Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
My craftsman mower wont start. It just clicks when I turn the key. Has a new battery so that's not the problem
    Sergeant:
  • 416 Answers
Move blade engage lever back and forth
it may not be returning all the way
Posted on Oct 10, 2013
4 Suggested Answers
  • 61 Answers
SOURCE: The new battery on my Craftsman LT1000 18hp riding mower will not charge. Anyone have any ideas?
ck for blown fuse, ck for broken wire.
Posted on Sep 06, 2009
  • 13 Answers
SOURCE: nothing happens when you turn on the lawn mower
Check your seat, drive safety switches. Can you turn the engine with jumper cables attached to the starter? It won't start, but should turn over, one of your safety switches is not working.
Posted on Apr 16, 2010
  • 150 Answers
SOURCE: Hello - I have craftsman
With the key in the run position, using a jumper cable, jump from the positive post on battery to terminal on starter motor. If it runs you have a solenoid or ignition switch problem. (assuming all electrical connections are clean). If it doesn't crank the battery is the culprit.
Posted on Oct 15, 2010
Testimonial: "thank you!"
My craftsman riding mower wont start when i turn the key all i hear is a click ,it has a new starter
Terry,
Sounds as if your battery is drained. Or it also couldbe a the solenoid. You can use a multimeter to test the battery to see if it has the 12v needed to start the engine, also you can use it to test the solenoidto make sure it's relaying the voltage.
If u have a set of jumper cables, u can test by simply hooking them up to another battery source, as in a car battery, and then attach to the mower battery, won't hurt anything..
If you KNOW the starter is good, then it can only be these 2 other things that I have mentioned. Hopefully the starter is not defective...
Oct 08, 2015 | Craftsman Garden
Why won't my craftsman mower turn over/ start ?
Check your battery. The clicking you hear is likely the relay not getting enough voltage to close and latch and is just toggling.
IT IS NOT RECOMMENDED THAT YOU JUMP START YOUR MOWER WITH YOUR CAR AS YOUR CAR BATTERY IS LIKELY A HIGHER VOLTAGE AND COULD CAUSE YOUR MOWER BATTERY TO FAIL. CATASTROPHICALLY.
Jul 23, 2014 | Craftsman Garden
Why Craftsman riding mower wont turn over & only makes click sound when turn key on??
1.try jumping the battery with your car battery. I have had same issue in the past with a brand new battery.
2. Try spraying starter fluid into the carb while cranking. If it starts or at least tries to start (assuming cranking is fixed), you have a fuel problem. Again, when I first tried to fire my Used mower, had to use starter fluid to get it to start the first time, but never since.
Jun 19, 2014 | Craftsman Garden
I have a craftsman with a kohler magnum 18hp. If i put a battery charger on my battery it dont charge i can turn the key and it wont roll over. If i jump my lawn mower and it running i can turn the key all...
Hi, if your battery wont charge you will need to replace it and when you do you need to check that the mower is charging by checking the battery voltage with a multimeter while the mower is running. It should be around 14 volts. Regards Phil.
Sep 06, 2012 | Craftsman Garden
Riding mower wont start
check the safety switch on the clutch pedal
May 19, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman riding mower clicking noise - wont start
RIDING MOWERE JUST CLICKS AND WON'T START HOWEVER IT WAS RUNNING FIND JUST 5 MIN. BEFORE I TURNED OFF.
May 22, 2010 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Craftsman zero turn model# 107.27774
If you are jumping the solenoid and it cranks but wont start leave the key in the on position and give it a try. Try replacing the solenoid and the wires conecting it to the battery.
Apr 24, 2009 | Craftsman 21 HP 42 in. Zero Turn Tractor...
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
143 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
