Question about Konica Minolta Magicolor 4690MF Multifunction Laser Printer
Why is there a white streak down the middle of the a copy or print?
  • 63 Answers
Clean your laser slit glass
Posted on Oct 11, 2013
If I Have a streak down the middle of my copies, is it the roller? If not, what do I do ?
if its not the cartridge then its the fuser. buy a new copier, cheaper than fixing it.
Feb 10, 2015 | Canon PC170 Black and White Copier
Canon NP6221 copier makes copies with black streak down middle.
I suggest You Go to Official Canon Printer Page For You Canon Problem On Below Canon Page URL:
Copy Has Vertical Black Streaks In Case You Still face Problem and Need Online Assistance Then Please Follow Us For On : Canon Printer Support
Feb 16, 2014 | Canon NP6221 Fuser Thermofuse
Canon NP6221 makes copies black and white with black streak down middle. How can it be fixed--works well otherwise.
They are manny cause of black copy.
1.over tone.
2.arching on main charger or dirt on main charger.
In Case You Still face Problem and Need Online Assistance Then Please Follow Us For On : Brother Printer Support
Streak in the middle of the copie/print with drum and blade replaced
Please clean the drum charge roller use the izopropilalcool,clean the charge roller cleaning roller,clean use the vacuum cleaner the waste toner (located under transfer assembly 6 screw),activate the ATDC and AIDC sensor configuration.
Jan 08, 2012 | Ricoh Aficio 1035 Copier
Black streaks on copies Canon PC11
Ok. You will likely need a new toner drum or cartrige. (usually you need the drum)
May 24, 2009 | Black Box (PC110C) Print Server
HP Officejet 6300 All-in-one machine makes black streaks
The problem is that that there a small piece of glass that the doc feeder use's to scan the orginal. You will have to clean the small glass it's about a half of a inch piece and is normally under the doc feeder unit. It will either be to the right side of the main copy board glass or it is under the doc feed unit where the paper goes down through the feeder. It is mostly some white out on the glass, just clean with a dam cloth with water or windex..... Good Luck
Nov 15, 2008 | HP 190 Copier
After printing, the page has a line close tho the middle..
I couldn't find an exact solution to your problem, but suspect that the issue has to do with how the in carriage is calibrated. HP.com published a web page for this product that shows how to perform a series of diagnostic tests that may lead to a solution:
Streaks or Lines on the Printed Page
Although you don't mention a problem with copying as such, this next web page seemed related enough for me to include it:
White Lines Through Copies
Hope this helps you track down and solve the problem. Good luck.
Oct 09, 2008 | HP Officejet 5610 All-In-One InkJet...
Drum has 13% life left; white paper w streak in middle when you copy
Try taking out the cartidge and given it a light shake. If the white streak moves or changes then you are out of toner.
As for sending faxes, do you get an error message an any kind? Does it try to dial?
Jan 11, 2008 | Brother MFC 8500 All-In-One Laser Printer
Konica Minolta Magicolor 4690MF Multifunction Laser Printer Logo
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
