Question about Husqvarna Riding Lawn Mower Yth24v48ls 48 Inch Cut
Husqvarna YTH22V46 22 HP V-Twin starts stalling after its hot. Pull the choke out helps a little but must push it right back in. Changed the fuel filter and seem to be better for a few cuts and then started doing the same thing. starts about 3/4 hour into cut.
    Sergeant:
  • 459 Answers
Check gas cap vent
clean it out then try it again
Posted on Oct 10, 2013
boscia
  • 163 Answers
SOURCE: my husqvarna GTH2448T has to be choked to run
check the fuek lines for hole and leaks, check the fuel filter and clean if necessary. remove the carbuerator and inspect the gasket; it should be soft and flexible, if it seems hard or brittle replace it. clean the carb with carb cleaner sray (available at any local auto parts store) and compressed air. make sure you get inside the small fuel rail holes.
Posted on Nov 30, 2008
SOURCE: I have a Husqvarna 23hp 48
not sure but is battery being charged the right way have seen battery's put in and charged backwards
Posted on May 15, 2009
SOURCE: spitting and sputtering
mine did the same, I found out that the high speed jet was clogged, I pulled the fuel line off the filtor(going to the carb), stuck the line into a mixture of half gas half carb cleaner, I fanned it up and in 2 or 3 minutes it started running well, hope this helps.
Posted on Jun 03, 2009
wadembly
  • 513 Answers
SOURCE: Hard start or won't start
the float in the fuel bowl might be getting stuck what you can do is push & pull on float to see if it flows if not the replace the float if i can help further e-mail me wade @ wadembly@aol.com
Posted on Jun 28, 2009
  • 640 Answers
SOURCE: My Husqvarna riding mower won't start. I was
Check to see if you left the blades engaged. There is a safety switch that prevents starting with blades engaged. Easy to miss, happened to a friend of mine last month.
If this really helpful, please rate.
Posted on Jul 11, 2011
Hi I have a Husqvarna model 236 chainsaw its starts when its cold but not after it warms up why help sisc of pulling the rope
There can be a number of things that effect a poor hot start, engine over heating due to dull chain, engine running to lean ( H mixture screw incorrectly set ) stale fuel, ignition unit faulty, to help with a hot start push the fuel puge bulb 5 times, pull the choke pull out and in again to give part throttle crank engine.
Oct 09, 2017 | Husqvarna Garden
My Husqvarna 2148 stalls when it's under a load or
What exactly are you calling under load? Is it when you turn on the mower deck, or when you go into high grass? I'll assume it is when you enter higher grass. Loss of power can be a number of things from the governor not being properly set, a bad spark plug (should have been your first thing to look at), insufficient fuel (dirty fuel filter, gas cap not venting, dirt in the carburetor from a deteriorating fuel line). You could also have a bad head gasket, or a valve not seating. Head gasket is easy to see if it is bad by looking around the head gasket area for black deposits of carbon or oil. Valve issues are common if you have a lot of grass buildup under the engine cover, which restricts air from cooling the cylinder area. If you give me a little more information as to when it is stalling (does it start right back up?), and the conditions, I can give better direction as to what to do.
Sep 05, 2014 | Tools & Hardware - Others
Dont wont to start to much fuel in cilinder
Never pull the starter more than 3-4 times under full choke. Pull 3-4 times on choke, push in to half choke and pull, should start.
Feb 14, 2014 | Husqvarna/jonsered 136-142,2036-2137...
21 hp twin briggs engine cranks runs
Try replacing your air filter
Sep 20, 2013 | Craftsman Garden
Husqvarna 236 brand new will not start
1. Make sure you have used the correct fuel to oil mix in the tank.
2. Set on/off switch to ON position.
3. Pull out the choke switch to (full choke position)
4. Prime the carb by pumping the primer bulb on the carb until fuel fills the bulb.
5. Pull over saw until the saw fires.
6. Push in the choke switch.
7. Pull over and the saw should start.
May 09, 2013 | Husqvarna Garden
Have 22HP BS V-Twin in a 2010 Husqvarna rider w/25 total hours. Recently won't cold start without priminig. It will crank and crank cold til the battery runs down. A shot of starting fluid and it runs...
nearly all petrol mower engines need to have the 'choke' engaged to start from cold. This enriches the fuel mixture, and is similar to priming. If there is a prime 'button' then you will probably have to use this all the time. This is normal.
However, you should check with your dealer to see if this is an unusual situation.
Aug 27, 2011 | Briggs & Stratton Briggs Stratton Intek V...
I have a murray push mower 6-22271 briggs straton 4 hp. it start and then stalls . filter clean. choke fully closed when control is in full forwrd run/choke position. I pour gas in the throat and pull...
Your carburetor needs cleaned. It is dirty/has debris in it. If it has a bowl that is. If it has a diaphram (carburetor mounted on the fuel tank), replace the diaphram. They go bad.
I hope this helps get you going.
Jul 28, 2011 | Garden
21 hp briggs on husky mower runs fine but intermittently acts like it is flooding ie.it starts losing power and i can see small amount of black smoke.if i pull the choke on easy it will stall.sometimes...
I had the same problem with mine. I talked to briggs help line and that was useless and also talked to 6 other repair shops. Seems to be a dirty little secret they are keeping about the defective carbs they use. Only way to fix it is to get the redesigned carb they have out now. They changed the fuel bowl and solenoid assembly. Carb kits did me no good.
Jul 16, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Can't restart my new husqvarna 450 chain saw after a little bit of time using it. i followed the instruction manual both times.
The manual may not be clear, read warm line 3 below, read it again. The 450 manual I read says something similar under warm start. Are you opening the choke after turning on the ignition? Before pulling the starter rope? Flooding is the most common hard start problem with 2-cycle engines. If you are opening the choke I recommend you contact Husqvarna for guidance. They will likely send you to a neighborhood dealer, gratis.
HusqvarnaUSA.com/ContactUs
http://www.husqvarna.com/us/homeowner/support/customer-support/
Start Procedure
Cold:
  1. Ignition on/off to on.
  2. Set compression release – optional step even if saw is equipped with a compression release.
  3. Pull (close) choke, set fast idle (done when choke closed on some saws); pull starter and listen for an attempt to start. once heard (usually two pulls; no more than 4).
  4. Set compression release – optional step even if saw is equipped with a compression release.
  5. Push (open) choke pull starter until it starts. (usually first pull).
Warm:
  3. Pull (close) choke, set fast idle (done when choke closed on some saws) – Do not pull with choke closed.
  4. Push (open) choke, pull starter until it starts. (usually first pull).
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Feb 28, 2010 | Husqvarna 450 e-series 18" Chain Saw
Saw stops when i give it gas.
  • plugged fuel filter
  • cracked/loose fuel line allowing air (instead of fuel) into the carburetor.
  • poorly fitting fuel cap
  • plugged or disconnected/broken pumper line
Feb 16, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Husqvarna Riding Lawn Mower Yth24v48ls 48 Inch Cut Logo
240 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
