Question about Canon Office Equipment & Supplies
I have xerox machine canon ir 2420l photo-gram problem, how to fix this problem
redzventures
  • 149 Answers
SOURCE: I have an IR-3300 Model xerox machine. It was
The two problems may not be related. Adding toner should not under most circumstances cause copies to become light, unless the toner you are using is of a poor quality - I hope it is a Canon cartridge or quality generic. It sounds as though your fixing film or drum unit may need replacing, or perhaps you need to perform a install procedure. As the 'install - toner - start' option is free, try it first:
First press the head key and then the number '2' and '8' keys at the same time then press the head key again. This will take you into service mode - select 'copier' then 'install' then 'toner' then 'start'. This will run throught a cycle that takes a little while, I think about 599 seconds (sorry for been so accurate but unhelpful but that's what I remember from the display - never converted into minutes but you're welcome to).
But if you are having blurry or even dirty or light copies it may be the fixing film. When the copies are printed, immediately check if you can rub off the toner at all by rubbing the print with your fingers - if so this indicates that the fixing unit is not hot enough or there is not enough pressure - check that the fuser is in properly and that the jam release lever is not engaged.
Lastly, it could be your drum unit that is faulty or worn. Totest this you will need to try and stop the machine in the middle of printing before it reaches the fuser - open the front cover and latch down the transport bed with the green handle - remove the paper gently so as not to disturb the ink in any way and observe the image quality - if it is displaying the exact same symptoms then it is not your fuser and is probably the drum unit or dodgy toner - most likely the drum. However, if the image is fine, then it most definetely is your fuser film (and or perhaps the cleaning roller that cleans the film).
Good luck
Posted on Jul 31, 2009
SOURCE: Describe your canon ir 400 xerox machine error
i have duplexing problem
Posted on Jan 11, 2010
SOURCE: canon ir 3300 xerox machine display board not working
dispaly and pad is not working who to open it tell me the codes
Posted on May 26, 2009
SOURCE: I HAVE A CANON IR
error code 00001-002
Posted on Jan 06, 2011
  • 159 Answers
SOURCE: CAnon xerox Machine IR 2318
Hello, unfortunately it appears you need to replace the fuser film (probably the upper roll). I wish I had better news. Good luck!!
Posted on Feb 28, 2011
Sir you tell me how can I reset canon ir 2002n error code e002-0000
Hello . to clear that error you need to replace the fixing heater unit
Apr 25, 2016 | Canon Office Equipment & Supplies
E000007 ir 2420l
problem with fixing assy
Feb 06, 2014 | Canon imageRUNNER 2200
E000808 0000
Please What can the solve of Problem Restart the machine if problem persists call service rep. error message : E000808-0000 model canon ir 2420L
Nov 30, 2013 | Computers & Internet
Error code e000007 canon 2420
MY CANON IR 2420 WITH ERROR 000007-0000 HOW CAN ISOLVE THIS PROBLEM
Dec 06, 2012 | Canon Office Equipment & Supplies
In my canon xerox imagerunner 2420L displays error massege
i have canon image runner 2420l copier and it show the error message restart the machine if problem persists, call service rep. **E000007-0000 how can i solve the problem/ and fix the machine
Nov 04, 2012 | Office Equipment & Supplies
Not getting dry prints using canon 3300 xerox machine
1) is it canon ir 3300 machine?
2) if it is what does it mean NOT DRY completely?
#) My ques is that you need to eplace fixing film
Jan 30, 2010 | Canon imageRUNNER 2270 Copier
Canon ir 3300 xerox machine display board not working
Feb 13, 2009 | Canon Office Equipment & Supplies
52 people viewed this question
old marine
old marine
