Question about Ryobi Ry09050 26cc 200mph Gas Handheld Leaf Blower/vac
Not geting fire to the plug
What can I do not getting fire to the plug
  • Ryobi Master
  • 7,482 Answers
Hi Dennis
Hi
Make sure you are getting spark at the spark plug, to do this:
Remove your spark plug and check to be sure you are getting a bright blue spark at the spark plug.
You do this by grounding the plug on the head of the engine and cranking the engine or by pulling the crank rope...watching the plug for spark.
If you are getting a nice blue spark then skip A below and go to B.
A...If you do not get a nice blue spark then you may need to replace the electronic module.
Note: If you have to replace the module be sure to measure the position it is in, it is critical to starting.
Take a picture for later reassembly.
B...Also take some fine grit sandpaper (not emery) and lightly sand the flywheel where the magnet is located to clean any rust or corrosion from the magnet area.
Bud
Posted on Oct 11, 2013
Leaking gas by carb
if u sre geting fire from the plug and u have gas i will say that its a good thing it dont start could led to fire and maybe alot of unnesry damge.but over all it should start hold to to the wild open it might be geting the wrong air to gas mix to run right .does it have alot of miles ,is the wires on right.if so then cheack ur time it may have jump or flat spot on cam .but if u have air gas and fire it has to start inless u r fireing on exs instead of intake.hope this helps u??
Sep 17, 2012 | 1976 Honda GL 1000 (K1)
2004 Blaster 2 stroke 200cc fires but well not kick start
check your compression. piston rings might be ate up and its time for a rebuild.
Mar 24, 2012 | RTO 200cc Full Size Four Wheeler ATV
Mazda protege backfires when try to start it
SOUNDS like you have put 1 of the plug wires on the wrong way around OR you have got a valve sticking or burnt out so go back and check the firing order
on a 4 cylinder its 1342 and on a 6 clinder its 153652
RECHECK AND LET ME KNOW HOW YOU GET ON.
Ron
Oct 11, 2009 | 1992 Mazda Protege
85 toyta fuel injected 22r wont start checked exaust not pluged geting fuel for pre start and to the rail also geting fire but when i pulled the plugs they were dry will fire up if i pour a little fuel to...
Rent a pressure tester from Schucks and you get your money back test the fuel pressuer but I can bet the filter hasnever been changed, try changing it first, it's behind the passenger front wheel, remove the wheel it's easier to get to and replace the filter under the intake manifold.
Jul 27, 2009 | Toyota Pickup Cars & Trucks
Husqvarna 350 geting fire and gas but wont start
Have you tried cleaning the air filter? The carburetor fuel inlet may have screens plugged with sawdust as well. If you have spark and fuel and AIR you should get fire(combustion)
Frank
Apr 09, 2009 | Husqvarna Chain Saw 20" Bar
Ryobi Ry09050 26cc 200mph Gas Handheld Leaf Blower/vac Logo
230 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
