The ptlot ligth go out when i turn loos the switch
  • 2,251 Answers
What kind of machine,is it a dryer?if so what kind and model number,if it's a whirlpool and it has even heat most likely it's the even heat board,if it's g.e. you have a bad belt switch.
Posted on Oct 10, 2013
How do I fix the brake ligths?
Did you check to see if there is a fuse on the brake lights circuit?
If you changed the lamps and the brake switch it is obvious that they are not being energized.
Aug 31, 2015 | Cars & Trucks
Panel ligth and parking ligths is not turn on.
I have the same problem with my 1998 Grand Cherokee Laredo. I feel it has something to do with the slider switch. Pressing down on the switch while sliding it up and down and setting it at a desired level of intensity usually works for me.
Jan 03, 2014 | 1996 Jeep Grand Cherokee
97 cad turn signal lift side and brake not working **** right is working
The problem could be in one fuse, bad ligth bulb, bad combination switch wich is the turn signal lever siwtch, or the combination of all this. Is the front left turn signal working, in order to find out if the turn signal switch is working check for power at the the cable in the corredpondent connector that way you eliminate the posibilty of the turn signal sitch if you have power at the connector also do the same at the stop ligth if there is no power you have problaby bad fuse, hope this help tou out.
May 13, 2012 | Cars & Trucks
Replace ligth swicth dimmer swicth brakes and singal litghs work no head ligths
Sounds like your turn signal switch is bad!! Multi-functioning switch it controls your head lights two? Unless you have a push button switch!
Sep 04, 2011 | Chevrolet Chevy Cars & Trucks
I just bought two flood lamps to fit to the bumper of my 95 jeep wrangler, how would i wire them to a toggle switch?
  1. 2-wires on each fog ligth
  2. toggle switch 2-hook up
  3. okay run hot wire from battery to one side of toggle
  4. on fog ligths one wire migth be white or black
  5. take one of the wire on fog ligth (white)&other fog ligth (white)wire
  6. take a wire hook both white wire from both ligths an hook to this wire an run it to the other side of toggle
  7. black wire on ligths hook them to ground
  8. after you hook the ligths up an they work it best to put a fuse connector between one of the wires on toggle
Dec 06, 2010 | Jeep Wrangler Cars & Trucks
My brake ligths and blinkers does not turn on. why? but, if i turn on my ligths , yes the rear ligths they are on just the brake and blinkers not
Defective Hazard Switch or Turn Signal Switch will most generally cause this problem on GM vehicles!
Mar 08, 2010 | 1999 GMC Yukon
No turn ligth and no stops ligt
gmc had a recall for that problem. It is the switch under the break pedel was installed wrong during manufacturing. Took mine in and they replaced switch.
Aug 09, 2009 | 1994 GMC Sierra
My nec vt46 does not want to turn on
You need to check the manual. It will tell you at the rear what the different lights mean.
Apr 13, 2009 | NEC VT460 Multimedia Projector
Cluster ligths not working
the switch has gone out and needs to be replaced.
Dec 24, 2008 | 1993 Nissan Pathfinder
Heating & Cooling Logo
18 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
