Question about Panasonic KX-TG4500 Phone
When I make a call from the base unit the person receiving the call has a hard time hearing me
2 Suggested Answers
caroldon
  • 17130 Answers
SOURCE: My panasonic KX-TG5000 phone headsets cannot make or recieve outgoing calls and the intercom function is gargly.
You need to reset the menu once again as it is possible that the phone had hung up as there was LINE PROBLEMS . Once this was reset the CLIP facility came back. So if you can once again remove power battery and keep aside to reset , then start all over to set up the base and slave units to MESH , the intercom and line facility must work.
You can remove the battery from the slave remote units to reset.
Posted on Oct 25, 2011
Oct 20, 2011 | Panasonic KX-TG4500 Phone
When i make or receive a call ,i can hear the person,but that person cannot hardly hear me
make sure that you have not covered the mic or pressed the mute button
May 12, 2011 | Lands Phones
My phone rings but it will not answer i can't hear the person on the other end
If the other person can hear you, then the problem is with the earpiece on the phone. The phone rings using another speaker on the base unit. Swap the mic/earpiece handset unit with another phone and use with existing base unit, to narrow down the fault.
Jan 15, 2011 | Emerson EMSEM2646WH Phone
It tells me that I cannot re record greeting - it says unable to fix now
what this simply is that your panasonic phone has been over power by power supply what you are to do first of all put off the phone for some time then put it on again after it most has relax it self then apply the below instruction to reprogram the greeting message on your panasonic phone again
Several Panasonic telephones come with a built-in answering machines. You can leave the telephone as is and let your callers hear a message pre-recorded on the device by Panasonic, or you can personalize your phone with your own greeting.
Instructions below.
  1. Press "Getting Rec" on the base unit.
  2. Press "Getting Rec" again within 10 seconds after you hear the pre-recorded message, "To record greeting, press record again."
  3. Lean in so you are within eight inches of the microphone on the unit, and wait for the long beep.
  4. Record a personal greeting lasting up to two minutes after you hear the beep.
  5. Press "Rec Greeting" or "Stop" after you have finished recording your greeting.
  6. Record your greeting again if the base unit displays an "E" and beeps six times in a row.
  7. Press "Greeting Check" to hear the greeting you recorded.
Hope this help?
Thank you and thanks for using fixya.
Nov 23, 2010 | Toshiba DKT-2010 Corded Phone
Problem for Plantronics CS50 Wireless Headset - I can hear the person on the other end when the configuration dial is set to 1,2 or 3. But th other person cannot hear me. When I set the dial to 4, others...
The following is a cut from Plantronics web site. I hope it helps, It's just possible you have missed a setting, such as the mute switch.
The CS50 has both transmit (how you are heard) and Receive (how you hear) controls on the unit itself.
The Master Transmit controls are the ABCD switch settings on the bottom of the base. A is the lowest and D is the highest setting. You can fine tune this setting with the Plus (+) and minus (-) buttons on the back of the base that are above and below the picture of the microphone.
The Master Receive setting is on the back of the base (below the picture of the microphone) there is a 1234 switch 1 being the highest setting and 4 being the lowest setting. You can fine tune this setting by using the volume control on the headset itself. This is the rocker volume wheel on the back of the headset (opposite of the microphone).
The headset volume control also doubles as a mute switch if you press it in, instead of rocking it back and forth.
There are also configuration settings on the left hand side of the base. This is a dark grey dial with a 1234 on it. There are notches to the right of this dial. Whatever number is lined up with the notches it what setting you are on.
This needs to be set to the clearest setting.
There is a silver button on the headset itself which is your “Talk button”. This is what you press to use the headset and or transfer the call from the headset back to the hand receiver.
There is also a switch on the right hand side of the base which is your the IntelliStand feature.
When the CS50 is used in conjunction with the HL10 handset lifer you can enable the IntelliStand feature.
The IntelliStand feature senses when the headset has been removed or placed into the CS50 base unit which automatically activates the Handset Lifter and enabling headset/handset mode to answer or end the call.
There is a switch towards the bottom on the right side of the base unit that will switch the IntelliStand feature On and Off.
Apr 11, 2010 | Plantronics PL-CS50 Professional Headset
I can here them but they can't hear me
I have the TRU9585 with 4 hansets. We used them for about 3 months, worked great. One day, I can hear caller, caller can't hear me. Problem was a defective transistor in base unit. Part number C2120, small 3 legged device near bottom of unit. Replaced it with generic NPN transistor from Radio Shack. Caution...should only attempt repair if you have worked on electronics before and can solder...Also C2120 configuration is not standard, configured emitter-collector-base instead of emitter-base-collector...Good luck!!!
Jun 05, 2008 | Uniden 5.8GHz Expandable Cordless Phone...
GN Netcom GN 9120 - can't hear
Hi There, I had the same problem with a headset one of our call centre reps were using. It's usually due to some one fiddling with the button. I got it working by removing the battery from the headset then resinked the headset to the base unit. Hope it works for you
Jan 30, 2008 | GN Netcom GN 9120 Professional Headset
Receiver seems not working
I'm pretty well sold that the technical support at HP is completely worthless. They have some tree they look at for answers but have no actual technical ability, making them about as useful as an extra **** on your elbow
Nov 17, 2007 | HP Xb3000 Notebook Expansion Base And...
Panasonic KX-TG4500 Phone Logo
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
