Question about Car Audio & Video
Pioneer 25685332 shows err
What is the solution to an error code ( OC ERR 1) ON PIONEER XV-DV360
The "OC ERR 1" code is a sign that there is something wrong with the speaker connection(s). Mostly one of the speaker cables is causing a short-circuit, which triggers the safety system. Power off the unit and pull out the plug. Check all the speaker connections (amplifier and speaker side) and make sure that no (parts of the) cable is (are) touching the chassis. Twist the cable ends to a single core if necessary.
Jul 21, 2015 | Pioneer Televison & Video
When I turn on my pioneer xxd3121, it's showing only OC ERR I. How can I resolve the issue?
Go to the pioneer site and either contact them for tech support or download a user manual.
Apr 08, 2014 | Pioneer Audio Players & Recorders
App err
PDF]VSX-D414 VSX-D514 - Pioneer
www.pioneer-latin.com/downloads/xre3077a.pdf
Increase the separation between the equipment and receiver. - Connect the .....AUDIO/VIDEO MULTI-CHANNEL RECEIVER VSX-D514. RCE. VSB. MODE.
Pioneer VSX-D514 Receiver Repair Questions,... - Fixya
www.fixya.com > Forum > Audio & Video Receivers > Pioneer
Recent Pioneer VSX-D514 Receiver questions, problems & answers. Free expert DIY tips, support, troubleshooting help & repair advice for all Audio & Video ...
app err Turns on then says amp err. - Fixya
Jan 26, 2012 | Pioneer VSX-D514 Receiver
Amp err
That will be the internal amplifier in the unit itself giving an error message.
Jul 12, 2010 | Pioneer VSX-D912 Receiver
Dsc-363 displays code " oc err 1 "
It's output power amplifier ic problem. change ur output ic
Mar 08, 2009 | Pioneer DV-363 DVD Player
Pioneer cdxfm128 12 disc changer
Err 11, Err 12, Err 14, Err 17
Dirt or a scratch on the disc stops the laser
beam from being able to focus.
Dirt or a scratch on the disc hinders the track
Clean or replace scratched disk.
There ya go, clean or replace the cd that is displayed.
Nov 15, 2008 | Car Audio & Video
Pioneer D711
Hi...
Is there an access cover with screws in it underneath?
MOst of the receivers have something like that.
I would also check the output PCB assby for shorts or opens.
Jul 02, 2008 | Pioneer VSX-D711 Receiver
Stand by button flashes but receiver wont turn on
I have vsx-d812 that has an AMP ERR in error menu. the troubleshooting was found to be Q696 and Q697 in the DC prot. area on "C" board, up near front toward diplay in center of c board. You can get access to error codes on VSX pioneer unit by pressing "enter" and "adv. surr." simultaneously for 2 sec. The display should show what error code you are experiencing. I believe there are three diff. error codes. 1) AMP ERR 2) OVERLOAD 3) BOAD ERR (not mistyped) I hope this helps pinpoint error code for ya.
Oct 07, 2007 | Pioneer VSX-816-K/S Receiver
PT FAN ERR
There is a fan located inside the unit used to cool the output chip. I iwould take a look to see if it is full of dirt, or is not turning.
Oct 03, 2007 | Pioneer HTD-510 System
Car Audio & Video Logo
65 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
