Question about HP LaserJet 4350n Printer
52.00 error dear sir i have a problem with my hp laser jet 4350 printer while its printing i am getting error 52.00 error plz some one can give me a sulution thanks with best regaurds gaffar
  • Raj Nag Jun 03, 2012
    change the laser scanner
Change the toner
Posted on Jun 03, 2012
  • Raj Nag Jun 04, 2012
    52.00 is a laser scanner issue, it's need to be change the laser scanner .
On hp laserjet 3035 the error is 52.00
Posted on Jan 06, 2011
  • 48 Answers
Hp says you have a bad scanner unit(laser unit) or DC controller, but first reseat all your connectors on your scanner unit(laser) and DC controller. Your scanner is located under the top cover and the DC controller is located behind the right cover. If the problem still persist replace the scanner first.
Posted on May 25, 2009
Dear sir thanks for your best support i have solve the problem by replacing the laser unit
once again thanks
with best regards
gaffar
from kuwait
Posted on May 26, 2009
Hp laser jet 3005 printer clearing paper path error
I would pull out the paper tray, and clean the underside roller. First try to clean it without moving the clips. Use a cotton cloth or lint free cloth and alcohol. Get as much paper dust off as you can. This might help you out.
Jul 30, 2012 | HP LaserJet 4350 Printer
I am getting Error 49..turn off and turn on error again and again from HP 2605 Color laser jet printer. Plz help.
It's a firmware error.
Do ALL your print jobs give this error. If it is just one job that causes the error, something is corrupted with the software.
If every print job causes the error, it's the printer. Try printing after removing DIMMs from the printer. If you can try plugging the printer into another port on the computer or router.
When all else fails, go to www.hp.com/#support and download the latest firmware and install it.
By all means READ the directions first.
Jan 31, 2011 | HP LaserJet 2605dn Printer
HP Laser jet 4350 dtn printer gets 59.40 error. I
Print Cartridge Motor Error.
Try removing then re-installing the cartridge. If that does not work then you will need to try a different toner cartridge as the toner cartridge is "locked up". These are the most common solutions. If none of these work then you have a cartridge drive problem and will need to contact a service center.
Jan 05, 2010 | HP LaserJet 4350dtn Printer
49,4c02 error to continue turn off then on
I would try clearing your print que as it could be a corrupt print job and disconnecting your network cable and reboot the printer, make sure you have the latest firmware. hope this helps
Nov 24, 2009 | HP LaserJet 4700 Printer
HP Laser Jet 4250/4350 series says its ready then it prints blank page and sends a message 51.20
Try a replacement toner cartridge first.If this fails, then i suspect it's a laser scanner fault. The error denotes beam detect error which is more than likely a laser scanner fault
Oct 12, 2009 | HP Office Equipment & Supplies
Noise in the Laser Jet 1022 Printer
try and check for broken gear- tooth on one of the sides of the machine
May 29, 2009 | HP LaserJet 1022 Printer
Double printing on single jobs.
You have software setting problem Check and double check your print dialogue box
Apr 21, 2009 | HP LaserJet 4350 Printer
Printing error
right side of the machine rear panel comes off, open metal door, there are your memory dimm slots. good luck!
Jun 12, 2008 | HP LaserJet 4350dtn Printer
Laser jet 5 will not print from my laptop. was fine until yesterday. now get error message. did all tests. printer printed out test sheet. computer printed out test sheet. just cannot print a document.
Looks like this is second printer installed on ur lappy... if that is so open Printers and Faxes and make ur laser jet 5 as default printer. Can give more accurate solution if u'll mention what error msg u got...
Plz Rate Me... Thanks.
May 13, 2008 | Office Equipment & Supplies
Printer problem
please reinstall your printer driver.and post your findings
Apr 07, 2008 | HP LaserJet 1020 Printer
HP LaserJet 4350n Printer Logo
667 people viewed this question
Seeker5211
Seeker5211
