Question about Samsung SGH-F400 Cellular Phone
Sync outlook - Samsung SGH-F400 Cellular Phone
Syncing my iPhone 5s with outlook 2007 and vise versa
Go to the Microsoft support site the instruction are there.
Jun 01, 2016 | Cell Phones
Cannot get Yahoo to sync with Outlook with Windows 7.
How do I set up Yahoo! Sync?
1. Configure which applications to sync
- Yahoo! Sync synchronizes Yahoo!:
  • Address Book
  • Calendar
- Yahoo! Sync can sync one way or two way.
  • 2 – way, Changes you make to either Yahoo! calendar or Outlook Calendar will sync to the other side.
  • 1 – way : From Outlook to Yahoo!, Outlook will be your source of truth. Any changes you make in Outlook will be synced to Yahoo! but changes made in Yahoo! will not sync to Outlook.
  • 1 – way : From Yahoo! to Outlook, Yahoo! will be your source of truth. Any changes you make in Yahoo! will be synced to Outlook but changes made in Outlook will not sync to Yahoo!.
2. Configure how often Yahoo! Sync will synchronize changes
  • Automatic sync ensures that your data stays up-to-date between Outlook and Yahoo at all times. It also ensures that you have fewer opportunities for data conflict. We strongly suggest that you enable Automatic sync by selecting Yes, then clicking Next. 30 or 60 minutes is the recommended interval.
  • If the Manual Sync option is selected, Yahoo! Sync will only synchronize your data when you initiate it. Just click the orange Yahoo! Sync icon in the task bar at the bottom right of your screen and select “Sync Now”.
  • Even if automatic sync is enabled, you can manually initiate a sync whenever you like. Just click the orange Yahoo! Sync icon in the task bar at the bottom right of your screen and select “Sync Now”.
  • Click Next.
3. Yahoo ID and password
Before starting your very first sync, Yahoo! Sync will ask you for your Yahoo! username and password. Use the same username and password you would use when logging into other Yahoo! services. Remember that your username and password is case-sensitive. Enter your information carefully.
Outlook users: Outlook may be configured to ask for your username and password whenever Outlook is used. This step only applies to you if, when you open Outlook, you’re asked to enter a username and password. If this applies to you, enable auto-login on Outlook. Here’s how: go to the Windows “Control Panel” and double click “Mail”. Click “Show Profiles”. Select “Always use this profile” and select the profile you want to sync to.
Tip: Your username and password will be safely stored on your computer. We store your username and password in a secure format and will occasionally ask you to confirm the password for added security.
4. Finish
Once you click Finish, your first sync will automatically begin. You can tell when a sync is in progress because the orange icon in the bottom right corner of your computer will be spinning. If you have a lot of contact or calendar information the first sync can take a lot of time.
Jun 01, 2010 | Yahoo Mail
Can I sync ipad with outlook? i'm using outlook 2007 and I really would like to sync it with my new ipad.
Hi
I had the same problem, outlook on ipad or syncing ipad with out look is very easy, just follow those few steps, Good luck!!!
I'm using iTunes in order to sync ipad and outlook, make sure your itunes is up to date (help ---->"check for updases") .
How to Use iTunes to syncYour iPad With Outlook Calendar.
* Connect your iPad to your laptop or desktop using the cable that you got with the ipad.
* iTunes will launch in the PC automatically.
* You'll need to find the itunes source list, choose "iPhone" and click on "Info" tab and then "Sync Outlook calendars" option.
* Notice in the lower right corner of your screen the "Apply" button. click on it.
Now your computer is synced with the ipad and the outlook!
Feb 11, 2010 | Apple iPad 32 GB WiFi Tablet PC
Sync iphone to outlook contacts
Speaking of syncing iPhone with Outlook, you can take advantage of iTunes to sync contacts. sync-iphone-outlook-contacts-oxaxc0rwhkhzilrwacqreyis-3-0.jpg
  1. Connect iPhone to computer with USB cable, and launch iTunes.
  2. Click iPhone icon, and choose Info the Summary Panel in left sidebar.
  3. Check Sync Contacts with, and choose in the drop-down menu.
  4. Click Apply at the right bottom to start syncing iPhone contacts with Outlook.
When the sync is finished, the contacts will show up in the Outlook contacts. Besides syncing contacts, you can also sync iPhone calendars and mails to outlook as well. But if you have noticed, the sync of iTunes is an annoying issue among iPhone users as during the sync of iTunes, the application may erase the available files in their iPhone.
http://www.leawo.org/tutorial/how-to-sync-iphone-with-outlook.html
Jul 19, 2009 | Apple iPhone Smartphone
How to sync contacts from iphone to outlook 2003?
When you connect your iPhone to the PC that you always sync with, Go to Info tab, Check the box Sync Contacts with: and select Outlook. Then make sure that you check the box Put new contacts created on this phone into the group: and select a subfolder in your main contacts folder.
This way, all the contacts from your iPhone will be saved into another folder in your main contacts folder of your Outlook PST.
Let me know if you have any questions.
Thanks
Sandeep
Jan 30, 2008 | Apple iPhone Smartphone
Outlook Express
You cannot sync treo with Outlook express because of the Outlook express limitations However you can sync with Outlook
Sep 12, 2005 | Palm Treo 600 Handheld
T3 sync with Outlook works except for Tasks
A hard reset of my T3 and sync with 'Desktop overwrite HH' on all Outlook conduits seemed to have resolved the problem.
Sep 11, 2005 | Palm Tungsten T3 Handheld
Sync with outlook
Change ur sync method. To change the sync from palm desktop to outlook , insert the installiation disc in and then install the pocket mirror conduits conduits that will help u to sync with outlook .
Sep 11, 2005 | Palm m125 Handheld
Calendar Sync issues with Treo 650
Tryy this -- Go to Chapura.com and purchase the pocket mirror software. I have Sprint service and that additional software has resolved my synch issues.
Sep 11, 2005 | Palm Treo 650 Handheld
Can I sync with Outlook Express
no You cannot sync thorugh outlook express however you have option to migrate your work e mail address from outlook express to Outlook , let me know if you want to know about how to ??????
Samsung SGH-F400 Cellular Phone Logo
13 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
