Question about Miele CVA615 Espresso Machine
Problem with Miele CVA615 Espresso Machine Water
Problem with Miele CVA615 Espresso Machine Water coming out of the hot water dispenser all the time. They made coffee every day with no problems.. The also used the steamer with no problems.. Last week I decided to try the hot water function with dispensed hot water fine. The next time They made coffee 1/2 of the water came out as coffee and 1/2 came out through the hot water spout. When we try to use the steamer water comes out of the hot water spout also and the steam doesn't work. Although it seems to be trying. Don't know where to start any help would be appreciated! thanks
    Problem Solver:
  • 15 Answers
Frankly, there are things wrong that are beyond your scope, mainly because of the domino effect in small espresso machines no matter who makes them. There are multiple thermostats instead of a pressurestat, and on and on trying to replicate what a commercial machine does. In a machine like yours, the slightest failure of a gasket throws off everything. There is better containment of problems in commercial machines, but that too depends on what fails first.
My advice, if you are a home user, would be to get a manual pump machine , such as a Pavoni, (which I have lost respect for since they employed plastic pistons,) or if for a small cafe or bar, something like a semi-automatic job plumbed through a filter. Either way, in all honesty and that has cost me dearly, I warn you about this coffee business, because it is a science and an art.
It is not easy to make a good cup of coffee or espresso, especially.
Posted on Dec 25, 2013
2 Suggested Answers
Master_Tech
  • 770 Answers
SOURCE: Water coming out of the hot water dispenser all the time!
Hello>>To explain the repair of the valve via this chat box is too much post your emauil and I will send you the service manual on the unit it will take you step by step thru it.
Posted on Aug 20, 2008
Water is not dispensing
does the machine ask you to fill water? If it does check to see if the float is secure and still inside of the water dispenser. It's a small compartment inside the water dispenser that houses a float with a cap to seal it in.
Oct 03, 2013 | Miele CVA615 Espresso Machine
I have a miele cva620 ind it displays expel air.. what shall i do? how can i do it?
FIll the water tank.
Turn the program selector to "ON with light" and place containers below the hot water dispenser and the steam nozzle.
Press the hot water button, turn the steam selector counterclockwise and let water run out until it streams steadily.
Press the hot water button again.
Turn the steam selector to "o" to shut off the water.
That should solve the problem
Jun 25, 2009 | Miele CVA615 Espresso Machine
No coffee dispensed and no water comes out when Rinse selected
1st use cleaning tablets used for brew unit. and go on cleaning procedur.
2-the sound you hear i think is only motor of
grinding
thank you
Mar 24, 2009 | Miele CVA615 Espresso Machine
Miele cva615 how to make coffee stronger less water
open the door and adjust slide for more grounds, also program prebrewing so it adds a little water to the ground to get them going before the rest of the water is pushed though.
Feb 28, 2009 | Miele CVA615 Espresso Machine
I have a Miele CVA615 and there is a message stating "rinse machine" I do not know how to clear this. Help!
turn on steam. some water should come out of hot side. when it stops, close steam and hit enter. if this doen't work, empty water container and tri again. it should say finished.
Nov 12, 2008 | Miele CVA615 Espresso Machine
Steam but no hot water
go in the programe mode and turn on the hot water on in the options
Aug 16, 2008 | Miele CVA615 Espresso Machine
Miele CVA615 remove coffee bean dispenser?
their is a plastic screw below the bean dispenser .once unscrewed you will remove the dispenser
Jul 13, 2008 | Miele CVA615 Espresso Machine
Clogged Dispensers
Sounds like a burst water line inside, if you made sure there is water available, and you hear it pumping. Either that or a solenoid valve is not activating. Must remove unit and pull the cover to investigate.
Jan 10, 2008 | Miele CVA615 Espresso Machine
Miele CVA615 Espresso Machine Logo
156 people viewed this question
Top Miele Coffee Makers & Espresso Machines Experts
just-ice
Michael Galve
Michael Galve
Colin Stickland
Colin Stickland
Are you a Miele Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
