Question about Samsung it xe700t1a-a05us
New pass word entered by my child now I have no access to the start screen
How do I change country settings?
Amazon has by far the best help section of any tablet manufacturer on the planet. See number 5.
  1. Turn on the device. Press and hold the power button at the top of the device for two seconds, or until the screen turns on.
  2. Select your device language, and then tap Continue.
  3. Connect to a Wi-Fi network, if possible. If you're not able to connect to a Wi-Fi network, tap Complete Setup Later. However, you will not be able to set up your child's profile or add content to their profile until you are connected to Wi-Fi.
  4. Register your Fire HD Kids Edition tablet to your Amazon account. If you don't have an Amazon account, you can create one now. Note: The Amazon account you use to set up the Kids Edition tablet is used to set daily time limits or purchase additional books, videos, and apps to add to your child's library. You should use the Amazon account that you use to purchase physical or digital products on Amazon. You do not need to create an Amazon account for your child.
  5. Select your time zone. The time zone is how you set the time and date for your Fire tablet.
  6. Select either Setup your child's account to create a profile now, or Setup later to create a profile at a later time.
  7. Add a child profile. Select an image for your child's profile, and then enter your child's name, gender, and birthday. Then tap Continue.
  8. Share content with your child. If you have purchased digital content, tap the check box next to each title you want to add to your child's profile, and then tap Continue. Tip: Tap For Kids to view recommended family-friendly titles in your library, or tap a content library (for example, Books) to view and select individual titles on your own.
  9. Set a lock screen password or PIN. To prevent your child from accessing device settings, web browsing, social media, in-app purchases, and more, you must set up a lock screen password for your profile.
  10. Launch FreeTime. After your child's profile has been created and has content added to it, you can launch your child's profile and they can start using it to make progress towards their educational goals. Alternatively, tap Set Daily Goals & Time Limits to choose different educational goals or time limits for when or for how long your child can use their Fire HD Kids Edition tablet. Tip: If more than one child will share the Kids Edition Tablet, you can create a lock screen PIN for each of their profiles so that each child only accesses content that is appropriate for them.
Set Up Your Fire HD Kids Edition Tablet
Mar 18, 2016 | Amazon Fire HD Kids Edition - 7" - 8GB
LF.com ParentAccount instead
How do I obtain a parent code for my child's leap pad ultra? My child started the ultra before I could set up anything.
Dec 29, 2013 | LeapFrog LeapPad2 Explorer - Green
Zenith Z42PT320. I set parental lock code for my son and forgot password. How do I reset or retrieve?
Zenith TV unlock [Child lock]
Tune the television to a channel blocked by a child lock. The words "Enter Lock Code" will appear on the screen with four dashes underneath
Press the numbers on the remote control to enter the child lock pass code to unlock your Zenith television. When the code is entered correctly, the blocked channel becomes visible. The words "Enter Lock Code" remain on the screen if the password is not correct
Enter "0000" if you did not change the password on the television prior to enabling the child lock feature. This number is the default pass code for the child lock.
Push "7777" if you changed the pass code for the television but no longer remember the code. This number allows you to bypass the child lock and watch the programming.
Key lock
Press the "Menu" button on the remote control to access the "Main Menu" screen on the television.
Scroll to "Special" using the up or down arrow buttons and press the right arrow button to access the "Special" sub-menu.
Push the up or down arrow button to highlight "Key Lock" and then press the right arrow button.
Press the up or down arrow button to change "Key Lock" to "No" and then press the "Menu" button to save the setting.
Wish to get more? http://electrohelponline.blogspot.com/
Jun 07, 2013 | Televison & Video
Need to reset the power on password on a compaq presario cq62 can't get pass the first screen. as soon as i start up the computer get the screen enter password.
These WEB sites can help you remove the Power On and BIOS password.
PC BIOS toolkit is a password removal/decrypt and BIOS settings modification/backup/restore.
http://www.syschat.com/download120.html&act=down
CMOSPwd - CMOS password recovery tools
http://majorgeeks.com/CmosPwd_d239.html
Using a computer with Internet access, download the files from these WEB sites and create a bootable CD disc to run them.
Jan 27, 2013 | Compaq Presario CQ56-115DX Laptop
MY RCA TTE 20V500T TELEVISION IS STUCK IN CHILD SAFETY AND TURNED OFF W/NO REMOTE TO ACCESS THE MENU
Without remote its not possible to disable child lock. If it possible to arrange the remote then you can do the following to override the lock.
1.Press VOL+ on the remote and CHANNEL + on the
front of the TV at the same time. Enter New Pwd.
will appear on the screen. (You must be in the Enter
password screen when attempting this).
2.Press the number buttons to enter a four-digit code.
The code will appear on the screen as you enter it.
3.Press OK to save the code.
4.Press MENU repeatedly to exit the menu or the menu
will automatically disappear within a few seconds if
no buttons are pressed on the remote control
Dec 10, 2012 | RCA 20V500T 20" TV
I forgot my family passcode and the answer to the secret question on my xbox 360 what should i do?
Hi aureliogovea
Please everyone that comes across my info take a few seconds of your time to rate my solution which you can select at the bottom of my answer Was this solution helpful? YES or NO :)... As i have taken time to answer your question the best i can Thank You......
If children use your Xbox console, you can set a pass code to control access to features and options. Because Family Settings exist for both the console and for Xbox LIVE accounts, you can set pass codes for both.
Here you can learn how to:
Set an Xbox LIVE Pass Code
When you set an Xbox LIVE pass code for your profile, anyone who wants to use that profile will need to enter the pass code before signing in to Xbox LIVE.
To set an Xbox LIVE pass code:
  1. Go to My Xbox and open your profile.
  2. Select Manage Account, Xbox LIVE Pass Code.
  3. Enter a four-button code using the X andY buttons, triggers, bumpers, and directional pad on your controller.
  4. Confirm your code by entering it again.
To reset your pass code, repeat this procedure at any time. (You will have to enter your original Xbox LIVE pass code before you can create a new one.)
Set a Family Settings Pass Code
When you create a Family Settings pass code, anyone who wants to change family settings on your console will need to enter the pass code first.
You can also use your Family Settings pass code to override game and movie settings if you (or those with whom you share your pass code) want to play games or watch DVD movies that your console settings normally block.
For example, you could give the pass code to your 18-year-old so that she can watch R-rated movies that your younger child is not allowed to see.
To set a pass code for your console:
  1. Go to My Xbox and open System Settings.
  2. Select Family Settings, Console Controls.
  3. Select Set Pass Code.
  4. Select Pass Code, then enter a four-button code using the X and Y buttons, triggers, bumpers, and directional pad on your controller.
  5. Confirm your code by entering it again.
  6. Choose a pass code reset question.
  7. Select Pass Code Reset Answer and enter your answer using either your Xbox 360 controller or a standard USB computer keyboard plugged into a controller port on your console.
  8. Select Done from the Set Pass Code screen, then select Done once more from the Console Controls screen. When prompted, select Yes, save changes to put your new settings into effect.
Reset a Forgotten Pass Code
To reset your pass code after you've forgotten it:
  3. Enter an incorrect pass code.
  4. You'll be told that your pass code is incorrect. SelectReset pass code.
  5. You'll then be shown your pass code question and asked to answer it.
  6. Set a new pass code, following the directions in the previous section.
If you've forgotten the answer to your pass-code reset question as well as your pass code, call Xbox Customer Support at 1-800-4-MY-XBOX (1-800-469-9269).
Jan 24, 2011 | Microsoft Xbox 360 Console
Forgotten o/s password unable to access pc
For Windows OS:
Enter setup: Start/Restart computer and press the F command shown at bottom of screen (F12 usually). Once in setup, scroll through the file menus until you find the option for password: to change the password, simply hit enter in the "old password" , enter in the "new" and "confirm new" (if applicable). This will reset for NO password, and you should be able to log into the OS.
Please let me know if you need further assistance.
carsandcomps,
Guru, Premium Expert @ Fixya.com
Jun 20, 2010 | ASUS Eee PC 1000H Laptop
Child lock on my tv dont have original remote
Apex child lock release sequences AT3208 Push and hold the "F" button on the remote and press mute. Release then press 6688 PF2020 Push display for 10 seconds and enter 3308 GT2711 Enter the pass code of 1225 to clear
Apr 16, 2010 | Apex Digital GT2715DV 27 in. TV/DVD Combo
I lock my cell phone and forgot the code how do i reset it the phone is a i 465
Unlock Code is a manual hard-lock on handsets which requires the correct pass code to allow access to the phone's functions.
Occasionally, people purchase used handsets. Previous owners may have locked the handset and are unreachable to get the new pass code
To unlock the phone using the factory default pass code, perform the following:
1. Confirm the phone shows, Enter Unlock Code.
2. Press the MENU button. The screen will show, Enter Security. Try both.
3. Enter last 4 of PTN, unless you have changed the lock code, and press OK. OR
Enter six zero's (000000) and press OK.
*If successful, the screen will display, Phone Unlocked.
*If unsuccessful, the screen will display "Security code is incorrect please try again."
If the you don't know the code, You will need to contact Motorola to have it re-flashed, which may incur a service charge from Motorola.
4. You now has access to use the phone’s functions.
5. Do not change the Unlock Code.
Oct 10, 2009 | Motorola Mobility Clutch i465 Cell Phone
Toshiba A-100 laptop asks for bios pass word upon starting
I had this issue my brother took it to a computer place and they had to enter a BIOS password, it did not cost anything hope it helps!
Aug 18, 2008 | Toshiba Satellite A135-S4527 Notebook
Samsung it xe700t1a-a05us Logo
73 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
