Question about Motorola RFS6000 WIRELESS SWITCH REDUNDANT 0 ACCESS PORT LICENSE
Where do i go on my motorola rfs 6000 to change the ssid password for users to get onto wireless network?
Mrvica
  • 167 Answers
SOURCE: Motorola modem SBG900
you must define DNS and Gateway!!! Go on My Network Places, right click, again right click on your network, select properties, TCP/IP and in there enter needed IP addresses!!!
Posted on Jan 25, 2008
geraldo14200
  • 48 Answers
SOURCE: network security
Are you sure it's a Motorola router and not a Motorolad cable modem? if it's a router, you have to hook up your main computer to the router via an ethernet cable directly, you also need to know the router's IP address meaning something like this, 192.168.1.2 you would enter this into the internet explorer title section of your browser, once you are in there you need to enter in a HEX key, you'll have to find this option within the router's setup options, the HEX key has to be 10 digits, make sure you write this down and save it.
Posted on Apr 09, 2009
ionStorm
  • 50 Answers
SOURCE: Wifi discovery problem. I
Assuming you haven't changed your modem's settings...
  1. Access the modem by typing http://192.168.100.1 in your browser.
  2. Enter the default username admin and password motorola
  3. On the left frame, click Wireless
  4. Click on the Security tab
  5. Under the tab, click Advanced
  6. Untick Disable ESSID Broadcast
Posted on May 13, 2011
  • 285 Answers
SOURCE: can't remember the network ssid and the password
ASK UR NETWORK OPERATOR FOR IT
Posted on Mar 10, 2012
SOURCE: cant log on to the wireless motorola 192.168.0.1
If you got to the router's interface by typing 192.168.0.1 and it requested the userid and password. If the password you enter did not let you in, then the password is wrong. Maybe someone changed the default userid and password to something else.
You can always press the reset button on the router to set it back to Factory Settings. Then the default userid and password will work, but you will have to set the wireless back up and configure the basic settings (if you have a userid and password that the phone company uses as the network userid and password. This is not your email address userid and password).
Posted on Jun 08, 2012
Name and passsword belkin f7d1301
  1. Choose a laptop or WiFi device that is currently connected to your network. If none of your devices are connected, use an Ethernet cable and connect a computer or laptop directly to your wireless gateway.
  2. Open a web browser and go to the Admin Tool (http://10.0.0.1) - this is the wireless gateway's administration site. The default settings are:
    • Username: admin
    • Password: password (case-sensitive)
    • Note: If you changed your Admin Tool password previously, you will need to use your new login information. If you don't remember your Admin Tool password, you will need to factory reset your wireless gateway. Instructions on how to do this can be found by reviewing the wireless gateway user guides at Wireless Gateway Guides.
  3. On the left navigation menu, select Gateway, then Connection and then Wi-Fi.
  4. Under Private Wi-Fi Network, you'll see the Name (SSID) of your WiFi network. (You may want to write down this information.)
    • Wireless Gateway 1 customers, click EDIT at the right.
    • Wireless Gateway 2 customers, click EDIT for both 2.4 GHz and 5 GHz bands to view the settings for each. ?
  5. Check the box next to Show Network Password. The Network Password (Network Key) will be displayed above. (You may want to write down this information.)
    • On this page, you can also edit your wireless network information, including changing your Network Name (SSID) or Password (Network Key). If you make any changes, remember to click SAVE SETTINGS.
  6. Now that you have your Network Name (SSID) and Password (Network Key), you can connect your WiFi devices to your network.
  7. If you have changed any information, use the new information to reconnect all your WiFi devices to your network.
Learn how an XFINITY Internet subscriber visiting your home can connect to WiFi without sharing your Network Name (SSID) or Password (Network Key)
Jan 04, 2014 | Linksys Wireless-G Broadband Router
Motorola rfs6000 default password
Motorola RFS Default Password
Default Ip address ==> 10.1.1.100
Username ==> admin
Password ==> superuser
for CLI==> RFS6000login ==> CLI
Mar 27, 2012 | Motorola RFS6000 Wireless Switch - P/N...
How to change wifi name in router
The wifi name you are referring to is called SSID, service set identifier. You can change that by logging onto your routers Web based utility. Open your web browser and type in 192.168.0.1 and it will ask you for a user name and password. If you keep the default user name and password the user name should be admin and the password is blank, meaning there is no password set up. After logging on, click on top tab "Setup" and on the side menu "Wireless". You should be able to change the SSID by typing in a new name in the field "Wireless Network Name". Make sure you save the changes! This should then change the name.
Mar 25, 2012 | D-Link DIR-600 Router
Wifi discovery problem. I have installed a Motorola SBG900i. All my wifi devices have had trouble discovering the SSID. When I do a scan available networks it does not exist. I forced 2 laptops to...
May 13, 2011 | Arris SURFboard SBG900 Wireless Router...
All wired ports are sending and recieving data but, my wi fi won't appear.
This can be caused by basic wireless settings of the router or the old firmware of the device especially if you have wrt54g version 5/6 router. To check these settings, follow these steps:
  1. Using a computer that is plugged into the router directly with a network cable, open a web browser.
  2. In the "Address Bar" type http://192.168.1.1 and press Enter.
  3. A box should appear asking for a "User Name" and a "Password". Leave the "User Name" field empty, and type your WRT54G router password into the "Password" field (the default "Password" is admin) and click the OK button or press [Enter].
  4. The WRT54G "Setup" page should now appear. Click onto the Wireless page.
  5. When the "Wireless" page loads, you should be on the Basic Wireless Settings sub-section.
Please check the following:
  1. "Wireless Network Mode": should be Mixed.
  2. "Wireless Network Name": should not be linksys (if it is 'linksys", try a different SSID name like linksys123, or your last name).
  3. "Wireless Channel": if the channel is set to "6 - 2.437GHz", change it to either "1 - 2.412GHz", or "11 - 2.462GHz".
  4. "Wireless SSID Broadcast": should be Enable.
  5. Click on the Save Settings button toward the bottom of the page to save changes. Click Continue when rompted to reload the page.
  6. Next, click onto the Wireless Security page(under Wireless tab). Click the WPA sub-section (depending on your router firmware version, this sub-section might also be labeled "Wireless").
  7. The WRT54G settings have been changed. You can now configure your wireless adapters and software with the same settings as your router, and restart the computers to check the connections.
Note : Make sure as well the wireless switch of your laptop is on.
Dec 23, 2010 | Linksys Wireless-G Broadband Router
How do I lock my Dell TruMobile 2300 wireless router to keep the neighbors from getting access to my wireless internet connection
press win key + r
under run type cmd
on the command prompt type ipconfig
not down your defaut gateway.
type it in your web browser, and then enter the correct user name and password for the router.(i u dont know the user name leave it blank or try admin for both user name and password or its combination o call dell for it)
Create a unique password on your router : Once you have logged into your router, the first thing you should do to secure your network is to change the default password* of the router to something more secure.
This will prevent others from accessing the router and you can easily maintain the security settings that you want. You can change the password from the Administration settings on your router’s settings page. The default values are generally admin / password.
Change your Network’s SSID name:
The SSID (or Wireless Network Name) of your Wireless Router is usually pre-defined as "default" or is set as the brand name of the router (e.g., linksys). Although this will not make your network inherently* more secure, changing the SSID name of your network is a good idea as it will make it more obvious for others to know which network they are connecting to.
This setting is usually under the basic wireless settings in your router’s settings page. Once this is set, you will always be sure that you are connecting to the correct Wireless network even if there are multiple wireless networks in your area. Don’t use your name, home address or other personal information in the SSID name.
This is sufficient to secure your router from other to use it.
Aug 11, 2010 | Dell TrueMobile 2300 Wireless Router...
How to secure my internet connection via smc router
If you plan to have a wireless network, you should set it up so that only people you choose can access it. Here are a few options for wireless network security.
Wired Equivalent Privacy (WEP)
WEP is a widely used network security method. When you enable WEP, you set up a network security key. This key encrypts the information that one computer sends to another computer across your network. The receiving computer needs the key to decode the information so that it's difficult for someone on another computer to get onto your network and access files without your permission.
Wi-Fi Protected Access (WPA)
WPA was created to improve the security of WEP. Like WEP, WPA encrypts information, but it also checks to make sure that the network security key has not been modified. WPA also authenticates users to help ensure that only authorized people can access the network. If your networking hardware works with both WEP and WPA security, we recommend that you use WPA.
There are two types of WPA authentication: WPA and WPA2. WPA is designed to work with all wireless network adapters, but it might not work with older routers or access points. WPA2 is more secure than WPA, but it will not work with some older network adapters. WPA is designed to be used with an 802.1X authentication server, which distributes different keys to each user. This is referred to as WPA-Enterprise or WPA2-Enterprise. It can also be used in a pre-shared key (PSK) mode, where every user is given the same passphrase. This is referred to as WPA-Personal or WPA2-Personal.
802.1X authentication can help enhance security for 802.11 wireless networks and wired Ethernet networks. 802.1X uses an authentication server to validate users and provide network access. On wireless networks, 802.1X can work with Wired Equivalent Privacy (WEP) or Wi-Fi Protected Access (WPA) keys. This type of authentication is typically used when connecting to a workplace network.
IF THIS ALL DOSEN'T WORK TRY THE FOLLOWING:
Wireless network security recommendations
If you have a wireless network, there are some additional security precautions that you should take.
Use a network security key
If you have a wireless network, you should set up a network security key, which turns on encryption. With encryption, people can't connect to your network without the security key. Also, any information that is sent across your network is encrypted so that only computers that have the key to decrypt the information can read it. This can help avert attempts to access your network and files without your permission. Common wireless network encryption methods are Wired Equivalent Privacy (WEP) and Wi-Fi Protected Access (WPA) and WPA-2.
Change the default administrator name and password on your router or access point
If you have a router or access point, you probably used a default name and password to set up the equipment. Most manufacturers use the same default name and password for all of their equipment, which someone could use to access your router or access point without you knowing it. To avoid that risk, change the default administrator user name and password for your router. Check the information that came with your device for instructions about how to change the name and password.
Change the default SSID
Routers and access points use a wireless network name called a service set identifier (SSID). Most manufacturers use the same SSID for all of their routers and access points. We recommend that you change the default SSID to keep your wireless network from overlapping with other wireless networks that might be using the default SSID. It makes it easier for you to identify which wireless network is yours, if there is more than one nearby, because the SSID is typically shown in the list of available networks. Check the information that came with your device for instructions about how to change the default SSID.
Position your router or access point carefully
Wireless signals can transmit a few hundred feet, so the signal from your network could be broadcast outside of your home. You can help limit the area that your wireless signal reaches by positioning your router or access point close to the center of your home rather than near an outside wall or window.
Aug 03, 2010 | SMC Barricade 7004VWBR Wireless Router
I have LINKSYS wireless router, mod # WRT546 in my home for my PC. My internet connecting has gotten very slow and a friend advised other PC might be accessing my wireless and I should password protect my...
You can secure your wireless network wit WEP or WAP code.
For that Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
For belkin router http://192.168.15.1
or
http://192.168.2.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router.
Click on wireless settings then enable WEP Security then add WEP code .It is your password to connect wi fi.Then save settings and restart router.
Then you can connect your wi fi network with that code.
Thanks for using FixYa.
Feb 09, 2010 | Linksys Wireless-G WRT54G Router
I am trying to set up security on my Linksys router WRT150N?
Below are some pointers to secure your linksys router:
- Change the default password of the router. By default it is admin. Changing the default password will prevent unwanted users from accessing the setup page of your router. Click here for the steps.
- Change the default SSID or network name. This will allow you to identify your wireless network. Click here for the steps.
- Disable SSID broadcast. This will prevent other users from detecting your wireless network. Click here for the steps. Take note: You will need to manually enter the SSID on your wireless adapter to connect.
- Enabling wireless security on your router. This will require a security key before you can connect to the wireless network. Click here for the steps.
For additional security to your wireless networks, you may refer to this link.
Hope this helps! Happy Holidays!
Dec 28, 2009 | Linksys Wireless-N WRT150N Router
Username & password
Changing the router password from admin to any password I think that you would be possible. Other brands of router has that option. And the router password won't affect the password for the wireless connection, they are different from each other. Wireless mac Filter is another way of securing your wireless network. Its done by listing the MAC Addrses (media Access control) or the physical address of your wireless adapter on your computer/s to either allow them to connect to the network or not to connect to the network. but I recommend to just use WPA security. It's secured and its much easier to add another wireless device to your network, because you just need to put the password and no need to get the MAC address and manually encode in on your router setup page. Its also possible to change the SSID or the name of your network.
I will get back to you with the steps on how to change the ssid adn change the router password. Okay?
May 26, 2008 | Zhone (6218-I2-200) Router
Motorola RFS6000 WIRELESS SWITCH REDUNDANT 0 ACCESS PORT LICENSE Logo
50 people viewed this question
Top Motorola Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Motorola Computer and Internet Expert? Answer questions, earn points and help others
