try taking out and reseating the ram sticks - if that doesn't work there is probably a motherboard fault.
you could also try asking on fujitsu siemens forums
take out the battery, and try again, if the problem is o.k the battery is bad replace. And test the adapter for to see is working good use THE VOM for test the adapter and replace it. However make this test take out the batteries, and adapter, and HOLD the power button by 30 seconds to drain the ECM, and try again. God bless you
please check if moisture level in the place were pc was left wasn't too high for it to operate. then please check are memo banks not loose, baisically just remove them, swap spaces and reinsert to another slot.
some cases fault is just loose memory.
Id try this option 1st : Computer Cleaning Information
We did not find any results for Fujitsu > AMILO D-8820 PC Notebook need factory setting down load or cd.
Other searches you may want to try:
One of theses site will have a down load for your computer factory setting or also could find a cd factory settings for your computer.
If it's only 10 months old it is still within the manufacturers warranty, so do not touch or alter anything to do with the charger or battery, as even though the battery is seeming to be the fault, it is normally the motherboard charging point that is faulty or the motherboard not recognising the battery is connected.
