Question about Nordic Track Recumbent Exercise Cycle GX4.0
The resistance doesn't change. - Nordic Track Recumbent Exercise Cycle GX4.0
Boiler doesn't warm up
Change the heater
Mar 25, 2017 | Saeco Odea Go
Gear shift moves but indicator doesn't change and transmission doesn't engage.
try disconnecting cable to transmission turn the shifter on transmission manually down there connect cable again start car try it if not try it again turn once then connect cable again then try it if not the transmission is not good
Jan 31, 2013 | 2002 Nissan Maxima
My Proform 100 ZLX Exercycle is stuck in low/zero pedal resistance, and doesn't respond to console settings. Can this be economically fixed?
follow the steps, and fix it. God bless you
Be aware that the resistance is often the part that requires repair. Resistance is managed magnetically, so often if the machine is working, but the resistance isn't setting correctly or at all, check the bolts that secure the magnets. If they are loose, the resistance will slip. If the bolts are fine, check the magnets themselves by using a refrigerator magnet and see if it is attracted or repelled by the your fridge magnet. If not, the magnets have de-magnetized and need to be replaced.
Dec 05, 2012 | Exercise & Fitness
My tv has sound but very low and will not go any higher
how about volume adjustment doesn't work?. ok if no response while you are adjusting in the set up, the cause is leak pre amplifier transistor, capacitor or change value resistor ( high resistance) at the amplifier section. it needs a component checking which need an analog or digital tester.
Oct 07, 2012 | Toshiba Televison & Video
Is the Sharp watch shp5759 waterproof
No such thing as a waterproof watch in the USA. Watches are rated for resistance to different depths. If it just says water resistant it means you don't need to remove it to wash your hands. If it doesn't say anything it is water resistant.
Oct 01, 2012 | Watches
Are sleeping bags fire resistant?
It all depends on whatyour sleeping bag is made of. Almost all new sleeping bags are flame resistantwhich doesn't mean that they are fire proof however they do not burst intoflames.
Jul 09, 2012 | Camping, Backpacking & Hiking
04 Saturn vue compressor turns off when fan is set to 3 or 4
The problem is the blower motor speed control resistor, it is located near the blower motor in the housing. I exchanged mine and it works like a charm now.
May 31, 2012 | 2002 Saturn VUE
Glow plug light dose nt cycle like it should.
This is caused by burnt out glow plugs, when the glow plugs fail it changes the resistance so the glow plug controller/timer doesn't cycle properly, it is the same as when a turn signal bulb burns out.
Feb 09, 2012 | Cars & Trucks
Oven not lighting on Amana model agds902ss
Helloemauldin Welcome to Fixya
My name is Huum,
When you turn the thermostat on your range on it sends 120 volts to the bake valve and ignitor. The bake valve and ignitor are wired in series and the ignitor draws all the current and heats up. As the ignitor heats its resistance changes and when it is cherry red the current switches to the gas valve and it opens. The amp draw on the ignitor needs to be 3.2-3.6 amps for the gas valve to open. The gas valve has gas to it at all times. The gas valve should open within 40 seconds after the ignitor starts to glow.
If the ignitor is glowing red and the gas valve doesn’t open the ignitor is usually the problem. Sometimes the ignitor will glow red but the resistance doesn’t change and the gas valve doesn’t draw the current.
This is not a do it your selfer!
Thank You For trusting us with your question
Please remember to leave a solved rating before you leave!
Dec 24, 2008 | Amana AGDS902SS Gas Kitchen Range
Nordic Track Recumbent Exercise Cycle GX4.0 Logo
41 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
