Question about Acer ASPIRE 5720-4649 Notebook
Open laptop latch slide - Acer ASPIRE 5720-4649 Notebook
How do I open the lid of laptop to use for the first time?
It generally slides to the right, spring loaded, and you have to pull up on the lid after sliding it to the right. It opens easy so don't force it.
Sometimes there is no latch. You just lift the lid while holding down the base.
Sep 03, 2014 | Dell Computers & Internet
Battery change on Dell latitude c6400.14inchlaptop
I think the Laptop you have is E6400,
Steps to Remove the Battery.
They are 3 Release Latches to remove the Battery.
1) Make Sure all cables including Power cord is unplugged.
2) Please look at the image attached.1a2dca20-03d2-447a-9f36-95e42448fc94.jpg
3) Turn the Computer Upside Down.
4) I have numbered the Latches.
Latch# 1 - Slide the battery door release latch# 1 into the unlocked position and Slide the battery door release latch# 1 toward the base of the system.
5) Latch# 2 and 3 - Slide the battery release latches into the unlocked possition.
6) Open the battery door on Latch# 1
7) Using the battery pull tab slide the battery out of the system.
Let me know if you need any other help.
Thanks
Feb 10, 2014 | Dell Computers & Internet
How to change battery on Dell latitude c6400.14inch laptop
Thanks
Feb 10, 2014 | Dell Latitude C640 Notebook
Battery slide wont open
Does it have a locking mechanism? The Latch/spring may be broken or jammed, push the latch over and hold use a tool, old credit card, to wedge at the crack where the battery meets the laptop, gently pry it open, while holding the latch open. OR remove the laptop's bottom cover. If you supply the Model of the Compag , I may can assist you further.
Feb 27, 2013 | Compaq Presario Notebook
Battery release latch won't open
If you push the battery in and try to release? Try a little silicon spray, mind not to over spray.If you hold open the release switch and manually pry out the battery with your finger nails?
Nov 12, 2012 | HP Computers & Internet
The latch on the laptop broke How do i open it?
you need to mimic what the latch did most latches are like arrows in this case get two thin items ( blunt butter knifes) and move the latches both left or right if its a middle type latch then try pushing in were the broken latch was .get what i mean if the old latch pushed in then its a middle latch if it slide then is double arrow latch ounce the laptop is open if you dont want to spend $$ fixing the lach just cut of the locking arrows to stop it locking again
good luck
email me if need further assistance
Jun 25, 2010 | HP Pavilion dv1000 Notebook
Battery release latch locked in open -hp pavilion dv4 1313dx
The same thing happened to my HP laptop. The sliding lock mechanism relies on three little hooks to hold the battery in place. What had happened to mine was that one of the hooks (the one nearest to the switch) had gotten stuck (this is quite difficult to explain, but just examine the three little hooks closely and you'll notice it the difference.) I freed it simply by pushing it with my thumb to unsnag it. The battery is now securely back in place, where it will stay!
Jan 13, 2010 | Computers & Internet
Top of my new laptop won't open Help
If you have the Acer 5570 model, there are two latches on the lid.....one on either side and I believe they both have to be moved together to open the lid. Move the slides to the right and the lid should open. If they don't and if perhaps a latch has broken from the release, try taking a credit card and swiping left to right you might be able to unlatch the catch.
Dec 02, 2009 | Acer Aspire 5500 5570-2609 Laptop
Keyboard on my Dell studio 15 is locked
Use your touchpad or mouse to save all open documents and close all programs. Shut down the computer. Be sure to click "Turn Off" instead of "Restart."
Unplug your Dell Inspiron 2600 and close the lid.
Carefully turn the laptop over. Remove the battery. The battery has a sliding latch and lock. Unlock the battery by sliding the lock to the unlock position. Slide the latch and remove the battery when the left edge pops up.
Wait one minute and replace the battery. Slide the lock back into the locked position.
Connect your adapter and restart your system.
Sep 13, 2009 | Dell Computers & Internet
Cant open laptop
should be a slide latch on the front of it.
Mar 19, 2009 | Acer Aspire 5315 Notebook
Acer ASPIRE 5720-4649 Notebook Logo
27 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
