Question about Dryers
Ariston as60v what is the wiring connection for this model, going in down timer.
    New Friend:
I need diagram wire dryer Timer Ariston AS60V
Posted on Dec 05, 2016
  • Cindy Loloan
    Cindy Loloan Dec 05, 2016
How do i set a ariston timer 999599
1) Ariston 999599 is ordinary 24-hour FM1 analog timer from Grasslin.
2) The timer dial rotates around each 24 hours, and pins are pushed outward or inward to set on-off times, and are dependent on wiring and position of override switch located on front tof timer dial.
Copy following link for setting analog timers.
3) After opening links above, add comment and attach photo of your timer.
Feb 18, 2013 | Hardware & Accessories
First time it happen I notice that it started before it should with the timer, so started it without timer and it worked. Now its not going though circle again. Changing the program, and trying again,...
1) you must test the timer is stuck with the contacts, you can try to clean it, tight loose wires, test wires open or break. Or doesnot replace complete TIMER. The timer contacts if you see the diagram is determinant control all operation machine of the diswasher. God bless you
God bless you
Jul 10, 2012 | Hotpoint-Ariston LFT 228A 23 in Builtin...
Ariston dryer model asl65vxs flashing F-12
F-12= communication error
Could be bad connections, wiring faults or a bad board. You can try unplugging the dryer and checking connections,wiring and the board for burnt or bad connections. Hope this helped Tim
Apr 29, 2011 | Hotpoint Ariston ASL65VXS Electric Dryer
I am attempting to replace the belt on my Ariston AS60V dryer The dryer belt is the correct one as compared to the old one but it seems a bit short once I loop it around the drum... Are there any...
if it looks like a big yellow rubber band, it will stretch to fit
being rubber if you heat it up by repeated quick stretching it will be easier to assemble
Oct 25, 2017 | Ariston Technologies AW149NA Washer
I have an intermatic C8865 timer. i want to wire it into an EFM model AF150-1 coal stoker furnace, because the fire goes down to far inbetween actual times heat is called for. also have main switch for...
Intermatic C8865 timer is a 5-hour cycle timer that repeats same cycle each 5 hour period.
This timer has 120Volt clock motor and is 120V timer.
Timer has NO and NC terminals.
NO terminal turns ON when timer turns ON
NC terminals is ON all the time, except when timer turns ON. At this point NC terminal turns OFF.
You have 3 things: 120V timer, 120V honeywell transformer, 120V stoker motor/fan
The transformer needs to be ON at all times.
The stoker motor is going to turn ON when the cycle timer turns ON.
You have 120V cable with black wire, white wire (and bare ground, which connects to green ground screw and to other bare grounds and won't be discussed further)
Black wire is hot
White wire is neutral
Black wire connects to 'Switch common terminal' on timer.
Same wire also connects to black wire on Honeywell transformer.
White wire connects to 'Clock terminal' on timer
Same wire connects to white wire on Honeywell transformer and to white wire on Stoker motor.
So all the white wires are connected together.
Last wire is black wire to stoker motor.
This wire connects to NO terminals on timer.
Here is drawing.
Add a comment any time
Dec 13, 2010 | Intermatic C8865 Timer, 1HR CYCLE TIME, 30...
Our hot water heater has stopped working in our Ariston dishwasher. How do I order a new part?
You need to take the bottom front off the heater, UNPLUG dishwassher first. There will be two wires going to the heater element, Unplug one wire and check the element with a OHM meter to see if the element is bad. If you don't get a reading the element is bad write down the make and model number you can order this part from sears or a local appliance repair parts store.
Feb 16, 2010 | Ariston Technologies L63 Free-Standing...
I have an ariston lsi 45/50 which will not end it's wash cycle.i have checked the salt level,which is fine. Any ideas please?
HI Because the timer controls many operations, a faulty timer can cause many problems. The timer is a complex component, so you shouldn't attempt a do-it-yourself repair. Test the timer with a VOM set to the RX1 scale. To gain access to the timer, remove the front control panel. The timer is directly behind the main timer control knob. Disconnect one of the timer's terminal wires and clip one probe of the VOM to each terminal. If the meter reads zero, the timer is working. If the meter reads higher than zero, the timer is faulty and should be replaced.
If possible, use the same procedure to test the selector and cycle switches. The wiring hookup, however, may be too complicated to figure out on either of these switches. If you aren't sure you can deal with these switches, call a professional service person. Replace a faulty timer -- or a faulty control switch -- with a new one made for the dishwasher.
The timer is connected to several wires that supply power to operate the various functions of the dishwasher. To replace the timer, have a helper hold the new timer next to the old one. Connect the wires of the new timer one by one, removing the old wire and connecting the new, to make sure you connect the wires correctly. The wires may be friction-fit on the terminals. If they are, use long-nosed pliers to remove the wires. Don't pull up on the wires, or you may break the connection between the wires and the clips.
After connecting the wires, set the new timer in position, secure it the way the old one was secured, and replace the control panel and knobs.,,,,,,,,,,,,,,,PLEASE RATE IT..........THANK U
Nov 28, 2008 | Dishwashers
go to
They have couple of diagrams
Aug 13, 2008 | Washing Machines
Dryers Logo
62 people viewed this question
Top Dryers Experts
