Question about Ace Hardware OAKBROOK COLLECTION DESIGNERS CHOICE TUB/SHOWER
ABS Diverter with hand held shower cradle(4295291), gets pulled to the side of the cradle as soon as I put the hand shower on the diverter.
3 Suggested Answers
  • 35 Answers
SOURCE: Shower diverter problem
It is very possible that a piece of rubber from the old washer or some debris has found its way into the shower diverter or the showerhead. The first thing to try, is to take off the showerhead and see if you get water without it. If you get water then your problem is solved!!! Puchase a new showerhead or take apart the old one and soak it in CLR or Lime-Away to clean it. If that doesn't do the trick than, Turn off your water supply to hot and cold. Remove the diverter (if possible) and inspect for debris. If you want you can also take out the hot and cold stems for a total inspection of the inside of the faucet. You can then flush out the inside of the faucet cavity with a Turkey Baster or something to that effect. Put it all back together ( use a bit of vasaline on all the rubber washers so they do not get stressed when re-installing) and you should be able to take a shower.....Also, if it was a cartridge you replaced, you may have inserted it 180 degrees opposite......Hope this helps.....Joe
Posted on Jan 12, 2009
packrat1948
  • 528 Answers
SOURCE: I have a Ace Oak Brook hand held shower head white
Ace hardware can get that part for you. Your local ace my have it in stock. The part is not available anywhere else.
A genaric replacement my work but I would go with the ace brand.
Posted on Feb 01, 2011
How do I change a single diverter to a 3 way diverter?
Not exactly sure what you are attempting. A quick-and relatively inexpensive way-would be to add an Alsons diverter to the shower arm. It is simply removing the shower head, adding the diverter, and reinstalling the shower head and accessory hand held shower. If you are looking for something different, there are myriad valves on the market that would allow for such change. However, changing to a new valve could get somewhat complicated. For example: you may need to increase the size of the supply lines that are feeding the shower; some diverters require a 3/4" feed.
Also, if you check the box stores, they have several shower/hand held shower kits that already have the diverter with the packaging. Again, I am not exactly sure of the end result in which you seek, but I hope this helps some.
Oct 31, 2014 | Dmm Symmons Temptrol pressure balancing...
Pearl Trillium diverter and hand held shower
The faucets on your Pearl tub do not come from Pearl. They were supplied by the local plumber who installed the tub.
Go to your local plumbing store and match up what you have.
Rod
US Parts Center
Jan 04, 2014 | Maax Pearl By TRILLIUMbla Pearl Trillium...
What to do if i can't stop the water flowing from the shower spout and there's little water pressure coming from the shower head and a hand held shower?
One rule I live by: more parts, more problems. Sounds to me that the plumbing/valves were not insalled properly. If you hired a profesional plumber, have them fix it. I am a licensed profesional plumber and I offer a 1 year warranty on all my work. If the contractor did the work and does not hold a plumbing license, that person is still responsible and may have to suffer legal consequenses.
Sep 10, 2013 | Latoscana TC3TPW690 Water Harmony...
Why does the water not flow from shower valve when turned on?
Do you have water coming out of the tub spout and not the shower head? If so how does the water get directed to the shower head,is it by pulling up the diverter on the tub spout?If water is still coming out of the tub spout then the diverter is bad and the tub spout needs to be replaced.
May 09, 2012 | Danze & Single Handle Tub And Shower...
I just installed the valve new. I have a shoewe head and a hand held that feed from the unit. It was intended to 1) serve the shower heas alone, 2) serve the hand held unit alone, 3) put water to both...
Assuming that your two heads are fed from the typical curved wall mounted shower pipe, what you need is a diverter valve. Removed both heads till it's down to just that curved pipe. Get a diverter valve from a plumbing supply store. Tell the sales folks that you want to install a diverter valve so that in one position, the hand held receives water and in the other, it cuts the hand held and puts it to the reg. shower head instead. They should give you a "T" sort of fitting. The female threads of this screws into that curved shower pipe. Then you will find two male thread ends. These connect to both your shower heads. Finally there will be a push/pull knob that is operated to control which head gets the water.
Nimsgame
Feb 13, 2011 | Home
Can this diverter run both the shower head and a hand held shower.
This unit will allow the function of the shower head or the hand held shower individually. You can make both operate at the same time but the performance will be dismall at best.
Oct 23, 2010 | Kohler K-9511-BN MasterShower Shower Arm &...
Water sprays out the diverter
Remove hot/cold button in handle, remove screw/pull off handle. Remove the two screws in the wall plate/remove plate. Use a wrench to remove the diverter assembly. Get new diverter assy and reinstall eveything. You don't need to turn off the water.
Jun 09, 2009 | Delta Faucet #RP320 Divert Assembly
Diverter valve does not work correctly.
the connections are reversed,just change them over and this will fix the problem.
Feb 18, 2009 | Grohe Eurosmart, 3-hole Roman Tub Filler...
Kohler K-9511
It sounds like there is dirt or other debris in the unit. Here is the installation guide. Take it apart and look for debris which would block the mechanism:
http://www.homedepot.com/catalog/pdfimages/5d/5d085947-93ec-433f-8f59-c8a23d2eb5ff.pdf
Feb 10, 2009 | Kohler K-9511-BN MasterShower Shower Arm &...
Ace Hardware OAKBROOK COLLECTION DESIGNERS CHOICE TUB/SHOWER Logo
54 people viewed this question
Top Ace Hardware Home Experts
Donni Steen
guitar zan
Are you an Ace Hardware Home Expert? Answer questions, earn points and help others
