | Peavey SP2 PA Passive Speaker
Just got shure sm58, plug it into my starsinger on the tele but sounds is very low compared to the crappy mics? i plugged up a mixer box and can get more sound now but should it work fine with the...
The SM58 uses balanced output. If the starsinger uses a 1/4 inch jack, it is unbalanced input and probbly requires a high impedance rather than the low impedance SM58 mic. You can get an impedance transformer to fix that problem.
Dec 13, 2011 | Shure SM58 Professional Microphone
I plugged my gemini pt-1000 turntable into the aux in the back of my stereo, but the sound is very low. Do I need a preamp?
If the amp doesn't have an imput marked phono, or deck, or turntable, the answer is yes. Search for a 'magnetic cartridge pre-amp' via google.
Feb 26, 2011 | Gemini PT-1000 II Turntable
Hi There, i have a Marshall MG100 DFX Series Guitar Combo Amp,and when i plug my guitar in i get verry little,or no sound from the guitar imput,can you please help. Thank you.
Try exceriszing the connections for input and headphone jacks ( just be inserting qtr inch connector in/out of jack ) a few times. then plug back into your input. if that didn't solve anything while amp is on move the input jack around ( up, down, left, right, ) and see if this makes the signal cut in/out to normal playing. if so you just have broken solder connections on the jack. Also you may just want to test your Speaker to make sure no problems exise there. ( Voltmeter across + and - terminals ) prolly 8 ohms but will most likely state on woofer. if not of this fixes your problem let me know and i'll throw some more steps your way.
Jan 24, 2011 | Marshall Mg100dfx 100-Watt Combo Guitar...
Technics 1310 turntable has left channel (white
There are just two causes, one is the preamp, which can be easily checked by putting the right channel jack in the left terminal. If the sound is normal, then it's likely that the cartridge in the deck is bad, or some wire is loose. However if the sound is still poor then the magnetic cartridge preamp in the amp has a fault. These are normally a single IC, which will have failed. Find the preamp by tracing the wires from the imput socket to the PC board, which may be alone.
Mar 21, 2010 | Audio Players & Recorders
How do I get surround sound while watching my t.v. I'm trying to hook my t.v. through my receiver
you should have an audio out jack / jacks on your tv. run wires from the outputs on the tv to your reciever imput. on the receiver you probably have multiple choices of imputs. select an auxillary or better yet the tv input for the audio.
set your amp function to whatever channel you inputed the tv audio.
chances are you will not hear sound from the tv, but it will be heard through your amp speakers.
Feb 21, 2010 | Audio Players & Recorders
HOW DO I PLUG UP THE SUBWOOFER TO AMPLIFIER
On the back of the amp, there should be a jack with the name "SUBWOOFER PRE OUT". It is a standard RCA jack, but it only puts out a line output, meaning only self-powered subwoofers will work with it. Usually, if the subwoofer does not have an amp, it will have 2 imputs and 2 outputs. You plug the two left and right inputs into the front speaker jack on the amp, and then plug the front speakers into the left and right amp on the subwoofer.
Jun 17, 2009 | Audio Players & Recorders
Little sound out of left satellite in Logitech S200 2.1-system.
Try plugging in some headphones to the right satellite, unplugging them and turning the speakers off and on. This worked for me, and is probably the switch getting stuck between headphones & normal speakers.
Mar 30, 2009 | Logitech Audio Players & Recorders
Car Audio & Video Logo
67 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
