Question about ASUS SOCKET AM2 AMD ATHLON 64 X2/64 FX/64/SEMPRON AMD 480X CROSSFIRE CHIPSE (M2AMVP) Motherboard
Asus Pundit P1-AH2 Barebones System not booting
I have the system stated above, when I startup, I get the BIOS flash screen, which sometimes hangs and sometimesgoes to black before the boot loader is started. I am unable to access the BIOS via pressing the DEL button or access the post message via the TAB button. I use linux, when I manage to get past the BIOS flash screen, I get a read GRUB (B ootLoader) error. I have tried a live/startup cd but it cannot load as I have no access to the USB keyboard/mouse. I have tested the harddrive in another machine and that is fine. When open the green light indicating power is on and when I unplug the light stays on for a few seconds before fading, so I think the battery is fine. The fan works okay so there is definitely power circulating.
Any ideas what to try next??
I have no manuals for this machine, do you know where I can get them??
  • Michael Slabbert
    Michael Slabbert May 11, 2010
    best option is to get a PS2 keyboard and mouse and check what is going on in your bios....
    Sergeant:
  • 210 Answers
Try this press ESC, if this did not work press F1 or F2 lastly F8. Accessing the bios depend on manufacture. Process press the key and power if on the pc and keep pressing the key till hearing the beep or bios screen will turn on. Hope the info will help you access the bios screen.
HH
Posted on Sep 05, 2009
Where is the battery on motherboard
yes, easy. You can fin an CR2032 in motherboard
Dec 21, 2012 | ASUS Pundit P1-AH2 Barebone
Is P1-AH2 compatible with Athlon X2, AD5000ODJ22GI?
According to the ASUS website, the processor is NOT compatible with that system.
This is the cpu table for your system
http://www.asus.com/Barebone_PC/P_Series_0811L/P1AH2/#CPUS
Sep 09, 2012 | ASUS Pundit P1-AH2 Barebone
I need the drivers of graphics asus Barebone pundit P1
Hi
There are 4 different P1 models (AH1,AH2,PE2X,PH1?)
If you go to
http://support.asus.com/download/options.aspx?SLanguage=en&type=1
on the left you'll see "Desktop" then under that "Barebones" then scroll down in the middle to "Pundit" and you'll see the models on the right - select which ever is yours and it will take you to all the drivers and support.
Jul 27, 2011 | Computers & Internet
Were can I download drivers for my ASUS Pundit P1-AH2 Barebone for Windows 7
go to this link
www.windowsupdate.com/windows7
there you will find several options.Im sure you will find all you need.
Good Luck
Apr 11, 2010 | ASUS Pundit P1-AH2 Barebone
I need the drivers of graphics and sound
This is all that's available
http://asus.mydriversdownload.com/asus-drivers/Asus-Barebone-P1-PH1-Utilities-Version-V1.01.10-for-Win2003_789.html
Mar 01, 2010 | ASUS Pundit P1-PH1 Barebone
Formated hard drive, installed xp pro, system will not boot up. Asus Pundit P1-PH1 barebone project.
check in bios the setting is set for Ahcd or ide native if activeted one try the other,or simply set the default settings
Nov 20, 2009 | ASUS Pundit P1-PH1 Barebone
Problem with Pundit-R and PCI graphics card
I had a similar problem when installing a GeForce 5200 256mb PCI card in my Asus Pundit-S running winxp which I overcame when I got the sequencing of installation right.
First, Physically install the card in one of the available PCI slots. Using the onboard graphics to your monitor, boot the system. Windows will detect your new card and prompt you to install. Cancel Windows installation and use the supplied Radeon install disc for driver and program installation. After that, Reboot and enter your system's BIOS. On my system, repeatedly hitting the delete key gets me there.
Now this is where it may differ. In my BIOS, I needed to select the ADVANCED Menu followed by PCI CONFIGURATION. If your BIOS does not have the ADVANCED menu, you may have to upgrade it by downloading from the Asus Global Site. That is a whole other challenge but it is possible...hehe
The two options that need to be changed in the PCI Config Menu are:
Primary VGA BIOS -> PCI VGA Card, and
Onboard VGA -> Disabled.
Save changes and exit BIOS however, on exiting, you will need to unplug the VGA/DVI cable from your onboard port and connect it to your PCI card port. My card will not display the content unless it is plugged in from initial boot so you might have to restart your computer if you are not quick enough to catch that boot cycle.
Selecting these options should avoid any onboard conflict between devices as the Pundit-R has an onboard Radeon 9100 chip. I suspect the two same-make chips is where the conflict problem lies plus you don't need to be running the onboard graphics if you have a dedicated PCI card.
I hope this helps.
Good Luck.
Sep 18, 2008 | ASUS Pundit-R Barebone
Problems installing a new processor
take proc. out and check if you bent any pins when replacing it. make sure you installed it correctly. some motherboards wont boot if cooling fan is not connected to motherboard. make sure motherboard supports new proc.
Jan 08, 2008 | ASUS Pundit P1-AH2 Barebone
No sound after new installation
you need to download the sound driver, from the web site the makes the mohter board, find the numbers on it put that in searh and it will find the motherboard, idenifi the board and you can kind the driver.
Nov 27, 2007 | ASUS Pundit P1-AH2 Barebone
New installation sound card
you need to upgrade the drivers to vista
ASUS SOCKET AM2 AMD ATHLON 64 X2/64 FX/64/SEMPRON AMD 480X CROSSFIRE CHIPSE (M2AMVP) Motherboard Logo
446 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
