Question about Metra Antennaworks 44-UA20
I need a installation guide for 44 ua20 antenna
Need to replace a roof antenna for a Honda crv
you will probably need to remove the headliner from the vehicle and unbolt the base from inside. also the cable.
Dec 31, 2011 | Metra 44-UA42 Amplified Roof Mount Antenna
Trying to install 44-PW530 on 1996 Toyota Tacoma. It had a power antenna from the factory that the mast had broken. Before installing I wanted to double check that the new unit worked so I attached blue...
The blue lead does not go to negative. It needs to go to the power antenna wire from your radio. If you have an aftermarket radio, then this would be a solid blue wire from the aftermarket radio harness, that should be connected to the matching blue wire in your other store bought Toyota harness that it mates to. Then this plugs into the OEM harness that is part of your truck wiring. You can confirm that the blue wire at your power antenna is the one that triggers the motor by briefly touching it to the power wire (red) and watching your antenna begin to rise up. Remove the blue wire from power, and it should descend.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/reginald_bec291de192ca44f
Jul 03, 2017 | Metra Antennaworks 44-PW530
Wiring diagram for instalation
install what? but crutchfied can give you free step by step diagrams, also check out modified-life-logo.gif.com
May 02, 2010 | Car Audio & Video
How to install ink cartridges #4 & 5 for 2600
Here's the User's Guide (Lexmark X2600, X2630, X2650). This should guide you on how to install/replace cartridges on your Lexmark X2600 printer. Go to Maintaining the Printer, Page 44, to view the instructions. Hope this helps. If you need more assistance, leave a comment and I'll get back to it. Thanks.
Apr 22, 2010 | Lexmark X2600 InkJet Printer
Aquatronics Radio MS1550G 4X40W
I have an Aquatronics MS1550G radio on my 2006 Suntracker. The radio speakers have sound, but the sound is barely audible. I have used the reset button with no success. Is there a quick fix to this problems?
Aug 08, 2009 | Aquatronics Car Audio & Video
Need Replacement Mast for Metra 44-PW22 Power Antenna
the online site for metra is www.metraonline.com The part number for the replacement mast is 44-PW22. Hope this site will help you find a dealer in your area. If you need more help, please ask.
May 18, 2009 | Metra Antennaworks 44-PW64
No MIDI Interface on Laptop
I would expect that to work fine. I have used several USB to Midi adapters with good results.
Dec 17, 2008 | Edirol UA20 USB Audio/MIDI Interface...
I have purchased a Garmine 4008 on ebay only to discover the GPS unit wires were cut. Which wires do i need to connect back up.
There are quite a few variables involved depending on what antenna and accessories you have, and where the antenna is mounted. Your best bet would be to download the installation guide at this link:
4008 installation guide
Jul 22, 2008 | GPS
Car Audio & Video Logo
26 people viewed this question
Top Metra Car Audio & Video Experts
xxxxxx xxx
Are you a Metra Car Audio and Video Expert? Answer questions, earn points and help others
