Question about Minolta Bizhub Di1811p Copier
Konica di1611 - Minolta Bizhub Di1811p Copier
I NEED THE admin login for a di1611 konica minolta via pagescope web connection
8 zeros try also 12345678. if not must go into service mode to reset password, can you get logged in from control panel?
Jun 16, 2017 | Konica Minolta Office Equipment & Supplies
Minolta DI1611 M1, M2
replace the drum cartridge, also clear maintenance counters in service mode
Dec 23, 2013 | Konica Minolta Office Equipment & Supplies
Konika minolta di1611 error xodes
You must be change the developer and the opc drum and drum cleaning blade.
Jul 26, 2013 | Office Equipment & Supplies
Konica DiALTA Di1611 error message 2nd side door open although the door is closed.
Check and clean the sensors and actuators,verify the cable connection,verify if 5V appaire to red cable.
Apr 09, 2013 | Office Equipment & Supplies
Konica Minolta di1611 indicating cof32
ATDC sensor malfunction.Enter in the service mode :
press the Utility key press STOP 0 0 Stop 0 1
select CLEAR DATA then select I/C counter and reset the counter press C.to exit press panel reset.
Feb 19, 2013 | Konica Minolta Office Equipment & Supplies
Konica Minolta Di1611/Di2011 printer Driver CD has no Driver for windows 7 64 bit - What is solution?
This is a very old post; however, maybe someone could use my help :).
The Konica Minolta Di2011 can be ordered with a built in printer module or not. The difference is that when you have the printer module, it works on PCL, but if not, it will only work using a GDI emulator.
For Win XP, you can find very easily the drivers on Konica website.
The drivers for Win7 64bit, especially the GDI Emulation for DI2011, cannot be found on the website.
I have found on the Konica Minolta website the STD GDI emulator for some other models and I have tested the one for the printer Konica Minolta 162.
It seems it works without problems for now, however I was only using it in A4 mode - manually selected. I have found that it requires a manual selection of the paper size and tray as it will not switch automatically.
I hope this helps.
BR S.H.
Mar 06, 2012 | Konica Minolta Office Equipment & Supplies
I cant find the driver for my konica minolta Di1611 for windows xp. can you help me download it's driver?
Konica Minolta Photo Imaging, Inc. ceased its Camera Business Operation as of 31 March, 2006, and since 1 April, 2006
Sony Corporation has been providing customer service for Konica's, Minolta's, and Konica Minolta's cameras (excluding Film-in cameras) and camera-related products except for the binoculars.
Please be informed upon the termination of the Agreement between Sony Corporation and Konica Minolta Photo Imaging, Inc..
Konica Minolta ceased the entire customer services for Konica Minolta cameras and related products, as of 31 December, 2010.
After 1 January, 2011, the Repair Service Providers will continue support for the repair service independently.
To view the list of Repair Service Providers for each region, please click HERE.
Aug 15, 2011 | Computers & Internet
I can't find drivers for my konica minolta Di1611 printer for windows xp. can you help me download it's driver?
Aug 15, 2011 | Office Equipment & Supplies
I can't find drivers for my Konica Minolta Di1611 printer for windows 7 64 bit
Hey all, after a load of grief, and NO help from the INTERWEB, I have chanced upon a solution. Firstly I installed a new local printer with IP number for network printer and associated network address/port (\\server\konicami). Then I installed the win7 64 bit bizhub162 drivers. Then I installed the win7 64bit BH 164 drivers and put an additional driver of x86 win2000 on the properties (server has win2000). Then, when I selected the BH162 driver in printer properties driver pull down menu, it worked. wahey.
May 06, 2011 | Konica Minolta Di1611
24 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
CheckitRight
CheckitRight
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
