Need a parts diagram for a mercury/quicksilver controll # 881170a14
2 Suggested Answers
  • 1381 Answers
SOURCE: where can I see quicksilver 3000 shifter/throttle diagram
try putting what your looking for in google and then click images.
Posted on Aug 19, 2016
Where can I see quicksilver 3000 shifter/throttle diagram
Aug 19, 2016 | Cars & Trucks
2000 Mercury 115 ELPTO impeller replacement. The Quicksilver replacement kit comes with various washers / face seal. The water pump housing didn't have a seal on top of the old one. Am I supposed to use...
if you mean a large flat sided 'O' ring then this is to help keep water in the impellor housing !? some housings have gaskets between the base plate and housing , check the impellor in the housing and see if it stands proud as then you need the gasket ! compare with the old one as it mite have been forgotten !! check the seal and tube for the water pipe also ok!
Sep 23, 2013 | MERCURY / QUICKSILVER Mercury/Quicksilver...
Just bought boat & prop will not in gage all the time
put your motor on the garden hose after you remove the propeller (you don't want to step into a spinning blade). remove the cover and start the motor.
Have some one shift the motor (without engaging the throttle).. This will show you which cable is the shift cable.Disconnect the shifter, and while it's running, shift it full forward and full reverse to fin the halfway point. Next return the control box to neutral and adjust the connector. Start it up and see if the control box will shift the gear box as far as you did by hand. If not you need to take the control box apart and move the cable anchor so you get more movement. Get a repair book and take pictures as the guts of a control box can be VERY confusing.
Sep 06, 2012 | Quicksilver Mercury/Quicksilver Parts...
Need to replace my shifter on my 1994 well craft 243 prima. I have a 5.7 liter v8 mercruiser engine. I need to replace a concealed mount shifter with a two tilt switches, one says trailer
Some where is an easy pop off plastic cove on the big end of the shift handle. When it is popped and you can see an allen head in the middle of the handle, you can remove the handle and let hang by the tilt wires. under the handle will be 3 or more long bolts that hold the shift control to the console. After you remove them the console will go inside the panel taking the handle and wires with it.
NOW comes the tricky part- the key switch has a power wire going to the control/ Try not to break it. Sometimes you need to loosen the key switch from the dash and allow the wires to follow the control out the back of the panel. Now you can see the cables and remove the faulty one.
Jun 24, 2012 | Quicksilver Mercury/Quicksilver Parts...
I have a 1980s Flatacraft Force 4 with a Quicksilver engin control unit. The aim is to keepall as was. My problem is that the steering and Quicksilver units were both patialy dismantled some 5 years ago by...
That control box is very complicated and you should find some old merc mechanic to do that. The steering is very basic and will either have a wire wound cable that spools on to the steering hub, or a flat rack and pinion style which can go together either top or bottom. So try it out and reverse it if it steers backward.
Aug 21, 2011 | Quicksilver Mercury/Quicksilver Parts...
I have a 1997 Rinker fiesta vee 330 with a quicksilver duel control with trim control shifter the right side plastic handle (the one without the trim control) is broken. Also the left side outer rubber...
Hello and good morning;
I read your problem and i think i might be able to help. I believe I know what you are looking for. There is this web site and I am pretty sure you can get this part. However, depending on your condition of control shifter and problem you have to justify yourself if better to buy the whole shifter, but i feel based on your description and your mechanical abilities you most likely can replace the broken or missing parts. Here is the web site, it shows having your part and other associated parts to your shifter.
Please copy and paste this link in your browser.
http://www.partspak.com/ProductCart/pc/viewPrd.asp?idproduct=12429
mr1bill.jpeg I hope the helps you, if you have any more questions , feel free to contact me. Thank You So Much, Mr Bill from Fixya.com
Aug 04, 2011 | Quicksilver Mercury/Quicksilver Parts...
Need to find rebuild kit for quicksilver throttle unit
here is a link to a mercury dealer with parts diagrams and part numbers. click here
Sep 23, 2009 | Bass Pro Boating
Televison & Video Logo
41 people viewed this question
Top Televison & Video Experts
Electro Med Services...
