Question about Patton Dryers
I have a u2-1287 that runs smooth after a few hours makes noise
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 81 Answers
Most electric fans have steel rotor shafts with bronze bearings.
they "call" them oilite bearings,susposedly because the bronze bushing (it is really a bronze bushing) but called a bearing, is oil impregnanted and susposed to be good for the life of the fan.
that is only true if you expect the life of the fan to be ONLY 18 to 24 months which is the average time that the factory oil lasts.
the oil dries up the longer the fan runs and the shaft makes the bronze bushing begin to heat up due to increased friction and eventually wear the round bronze bushinhg egg shaped.
Try giving your bearings a good healthy squirt of sae 30 wieght oil from a zoom spout-- [pull out straw squeeze bottle refillable oiler.]
I recommend oiling both the front and real fan motor bearings once a month.
This is the most common cause of fan failure.
Because I oil my fans bearings once a month,I still have fans that run from 1940,1950,1960 and 1970. The 1940 GE fan lasted 70 years and is still running strong.
Some newer fans have chinese ball bearings , but the ball bearings also die prematurely from lack of needed oil.
Sometimes, you can pry off the bearing race cover to get oil into the bearing.
a good trick here is to use wd40 if you think you cant get sae 30 into the bearing.
wd40 is a n extreemly light wieght oil that penetrates very well
and gets into places where you think it wont get into .
You can totally wet up a fan motor with either
sae 30 or wd 40 or both without worrying about the electric
motor being harmed by the oil.
the oil,sae 30 or wd 40 wont hurt the motor.
On badly rusted and nearly siezed fan motor bushings , or any electric motor as well, I use first wd40 for penetration and then sae 30 for good long duty lubricatin.
You may have to keep squirting ioil in the motor for 1/2 hour and end up with a puddle of oil under the fan motor, but about 40 % of the time ,you can bring back to life what yo thought was a dead motor. Perserverance is required and faith that you can fix the motor. 40 % of the time you get sucess to one degree or another and 60 % of the time ,its kaput for good.
I got all those fans i mentioned before because other people thought the bearing were seized and shot, and put the fans in the garbage pail where I rescued the fans from.
the bearings were almost siezed but far from shot becaue i got oil in to the shafts and bearings and another 12 to 20 years of life from the fans. However,i do oil them monthly in fan season, which is winter time for me, since I use fans to blow the hot air off my wood stove,
Posted on Oct 11, 2013
    Master:
  • 996 Answers
Bushesr bearing worn
Posted on Jan 20, 2015
I have a 2003 trailblazer its making a sqeal noise and it has lack of power and the engine light is on
Take the serpentine belt off and check how it runs now (do this only for a few seconds) if it improves then check the pulleys and the alternator they all should turn by hand very easy and smooth
Feb 14, 2015 | Cars & Trucks
STARTS ROUGH,LOUD NOISE FROM ENGINE,THEN RUNS SMOOTH
It sounds as though you may have a starter bendix failing or the starter bolts may have loosened. Disconnect the battery, crawl under and investigate.
If the bolts are tight, you may want to look into the cost of a new starter.
Good luck
Apr 03, 2014 | 1999 Chevrolet Silverado 1500
My machine makes the awful noise when running do I need to tighten the belt or replace it
Noises can be a few things, first remove the belt spin drum by hand it should be fairy smooth and Quiet, if not then chance is the rum bearings are faulty quite an expensive repair....
Jan 31, 2011 | Washing Machines
Maytag LDG9334AAE Gas dryer making popping noise from vent
clean clean clean everything, dont let it go to much longer or you will have a fire, and dont ignore this or you regret it... then tell me if it makes the noise
May 07, 2009 | Maytag Dryers
Loud humming noise as fridge is running
if you have ice buildup then the fridge may be low on freon.
or there is dust clogging around the pump or fan is not running.
remove the bottom or back and look around the compressor.
see that the fan is running.
Jun 04, 2008 | Sub-Zero 661/F Side by Side Refrigerator
Dryers Logo
156 people viewed this question
Top Patton Dryers Experts
Tom Chichester
Rani wadia
Rani wadia
Are you a Patton Dryer Expert? Answer questions, earn points and help others
