Question about Dell Vostro Computers & Internet
Clock not keeping time - Vostro Dell Computers & Internet
    Sergeant:
  • Dell Expert
  • 504 Answers
Log onto your Computer and adjust it by Adding the Correct Time zone
Posted on Oct 10, 2013
Can't set clock. 12:00 keeps flashing
SETTING THE CLOCK AND DELAY BREW TIME
To Set the Clock:
1.
Plug the power cord into a standard electrical outlet. The clock
will flash on the control panel to indicate that the time has not
been set yet.
2.
Press and hold the HOUR and MINUTE buttons until you reach
the current time. The AM or PM indicator will light at the bottom
of the display (Figure 1).
The clock is now set!
NOTE:
Pressing any button before setting the clock will cause the
clock to start keeping time from 12:00 a.m. You must set the clock
if you want to use the Delay Brew feature.
Nov 01, 2014 | Mr. Coffee 10-Cup OptimalBrew Thermal...
Setting clock on laptop toshiba need to find out how to change time on laptop pc
Click on the clock time and you can edit the time and date.
The clock time is on the bottom right hand side of the desktop.
Feb 07, 2014 | Toshiba Computers & Internet
I recently moved my melodies in motion clock back one hour for daylight savings time and now the clock is not keeping time. I suppose I should not have moved it backwards but now what do I do to get the...
By moving the clock back one hour you changed from DST to standard time, not as you stated. Some clocks require you to rotate the hands clockwise to set the time back. Your clock may have been damaged beyond repair.
Nov 05, 2013 | Seiko Melodies in Motion Clock
My cd player keeps turning on and off. and dash clock light keeps dimming in and out and wont keep the time.
You have a loose wire. Will require removing the radio to get to the wire that keeps constant power to the radio ,,,this allows the clock to keep time. An interuption in this power source equal reseting the clock. Good luck
Feb 11, 2011 | 1992 Honda Accord
Day Light Savings Time
If you tip your clock over you will see three little buttons under. They are each labeled. Press/hold the one that says "clock" until your display blinks. Use the forward/back buttons on face of clock to re-set time, then press the little "clock" button underneath it again to keep the time you just set. It probably will beep.
When Congress's ideal day comes, re-set it the same way. Sorry, but all this will do is keep you from having to look at the wrong time for a few weeks straight.
Oct 28, 2008 | Zenith Z166S Clock Radio
Westinghouse microwave WST3502..... Problem:
Press "Clock", type in the time on the keypad and then press "Start". The clock runs a little slow (at least on mine) and I have to reset it about once a month. It gets about 10 - 15 minutes behind after awhile.
Sep 06, 2008 | Westinghouse WST3501 Microwave Oven
Clock runaway
You are right on, the clock is using the 50 hertz to keep time expecting it too be 60 hertz.
Dec 27, 2007 | GE RP4842 Clock Radio
RCA alarm clock - RP3721 - crystal or AC for time?
They used to use crystals to help the timer ics to keep time but since the development of Micropros. all this is built in to one chip. Now they will use a resonator or a small crystal for the timing clock of the micro but nowdays the manufacture uses that clock to keep all in check. If your gaining time you probably are having problems with your ac duty cycle as this also keeps clocks in check.. This would not affect most devices but could be a problem. But of course a defective Micro could also cause this gain in time And probably is?? Now a battery backup is nothing more then a battery in line with the Microproccesors B+ terminal through of course a diode as well as a voltage limiter resistor to take over the B+ when the units ac supply is absent..
Mar 03, 2006 | RCA RP3721 Clock Radio
Computers & Internet Logo
23 people viewed this question
Alun Cox
