My acer espire one d255-13412 will not boot. Error message...no bootable device... insert boot disk. My laptop does not have a disk drive
  • 564 Answers
You have a problem with your hard drive.
Posted on Oct 15, 2013
corahudo
  • 3 Answers
SOURCE: No bootable device
Do you have the original cds for the computer? If you do, you will hae to download everything beginning with windows whatever you have. Unfortunately eveerything saved on your hard drive will be erased, but your computer should work after completing this.
Posted on Jun 28, 2009
SOURCE: Acer Aspire One Insert boot disk
well u really cant put in a disc, you said you have the aspire one that means it doesn,t have a disc drive . Thats the way it was made
Posted on Jul 10, 2009
leecom72
  • 4806 Answers
SOURCE: acer aspire one
Its possible the computer is trying to boot from another device, as the computer starts up hit the F12 key, this should bring up boot options, select HDD if it's in the list.
If not hit F2 as it starts and enter the BIOS, look for the boot option and set the HDD as the first boot device, hit F10, save the changes and exit.
The computer will restart and hopefully boot into the operating system
Please post back if you need anymore assistance.
Regards.
Posted on Aug 06, 2009
  • 5 Answers
SOURCE: Acer aspire one mini notebook. NTLDR is missing..
If you don't have documents, pictures, etc on the hard drive that you need to backup, try running system recovery by doing the following (not sure if this works on the version with a solid state drive):
1. Turn on the computer
2. Press and hold Alt + F10
3. Click on Restore System to Factory Default
4. Ensure the netbook is plugged into AC power instead of running off the battery and click OK
* This will return your netbook to the condition it was in from the manufacturer.
Posted on Oct 13, 2009
parrotheadpc
  • 2600 Answers
SOURCE: no bootable device message, says insert boot disk what is that
Usually this is idicative of a hard drive failure, try to boot with the windows cd and see if it will boot up. Try this below......
Windows Start-up Errors
First, The basics. You will need a Windows CD. If you only have a recovery disk set like the ones from a HP or Compaq, they will not do what you want. You can normally use a Dell disk, also retail box disks (Windows Purchased from the store), or some OEM versions of Windows will work (most of these will have the Microsoft hologram on them).
When you get the system started and it finds your startup disk you will see a screen that says Press any Key to boot from CD. I normally use the space bar as my any key and then you should see a blue screen that says Windows setup in the left hand corner. Wait until you see the welcome to setup screen and then click the "R" key to get to the Recovery Console How long it takes to get to each of these depends on the speed of your system, but I will tell you that it will take a few minutes to finally get to the Console.
Once you are at the Recovery Console you will be given at least one choice of Windows installations. Normally the choice you want is the number 1 choice. Click the number 1 key at the "top" of the keyboard and click enter.
You will be given a message asking for the administrator password. Unless someone or something has messed with your computer there is no password so you just click the enter key.
This will bring you to a prompt that says:
C:\WINDOWS>
Type: cd \ and then click enter
( Note: between "cd" and "\" there should be a "blank space" otherwise the command won't work. If you find that a command hasn't worked make sure you typed it correctly. These are similar to old DOS commands where spaces had to go between each command so DOS knew where one command stopped and another started.)
You are now at the ROOT of the drive where it all begins. The Prompt should now say C:\>
Now type: CHKDSK /R and click enter.
The chkdsk / r command also includes the P command and will also look for lost recoverable information in bad sectors.
Now after the chkdsk has run type: FIXBOOT then click enter.
It may prompt you with a warning but continue through it and once fixboot has finished type: EXIT and click enter.
Your system should reboot and when it does click the F8 button to get a windows start menu. Use the up or down arrow to highlight the LAST KNOWN GOOD CONFIGURATION and click enter. If it was a simple drive error this should have fixed it.
Posted on Nov 21, 2009
What to do when my acer laptop is saying no bootable device---please insert boot disk and press any key
Check the boot device list in the bios. Make sure it tries to boot from the hard drive and drive C
Nov 01, 2015 | Acer Aspire E1-531-4444 15.6" Notebook...
My laptop says no bootable device insert disk what is wrong?
NO BOOTABLE DEVICE When the PC cannot see a boot file/disk on either the hard disk or floppy drive it gives an error message "No bootable device. Insert boot disk and press any key" First thing, check to see if the is a floppy disk in the floppy drive, if so removes this disk. If there was no disk in the floppy drive then it may be a hard disk problem.
Check the BIOS to see if the hard disk is detected, if not open the case and re-seat the data cable on the hard drive and also where it connects to the motherboard disk controller.
If it still gives this error message and the BIOS does not detect this hard drive, then the hard drive is probably faulty.
A further check on the hard drive, remove the hard drive and connect it to an USB hard drive adapter and connect it to a working computer's USB port, if this computer does not detect it as an external storage device then the hard drive is faulty.
To get the computer operating again, install a new hard drive in your computer and then install Windows on this hard drive plus the computer's device drivers and your programs.
Oct 30, 2012 | Toshiba Computers & Internet
Why is my bootable device not found
It is more than likely the hard drive has issues, have the hardware tested for possible replacement.
Jul 27, 2012 | Acer Aspire One PC Notebook
Tried to boot from USD, CD/DVD Drive but failed. Still showing No bootable device -- insert boot disk and press any key
To boot up from the DVD drive go into the BIOS setting - boot device order and move the DVD as the first boot device and the hard disk as the 2nd boot device.
If you want to boot up with the USB then move the USB as the first device. If the USB is not listed as a boot device then it is not possible to boot up with an USB device.
May 26, 2012 | Acer Aspire 4930-6862 Laptop
Every time I turn on my computer the following message appears: "For PCIE Atheros Ethernet controller v1.0.0.5 Check cable connection ..! pxe-e63: error while initializing the NIC pxe-mof:...
It sounds like the hard disk is faulty, the machine is trying to boot via the network card as it cannot find a bootable disk. You could try removing the hard drive and reseating it but the disk could be dead.
Apr 04, 2011 | Acer Aspire One PC Notebook
My daughter's ACER inspire one gives the following message and makes a beeping sound "Check Cable connection! PXE-MOF: Exiting Intel PXE Rom No bootable device---insert boot disk and press any key
There is a loose connection between the hard drive and motherboard of the computer, that's why you are getting that message. You most likely need to take it to a computer repair shop so they can fix it.
Mar 06, 2011 | Acer Aspire One PC Notebook
Well, my computer doesn't start up and the screen says "Media test failure, check cable", "No bootable device -- insert boot disk and press any key". I don't know what the cable is and...
The uProcessor can't find a bootable device and presumes your hard drive is no longer plugged in. Standard error message.
Check your BIOS for the hard drive listing. If it is listed there is no problem with the cables.
You will need your restore disc to boot from and repair your boot sector on the drive.
Feb 21, 2011 | Acer Computers & Internet
When i turn on my Acer Aspire One D255 it says: "check cable connection! PXE-M0F: Exiting Intel PXE ROM. No bootable device -- insert boot disk and press any key"
The PXE ROM is part of your system's network interface controller. It is being entered on your system's startup to look for a bootable image on a physical network connection and if found, to boot from that image. If there is no network cable connection to your system or if there is but no bootable device is found on that connection, the result is the error message that you got. As to why your system is entering the PXE ROM can be explained by looking at your system's Setup Utility,,,
Press F2 while powering up to enter the Setup Utility and use the cursor control keys to go to the Boot tab which then shows the Boot priority order. The default order is as follows...
1. IDE0
2. IDE1
3. USB FDD
4. USB HDD
5. Network Boot : LEGACY PCI DEVICE
6. USB CDROM
Your system's internal hard disk drive should be listed beside IDE0 and it will be accessed first to look for a boot record. If the drive fails to boot, the next devices in the list will be accessed accordingly until either a bootable device is found or the last item which is USB CDROM. If a USB CDROM is plugged in on one of the system's USB ports, it will be checked for a bootable record and if not found or no CDROM is plugged in, then the system displays the last part of the message -- insert boot disk and press any key.
Press F12 while powering up enters the Boot Menu which has the Boot Option Menu. This menu should show by default the following...
1. IDE 0: (the name/type information for your system's internal hard disk drive
2. Network Boot: LEGACY PCI DEVICE
If there is no hard disk drive information shown beside IDE 0, then the possibilities are that
1. there is no internal hard drive present
2. there is a hard drive but it has failed
If there is hard disk drive information and pressing enter to select it does not result in an operating system startup, then the drive's startup partition has been wiped and so it has no bootable image.
If there seems to be an internal hard drive present but it has no bootable image, you may attempt recovery from the installation images in the hidden partition. The recovery allows restoration of...
1. operating system to factory defaults
2. applications (selectable)
3. drivers (selectable)
Press Alt and F10 keys together while powering up and the Acer logo is showing to enter Acer's eRecovery Management. Follow the instructions to do the recovery.
Feb 09, 2011 | Acer Aspire One Netbook 8.9" Notebook
Media test failure, No bootable device, insert boot disk.
Media test failure, no bootable device error message means the hard disk has failed, therefore cannot boot up.
If reseating the hard drive doesn't fix your problem then replace the faulty drive and install Windows on the new drive to get the computer operational again.
May 12, 2009 | Acer Aspire One Netbook 8.9" Notebook
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
