Question about Garden
I have a inteck briggs motor on a snapper 30inch mower it has a battery start and a pull rope start it has startd with 2 pulls as the battery is over a year old thts why i have been using the pull start. Right now it won't start with the rope, but wh en i use the battery charger on start it will start right up. I have cleaned the carb checked the valves good fuel good blue spark at the plug I have isolated yhe motor from the wireing at the kill bolt and it starts right up with mthe charger to the starter but won't start with the pull rope.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,917 Answers
Your valves are bad they are not seating all the way they look like but there not lawn mower should staert on third pull after you prime with slow prepulls if your compression is under 100lbs valve job time bet on it
Posted on Jul 19, 2014
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 85 Answers
Test the battery
if it is under 12v as normal change it; 10v is one dead cell. 8v is two dead cells etc.
if it is not able to hold a charge the engine wont start even with the pull start due to electronics not firing at under 12v
that is probably why it starts with the charger hitting it with 14-18v
Posted on Oct 20, 2013
  • Ron Sanders
    Ron Sanders Oct 23, 2013
    Hi alex no that didn't help but i think I found the problem. I pulled the head and found a small peace of head broke off, as I remember the owner said he heard a pop and the engine died, I'm not sure but something like this happened on my John Deere and it would't start either. But thanks for the try
4 Suggested Answers
SOURCE: Snapper Big Six Mower. New spark plug, cleaned carburetor&fuel tank, new 91 octane fuel mower starts with engine starting fluid but won't stay running
Try taking the float bowl off and clean out the orfus. It will eather be in the nut holding the bowl on or in the end (sides) of the pickup tub the nut scews on.
Posted on Jun 30, 2012
  • 2239 Answers
SOURCE: Briggs ans Stratton Quantum 5.5 HP still no spark after changing coil and plug
You are correct, you have a flywheel with magnets in, an electronic ignition unit which when the magnets pass the ignition unit core at speed energises and creates a spark via the plug, the earth wire simply takes the unit to ground and shuts off the spark, the unit you changed was it definetly an electronic unit or just a coil? if electronic and you are cranking the engine fast enough and have the plug well earted against the cylinder with the earth wire not connected it should spark.
Posted on Sep 02, 2012
philwalker78
  • 608 Answers
SOURCE: Swisher 60" pull behind mower with 14.5 briggs engine. good spark and the starter will crank just fine. If I prime the carb with a little gas it will start imediately but wont continue. Any ideas..
Hi Andy, the carby will need to be removed and all jets cleaned out with compressed air. Basically its not getting enough fuel through the carby to keep running. Regards Phil.
Posted on Nov 29, 2012
21" snapper self propelled mower
You need to remove the starting mechanism and make sure that there are no kinks, etc. in the starter rope.
Jun 12, 2016 | Snapper Garden
How do I replace the pull cord on snapper sr1330 riding mower
remove coil cap look at the rope pulley pull old rope forward till you get to end knot hold pully pull not out with the rest of the rope then wind pulley up till it wont go any farther back off one turn alighning the cover hole with pully hole use ascrew driver stuck between the slot on cover and pulley ten get your rope take a lighter and burn the end of the rope the take a rag pul the end of burt end of the rope shuold leave a pointed rope then take rope and stick through pully hole then the housing make the rope about 70 iches long it will be to long i no but just do it tie a knot in tend on the back of pully take lighter and heat it still it melts a very little the knot that is pull rope on through pulley hold rope remove screw driver slowly let rope wind up on pulley still it stops you will have rope sticking out reistall pulley cap then put handle on rope put handle all the way down to cap pull rope one turn push handel down to cap atie a knot in rope as close to to handel as possible heat not like the other end cut rope with 1/2 inch of rope sticking out of knot
Sep 13, 2014 | Snapper Garden
Have a 12.5 briggs Inteck engine its an ohv mod219907 type0131E1 code070323ZA with electric start and a pull start. It will start with 1 turn with the electric start but won't start with the pull starter. ...
I have seen Inteck engines to be very sensitive to valve clearance. IF it is a few years old try adjusting the valve clearance exactly as shown in the manual. The electric starter may give it just enough kick to make the difference.
Oct 10, 2013 | Computers & Internet
Toro Electric Start Problem
Remove spark plug and observe condition. Fouled with oil, bad motor. With plug removed pull rope several times to blow out cylinder. Spray WD40 in spark plug hole, pull rope several times see if oil blows out. Spray a lot of starter fluid in spark plug hole, replace plug. Spray starter fluid in air cleaner area of carb, try to start. Replace spark plug, try to start. Ensure oil is full, all mowers have a low oil sensor now. 30w oil. Always use Stabile in gas.
Jul 04, 2012 | Toro Garden
Turn the key and just get a whirring sound. Is it the solenoid? What can I do?
sounds like the gear broke on the starter and lock up the flywheel take off the little cover over the flywheel and you will see it you can buy the gear for about 10 bucks
Apr 21, 2012 | Snapper Garden
I have a Yard Machine Lawn mower by MTD it has a briggs and stratton engine. The pull cord pulls, to easily I might add, but will not start the lawn mower. It doesn't seem to engage the motor. What might...
If you think the rope pulls too easily the engine may not have enough compression. Consider doing a compression test or a leak-down test on the cylinder.
Oct 23, 2010 | Mtd 22" Yard Machine Push Mower
Lawn mower won't start
to check for firing remove the spark plug insert it in the plug boot and pull the rope while watching to see if the plug sparks be carefull not to touch the plug electrode while pulling the rope or it will shock you. If you don't have a spark, try a different plug. If still no spark the coil could be bad.
Jun 25, 2010 | Briggs & Stratton Briggs Stratton Intek V...
I have a Snapper Briggs & Stratton lawn mower Model Series 126T00 and for some reason it will not start.I drained the gas tank ,put fresh gas in it. I did a caburetor kit and it still will not start....
How about the key way? Its the timing of the motor. Its under the pull rope and the wheel under the pull rope. Might be cut or broke in half.
Mar 21, 2010 | Garden
Garden Logo
95 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
