I have a Budweiser speaker tower. Power on and plug in ipod and plays for about 5seconds. Turn power off and again you can hear music for about 5 seconds. What is wrong, can it be fixed and is it worth the trouble?
  • 13433 Answers
SOURCE: 80 gig ipod won't play music?
Start with these five simple solutions: Reset, retry, restart, reinstall, or restore
http://www.apple.com/support/ipod/five_rs/
If that all that didnt work, then i suggest you contact apple or your dealer for more assistance or repairs.
If you need more asistance, let me know. Good luck.
Posted on Mar 23, 2008
SOURCE: What does the little electrical bolt symbol mean?
this is obviously a power or connectivity issue, check that the device ( your ipod ) is correctly seated into the logitech speaker system, and check the power cables are connected according to the manual which came with the logitech speaker system.
question u may ask yourself? - does the ipod work as it should on its own? (without non-apple devices/components attached to it) - if it doesnt - take to an apple store or call or seek apple support.
it sounds like your ipod is low on power from source.
i hope this directs you in the right direction, party on!
Posted on Dec 01, 2008
  • 10 Answers
SOURCE: Computer Won't Recognize
Hi. Maybe your computer doesn't recognise your iPod, because it doesn't have the driver installed. Your iPod Shuffle looks like one of the newer types, which are smaller and lighter than the previous version. Try re-installing the driver from the Apple website, but make sure it's the correct one, or you might damage it.
Posted on Jan 04, 2009
mneilsen2084
  • 342 Answers
SOURCE: frozen ipod
Here you go :) Please rate me on wether or not this article resolves your issue
Last Modified: January 28, 2009 Article: HT1320 Old Article: 61705 Summary Learn how to reset or restart iPod following a freeze.
Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.) Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step. Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
If you are still unable to reset your iPod, use only one finger from one hand to press the Center (Select) button, and one finger from the other hand to press the Menu button.
When you reset iPod all your music and files are saved, but some customized settings may be lost. Date and time are preserved (unless the iPod reset itself because it had no power and then was reconnected to power). Other customized settings, such as Bookmarks, On-The-Go Playlists, Shuffle, Backlight timer, and so forth are preserved from the last time the hard drive turned on.
Posted on May 06, 2009
jan mczeal
  • 632 Answers
SOURCE: Outside speakers won't turn off when I put my headset in.
There is a switch inside the iPod Nano headset female jack that is deactivated by headset the male jack when it is plugged in. The switch deactivates the outside speakers. In your case, the switch is not deactivated so you hear sound from both. Three things may cause the problem that you need to check.
  1. You are using a not compatible headset. Make sure headset used is compatible with the unit.
  2. The headset is not properly inserted. Insert the headset firmly and make sure it sit firmly in.
  3. The switch inside the unit is defective. It may be stuck or broken. Disassemble the unit to check the switch. Insert the headset and make a visual check if it hits the said switch and deactivates it. You may need the help of a person with know-how in electronics.
Posted on Oct 30, 2009
Speakers wont come on
Lets start with the basics.
1. Make sure the power cord to the computer speakers are plugged in. Check at the wall and make sure the power cord is connect to the back of the speaker. If there is a power button make sure it is pressed in the on position. Make sure the volume level is turned up.
2. Check the computer and make sure the sound is not on mute. Turn the volume level up from the computer settings.
3. Try playing some music. If you hear sound you are good to go.
4. If you are not able to hear anything than continue. I would suggest plugging your speakers into you cell phone. Try playing some music from your cell phone.
5. If music plays through the speakers from your cell phone, something is wrong with the computer. If no sound plays with your cell phone then something is wrong with the speakers.
6. If worse comes to worse bring your computer into a computer store. Tell the salesman you want to buy a new set of speakers. You just want to make sure your computer works with the speakers before you buy them.
7. If all else fails, ask a local tech you trust.
May 25, 2015 | Audio Players & Recorders
Tip
Connecting an iPod Without a Car Stereo
<p>Newer cars often come with adapters to connect an iPod to a car radio, but you can still listen to your favorite lists, if you do not have a car stereo at all. Portable electronics can be used to connect the iPod to speakers, and play it on your car. <br /> <p><br /> <p>1. Purchase an adapter FM radio transmitter for your iPod. It will stream music from your iPod to a low-frequency power, which can be captured by a radio in your car. For best results, use a transmitter with a power adapter 12 volts, you can power adapter car "cigarette lighter" power outlet instead of batteries. <br /> <p><br /> <p>2. Place a "boom box" radio in your car stereo. For purposes of the iPod, the older model, if you have done. All you need is a working radio and decent speakers. Again, it is best if you turn the car to avoid the use of batteries. <br /> <p><br /> <p>3. Set your transmitter to a radio frequency is not used in the stereo field, and tune the same frequency. Adjust the volume on the stereo halfway. <br /> <p><br /> <p>4. Place your iPod within reach of the driver or passenger. When the iPod is playing, the sound will be transmitted to the radio. You can adjust the volume on the iPod itself to control the music changing. When the iPod is off, the radios go silent, although you will hear a static noise. Turn on the radio to get rid of noise, and to save battery when not running the car's power. <br />
on Aug 09, 2011 | Apple iPod touch
My Altec Lansing Inmotion used to charge my Ipod Touch, but since yesterdag (after not using it for 3 weeks) it won't charge my Ipod anymore. The Altec charges itself, but somehow the Ipod doesn't. It is...
That is a tough one. Is your iPod fully seated -- will it play music in the im600? Have you tried a different iPod in the im600 to see if it charges? Does your iPod recharge normally in other players, in a wall charger and your computer? If not, your iPod could possibly need a new battery.
Also: since it was unplugged for 3 weeks, you may just need to run the im600 through a full cycle or two (let the FM radio play until the battery is dead, with no iPod in it), then recharge the im600 for 5 or 6 hours, and THEN mount your iPod into it and see if it charges it. Be sure to unplug/plug-in the adapter into the im600 to ensure it is getting full power from the wall outlet. One last thing: the im600 will only charge the iPod when it is plugged into AC power; it won't charge the iPod while it's running on its own battery power. Good luck!
Jan 16, 2011 | Altec Lansing Inmotion-IM600...
Buzzing when I plug in my ipod
main board or power supply, report to b and w service. known problem
May 15, 2010 | B&W Bowers and Wilkins Zeppelin iPod Music...
Ipod touch music wont play, built in speaker works fine
Restart your ipod by holding the home and power button at the same time, this will restart it and should fix it.
Aug 12, 2009 | Apple iPod touch
Nov 30, 2008 | Dynex 30-Pin Dock Adapter for Apple iPod...
My iPod stopped playing through speakers- but only at work...
Esmurfette
First things First!
1) check on other speakers to see if your iPod work fine
2) check connector for loosing electric connectivity.
3) check with your headphones to see if your iPod play music well.
4) Check, power on the computer spk. you got. or the input that is working right.
Good Luck
Jan 29, 2008 | Apple Logitech Inc MM50 Portable Speakers...
Using my ipod in my car
try the volume setting on your ipod. it may have to be adjusted. go to settings, volume and see where you are on the slider and adjust to the volume you want. ipods come factory set at a predetermined volume level.
Nov 20, 2007 | Apple iPod nano
Sub issues
Would suggest that the power amp in side the speakers havs failed. Try to plug the speakers into a ipod then you can prove if tis the speakers or the Pc.
Jul 25, 2007 | Philips MMS171 Computer Speakers
359 people viewed this question
 Grubhead
Grubhead
