Question about Canon PC-D340 All-In-One Laser Printer
Canon d340 fuser paper jam - Canon PC-D340 All-In-One Laser Printer
  • 42 Answers
SOURCE: Canon D880 fuser
With an offset #2 phillips screwdriver and some patience you can do this- we have been fixing PLENTY of fusers on the imageclass series-you can get the fuser out thru the exit side of the copier.
1. UNPLUG COPIER , pull platen to left with grey lever
2.remove one screw for upper plastic cover cover pulls down and out
3.remove 2 screws on lower exit cover this comes up and out
4.remove small plastic cover on left side of exit assembly as you face end of copier.
5.pull back black plastic sheet to expose 3 connectors one plugs into circuit board two plug into heater or fuser assembly. unplug these
6.with your offset driver remove 3 screws holding fuser to frame of copier -these will be pointing up.
7. lift fuser up and carefully work out of copier.
check for stuck papers or damaged fuser film sleeve.
To reseat fuser and replace panels go slow and easy the panels fit back in kinda funky it takes a bit of tinkering.
We do not turn the copier upside down to remove the fuser and have replaced about 20 of the fusers or installed a new fuser sleeve.
Good luck and ask all ya want if more assistance is required.
Posted on Apr 23, 2008
Cogz
  • 1326 Answers
SOURCE: Canon PC 1060 error code E-002-000
A E002-000 is fixing unit error code. It is a power problem with the fixing unit. When you removed the paper jam did you see any piece of a blackish grey plastic pieces. If so you need to replace the fusing unit and or the upper fixing film..
Posted on May 11, 2008
SOURCE: check document message
After much frusrtation we lifted the cover and wedged in the left side was a TINY scrap of paper on a little wheel.
Posted on Aug 01, 2008
  • 148 Answers
SOURCE: How to remove the scanner unit on Canon PC1060
you sould not have to remove the scanner unit to clear a jam in the fuser
open all doors and remove anything marked green
remove the the cartridge assembly if it will come out
open the fuser section (usually a release that takes pressure off of the fuser rollers
remove the paper feed cartridge
you now should be able to follow the paper feed path from the time paper goes i until it comes out
if you are not sure of path take a piece of card stock and simulate it goig through feed ara
there are small microswitches/ poto eyes that sense paper lok for an small pieces also clean thes poto eyes with q tip and rubbign alcohol
reassemble
unlug from the wall then plug back in and turn on p roblem sould be solved
Posted on Jan 05, 2009
digitalhubz
  • 109 Answers
SOURCE: My canon MP620 Paper Jam Pull out the Jam Paper Al
There are pieces of paper stock on the sensor, when the paper jam happened then you pull out the paper did you get the whole page of the paper or have missing pieces? open the paper guide, turn off and on the printer and observe the unusual objects in the roller, this error is caused by objects in the sensor.
Posted on Oct 21, 2009
Canon PC D340. The display says supply rec. paper tray: freesize. I have tried disconnecting the printer and reconnecting it but it has not worked. Can you tell me how to solve this problem...
Because the paper size of your software like Word is "custom", and the paper size setting of the printer is "ltr", the printer won't print until you change the paper size to "freesize". Change it in "Additional Functions" menu on the printer (Canon D340). (Word will change the paper size setting automatically if you adjust the margins of your paper too far)
Mar 31, 2011 | Canon PC-D340 All-In-One Laser Printer
E300 error message
Hi Good day!! It may be the fuser problem. u may need to replace the fuser or buy a new unit.
Nov 19, 2010 | Canon imageCLASS D340 All-In-One Laser...
Canon ir4570 always jam at fuser
To properly solve the jam, you would have to start taking apart the machine, take the fuser out and inspect the paper path, a service manual would be helpful as the machines paper path in most cases is very complex, there are alot of moving parts in the path.
there is possibly a small piece of paper in the path, stuck in a gear or something similar, or a part is out of place or there is something in the path that doesn't belong there.
Aug 15, 2010 | Canon Office Equipment & Supplies
Paper is wrinked and stuck, in the left side of machine above the cords. short of taking apart the entire machine do you have any advice
sounds like the jam has occured in the fuser area, if the fuser unit is not user changeable then a technician will have to be called.
Mar 31, 2010 | Canon imageCLASS D340 All-In-One Laser...
I'm considering a Canon D340 multi-function copier and notice it has an "energy saver" button rather than an on/off switch. After making a copy, the panel goes dark. If you select the "energy saver"...
There is still power to the machine. It is simply waiting to be used. These machines use an "instant on" fuser. These fusers (the part that heats up to fix the toner to the paper) do not use a heater lamp that needs to stay hot. They use a thermal head that can heat up within a few seconds so no need to stay on and hot all the time.
Jan 07, 2010 | Canon PC-D340 All-In-One Laser Printer
The screen reads paper jam error, but there is no visible paper jam and when turned on a grinding noise occurs
Most likely, there is a paper jam in the fuser unit....which is stalling the fuser rollers, thus causing grinding noise (accordian or fan folded jam)
Oct 24, 2009 | Canon imageCLASS D320 Digital Copier
My copy machine feeds in paper but it comes out crumbled
Chances are the Fuser Assembly is getting caked up with toner. I am not sure if you honestly want to spend the money on Fixing this problem but, I seen this problem before and it is a pain to remove the fuser, it will most like take the tech an hour and 25 minutes to remove this from your unit.
Jul 23, 2009 | Lexmark X5470 All-In-One InkJet Printer
Paper jam message, but no paper visible
Are there any traces of paper in the printer? Have you tried by restarting printer?
Mar 18, 2009 | Canon PC-D340 All-In-One Laser Printer
Paper jam
Hi usually paper jam at paper input area a or transfor section(photo drum area or fuser unit area, so you may try:
1) take out paper tray and open the cover that you can change toner cartridge there (see manual) looking for any paper inside paper input area or around the cartridge, then take out jam paper.
2) open fuser unit at paper output area ckick a locker at somewhere (see maanual) looking for any paper jam
Dec 22, 2008 | Canon imageRUNNER 1310 Printer
Check document message
It thinks there is a document stuck in the document handler. Check for a small piece of paper, or a stuck sensor.
May 27, 2008 | Canon imageCLASS D340 All-In-One Laser...
Canon PC-D340 All-In-One Laser Printer Logo
83 people viewed this question
old marine
old marine
