Question about Toshiba 43H70 43" Rear Projection Television
52HMX95 No Color - Toshiba 43H70 43" Rear Projection Television
  • Bond Welch
    Bond Welch Oct 10, 2013
    Tried new hdmi no success picture but no color
I have no sound output what so ever. Not even in the ewxternal hook ups. Toshiba 52HMX95 tv
Disconnect the DVD and see whether it is working. Also see whether any jack is plugeed in the headphone socket.
Jun 29, 2014 | Toshiba 52HMX94 52" Rear Projection HDTV
Toshiba 52hmx95 dlp tv. took back cover off. the fan cooling the lamp,makes a loud humming noise.read that fan is hard to get.(this is a three wire.only finding two wire.)is there a three wire fan i can...
maxie99,
Fan is available at https://www.encompassparts.com/webwiz/wwiz.asp?wwizmstr=WEB.SEE&partnumber=6475656&smodel=52HM95 for about $80.00. Replacement should be as simple as unplugging the fan cord and removing a couple screws to remove. Do the work with the unit unplugged from the wall. Reverse the procedure to install the new unit.
Thanks for using FixYa and the great rating.
hardrocko
Oct 19, 2010 | Toshiba 52HM95 52" HDTV Projection...
What are the blinking light codes on a toshiba dlp meAn?
90% of the time your lamp needs replacing.( DLP sets only )
Jun 18, 2009 | Toshiba Televison & Video
Constant Buzzing sound when TV is on
The wiring may have fallen back onto the fan or that may never have been the problem at all. A common problem for DLP TVs is the color wheel motor. It will hum and change pitch especially as you power the TV on or off. Its an expensive repair in this TV because Toshiba does not sell it independently from the larger, more expensive light engine assembly. Don't allow this to fall out of warranty! Call the extended warranty company and tell them that the repair was not effective and that you want this resolved promptly before the warranty expires.
michtech
Jan 25, 2009 | Toshiba 62HM95 62" HDTV
Toshiba 52HMX95 DLP has weird gray think line
DLP TVs work projecting light throught a tube covered with mirrors, called the light tunnel.
The gray shadow it is something in the middle of the light tunnel, probably a mirror that has gone out of place when you moved the TV.
Sep 01, 2008 | Toshiba 52HMX94 52" Rear Projection HDTV
Toshiba 52hmx95 dlp
Take off the back, and take out screws holding in the light engine. Look at new light engine, and the old one you will have to take off a couple of things that your new engine wont come with. It is very easy to change. Any questions please ask.
Feb 14, 2008 | Televison & Video
Toshiba DLP fan noise (52hmx95)
i constantly hear complaints about fan noise in dlptvs if you sit in front of your computer you will hear the same noise even in the next room there is no solution to the fan noise problem this product has a huge cage fan and a second and third three inch fans in it.... more than the samsung product it can be noticeable if the tv is on hard surfaces ie wood floors ,inthe corner, glass top etc the vents on the back of the tv allow for proper cooling of the lamp at shutoff so it doesnt shatter the tube its kinda like annealing glass its designed to extend the life of the lamp .... which im sure youve priced call toshiba and tell them your lamp is bad right now and get a new one for an emergency ( warranty if you can do it ) they are also improved this product is known to have short bulb life sometimes the zinging noise you hear is indicative of a bad color wheel in the light engine which would require replacement ( not cheap) toshiba will not piece out the color wheel assembly individually
Nov 30, 2006 | Toshiba 62HM95 62" HDTV
Open Questions:
See all Toshiba 43H70 43" Rear Projection Television Questions
Toshiba 43H70 43" Rear Projection Television Logo
19 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
