Question about Acer Computers & Internet
Exiting media problem, windows7 won't boot - Acer Computers & Internet
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 30 Answers
Unfortunately is sounds that your PC has crashed. Oh no! Hope you've made backups. If not you may wish to take the machine to a repair shop and they may attempt (no guarantees) to recover your data. Alternatively, check out erecovery for Acer which can do a factory default on the machine. If you do not know how check your manual or do a quick Google search, or take the machine to a repair shop.
Posted on Nov 11, 2013
Pxe mof exiting intel pxe rom
You are going where no man has gone before. Go to the VMware forum and see if they can help. I gave up on this VMware 2 years ago. Just can't get it to work. And I'm a technician!
Mar 15, 2014 | Toshiba Computers & Internet
Tip
Install Windows 7 or Windows Vista on a Pc Without DVD Media
For user who doesn’t want to waste a DVD disc to burn the ISO to physical media, and does not have WinPE (Windows PE) startup disc, here’s a workaround method to install Windows Vista and Windows 7 into physical computer’s hard disk drive or partition (volume) directly with ISO without writing or burning to disc. The without-disc installation method is useful especially during beta and RC period of new operating system in the making, where the new build and new versionis launching and publishing every now and then. This tutorial guide assumes that the new Windows 7 or Windows Vista will be installed and replaced the original existing operating system currently installed. The instructions can be modified slightly (mainly on hard disk partition used) to fit into need of readers who want to have a dual-boot, multi-boot, or simply just to upgrade install to new OS.
1. Install a virtual CD/DVD drive on existing Windows operating system.
2. Mount the Windows Vista or Windows 7 installation DVD ISO image using the virtual drive.
3. Copy all files inside the virtual CD/DVD drive mounted with the ISO into any folder on any partition or hard disk drive not going to be used to install the Windows OS. For example, copy into E:\Windows7.
4. Copy the bootmgr and boot folders nested inside the copied folder (i.e. \Windows7) to root directory of system boot drive, typically C:\.
Note: For Windows Vista, users may need to use this step: Copy the bootmgr folder from E:\Windows7 to C:\ root directory, copy E:\Windows7\boot\boot.sdi file to same folder in C:\boot folder, and then copy bootsect.exe from the E:\Windows7\boot\ folder to C:\ drive.
Note: boot folder in system boot drive is hidden system folder.
5. Create a new folder named sources under the C:\ root folder.
6. Copy the boot.win file inside \Windows7\sources folder to the source folder created in the system boot drive, normally C:\.
7. Open a command prompt as administrator.
8. Run the following command (change the C to your drive path letter if applicable):
C:\boot\bootsect.exe /nt60 C:
For Windows Vista users who copied bootsect.exe to C:\ root folder, use the following command instead:
C:\bootsect.exe /nt60 C:
A successful message is the command completes successfully.
9. Change the name or label of the boot system partition local disk to BDCP or any name you prefer that easier to remember and type (in DOS command promot, use label command).
10. Restart the computer.
11. After booting up, the system will start the corresponding Windows installation process. Select the applicable language to install, time and currency format (regional settings locale) and keyboard or input method in the installation wizard dialog.
12. On the next screen, user will be presented with option to Install Windows. DO NOT press on Install Windows button, instead, click on Repair My Computer link on the bottom left corner.
13. In the Windows Recovery Environment (WinRE) System Recovery Options dialog window, click on Command Prompt to open a DOS Prompt window.
14. Run the format command to format the primary hard disk or partition to clean state:
format c: /q
Note: /q switch, which perform quick format can be omitted to full format. And if existing hard disk partition is of FAT32 filesystem format, use format c: /q /fs:ntfs to convert the file system to NTFS while formatting. Before formatting begins, the command may prompt for hard disk drive or partition label name, if so, enter accordingly (i.e. BDCP).
15. After format completed, start the Windows Vista or Windows 7 installation process again by manually running the setup.exe located in the copied. Note that the setup.exe is not the one located on boot system drive which copied at later step, as the boot drive has been formatted. For example:
E:\Windows7\sources\setup.exe
16. Continue with installation procedures by following on-screen instructions as per normal practice.
on May 19, 2010 | Computers & Internet
Windows 7 starter doesnt start
You can use an external DVD drive and a Windows 7 Starter media to fix it. Boot it using the external drive, and the Windows 7 media will fix the boot problem automatically.
Mar 07, 2014 | Acer eMachines 350-2074 Netbook
Hello, My laptop shows the following message when I turn it on- Realtek PCIe FE Family controller Series v1.19(08/10/09) PXE-EGI-Media test failure,check cable PXE-MOF-Exiting PXE ROM Reboot an
It can't locate a working boot disc. Most likely lost communications with hard drive. Look in BIOS again to see it recognizes the drive. If not try re-seating / reconnecting drive.
Feb 16, 2013 | Dell Inspiron N5010 Black
My computer won't boot up with windows xp service pack 3
This is a strong indicator the hard drive has failed, have it tested before replacement.
Jul 10, 2012 | Toshiba Tecra Computers & Internet
Windows will not boot on my Eeepc 1005HA. 0xc000000f -- The boot selection failed because a required device is inaccessible. I have tried to reinstall windows7 from USB (tested and working) but boot...
BootSuite is an awesome toolkit that includes a boot CD and several other data rescue tools that help get your PC going even if Windows won't start or computer won't boot up at all.
Jul 11, 2011 | ASUS Eee PC 1005HA-PU1X-BK Netbook
PXE-E61 : media test failure, check For Realtek RTL8101E/8102E PCI-E Ethernet Controller v1.06 (080222) PXE-E61: Media test failure, check cable PXE-M0F: Exiting PXE ROM.
The system is not finding any bootable media (Hard Drive) and is attempting to boot via the network card (PXE Boot) the error message is saying that there is not PXE network to boot from and it is exiting the process.
Generally, this is caused by a hard Drive failure. Reseat the drive and or drive connections and see if the system will find the hard drive.
Generally, a Hard drive failure
Jun 17, 2011 | Computers & Internet
My computer won't turn on properly. It keeps saying disk error press control alt delete. When I do it just says it again and again. It won't load and turn on.
First you should check if there is any disk on your cd room, if there is any disk you should remove the disk from the cd room, if there is no disk the possibility is your hard drive getting error
Press f2 or delete to enter your bios set up system
Look for boot menu
Set the first boot as a HDD and the second boot as cd room and disable the third boot
Save and Exit the setting
if your computer still won't load you need to reinstall your windows
insert windows cd and go to set up again by pressing f2 or delete button
Set the first boot as cd room then the second boot as HDD
Save and exit the setting again
When the message press any key to boot from cd appears you should press the space bar or another key
Then just follow the instruction of formatting
Jun 03, 2011 | Acer Computers & Internet
I get a black screen that say: Realtek PCI Express Gigabit Ethernet Controller Series v2.26 (090219) PXE-E61 media Test Failure check cable ****-MOF: Exiting PxE ROM No Bootable device- insert boot disk...
Apparently, the HDD has failed, that's why it doesn't find a bootable device and you can't restore te factory settings. You can try getting Hiren's Boot CD and use the testing tools to scan and fix the drive. Sometimes it just gets corrupted and returns to RAW format and just needs a format ( unfortunately you will lose all your data).
Nov 17, 2010 | Computers & Internet
Hello Sir, I purchased Acer Aspire 5745G two weeks ago. Yesterday My brother installed Fedora 12 and Windows7 was already instlled in it... Acer Customer Care Service suggested me to use Windows7 only. So...
The problem is with your Windows Boot file "bot.ini file" This file can become damage, corrupted or deleted for a number of reaons, (here seems the installation of Fedora 12) and id usually brought to your attention to by an error message befoe booting windows, the same message you are facing. there are two ways of removing it. 1-You can format your OS and re install it. or 2- repair your windows using the windows OS Cd.
Nov 15, 2010 | Acer Aspire One PC Notebook
Computers & Internet Logo
16 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
