4 YR OLD NETROME CAMERA SYSTEM WILL NOT POWER UP
  • Morris Jones
    Morris Jones Oct 10, 2013
    Could this be a hardrive problem... a noise was made in the computer cabinet and then it would not come back on
    Sergeant:
  • 222 Answers
Check power adapter. These things are prone to failure, particularly if you are approaching their current limitations. It's better to have too many than not enough separate power supply adapters. Splitting the current coming from a single power supply increases the current demand and shortens the life of the adapter.
Posted on Oct 15, 2013
Reset & Software for Netrome Tetragon 4-Channel DVR
Way to go , Jeremy!
Thanks for updating !
Mar 30, 2013 | Meade Home Security
I cant open a port on the blackbox so that i can remote view the cameras i have talked with at&t and they opened the pinhole but blackbox wont allow a passthrough i have 2 blackbox systems one is...
I may have a solution for you. I had the same kind of problems when I upgraded the NS840 Security Blackbox Main Program from 2.0.0 to 3.0.1. From reading in other places I really don't think the 3.0.1 software works at all as far as being able to connect to your system remotely. Something about the engineers sabotaging the software before they went out of business. Luckily I still have the 2.0.0 software that I downloaded last year. So I uninstalled the 3.0.1 and installed the old 2.0.0 and guess what? It works as advertised! You'll need to download and unzip the program installation file here: http://dl.dropbox.com/u/389704/ns840_2.0.0_setup.rar
Aug 19, 2010 | Klein Electronics Netrome Security Black...
My 2 yr old Ixus 70 keps turning itself off.
How old is your battery? Keep in mind rechargeable Li-Ion batteries aren't meant to last more than a couple years, regardless of whether they've been used or not. If yours is as old as your camera, I think you know the answer. The good news is there are many inexpensive generic alternatives available these days. Some are very good, and vice versa. Research the buyer reviews before considering purchasing.
Nov 10, 2009 | Canon PowerShot SD550 / IXUS 750 Digital...
Sony ps 3 won't show initial screen. turns on/grn light is on indicating but nothing happens/ have chgd the rca cables/ chgd tv's/made sure not dusty chgd all inputs/still no resp//any ideas? also, no...
Turn off the PS3. Press the power on button (the system will beep) and hold it down for approximately 5 seconds until you hear a second beep. This will reset the video to the default. You should get a low resolution screen and be able to log on and reset the display to the desired settings.
Aug 23, 2009 | Sony Playstation 3 (PS3) Console
Camera won't power up
You might try cleaning the battery compartment of the camera to make sure that the contacts are not corroded.
Jan 07, 2009 | Canon PowerShot SD600 Digital Camera
Help
dear sir
if it's do veruse time just chande yr USB cable or use different usb port after use the sectuation u face same problem chek virus may be yr system is inficted with Trojen or antispy..
dear sir
u have a drvier cd with phone give u when u perchase that phone and when u connect your phone to pc it's show SamsungD900i found then u give path from yr drvier cd it's depend whitch OS u company give all most OS drvier built in CD u have to install software first which also located in CD then connect yr phone to pc as my sujjaction first install full softwre and drvier after connect yr phone to yr Pc and if u allready connect yr phone just plug out then install software and drviers after finesh installaction restart pc then connect yr Phone to OTHER USB prort. it's help u..:)
Thanks
Please vote
jo_Chinmay
Jun 07, 2008 | Sanyo VPC-C5 Digital Camera
Powers up no video on screen or external monitor seems laptop has endured a strike to the keyboard area, noticed it when i removed it to check for loose connections.
u must be be sure yr system is up n working most times u power it u see the green led that one is bcos its on a power source. now couple yr system back the way it was. power it on make sure the green led is on, then press the caps lock or the fn + num lock key on yr keyborad n see if the caps lock led n num lock led will come up. if it doesnt come up then yr system wont display even with a CRT. now remove yr ram(memory) then replace it back n be sure its seated firmly again power yr system up if it doesnt come up try using a diff ram thats working well n test yr system again. if still not on then try replacing the processor. next tell me what happend so i know.
thank u
hope this helps
May 31, 2008 | Gateway MX3215 Notebook
Start up
yr problem should be from the screen to really confirm if yr laptop is truly on cos u dont just gudge by seing the power led on. to check if yr system is on press the caps lock key or press the fn+num lock key if the indicator led comes on then yr system os on now troubleshoot yr screen by checking the module,connector n fuses. if the caps lock led doesnt come on then yr system just powered on because it saw a power source in that case try to replace the memory(ram) next the processor.
guess this helps
thanks for using fixya
May 26, 2008 | Toshiba Satellite A135-S4427 Notebook
Camera dead
If in the UK, this will be covered by the warranty return it to Kodak for repair,
May 10, 2008 | Panasonic D-Snap SV-AV100 Digital Camera
Camera will not power on
Your camera is still covered by nikon warranty you need to send to them for warranty work.
Sep 02, 2007 | Nikon COOLPIX L3 Digital Camera
Computers & Internet Logo
David Payne
David Payne
