Question about Grundfos MQ3-45 1 HP Pressure Booster Pump
How to connect iton to 220 volts - Grundfos MQ3-45 1 HP Pressure Booster Pump
  • 2,113 Answers
Http://rainwatercollection.com/download/Grundfos-Manual.pdf
From what i have researched you have to buy a 120 volt pump or a 220 volt pump you cannot wire it both ways. The pictures shown on that pdf show where to put the line 1 and line 2
Posted on Oct 17, 2013
Will American power tool batteries work after being plugged into a 220 charger
Yep. they will as long as the 220 volt charger was connected to 220. If a 220 volt charger is plugged into 110 volts it may not charge the battery but no damage to the battery will happen.
Dec 04, 2014 | Drills
Tip
How to convert 220 volts to 110 volts for the iPod Touch
<p> <p>The battery of an iPod Touch prepared for use in the United States is designed to be reloaded from the current supplied by a 110-volt electrical system. Power is transmitted to the battery charger with an iPod battery, which are connected via a USB cable and then connected to a 110 volt outlet. To use the power of a 220 volt outlet with an iPod Touch, set the current 220 volts to 110 volts. A conversion adapter voltage, also known as "Step Down Transformer," it is necessary and can be obtained from an electronics store, a hardware store and even some drug stores. <br /> <p><br /> <p>1. Place the 220-110 voltage converter card (aka, "Step Down Transformer") next to a 220 volt outlet. Plug the adapter into the outlet. <br /> <p><br /> <p>2. Connect the end of a USB cable to the USB connector USB iPod charger iPod. Connect the other end of USB cable into your iPod's own socket on the bottom of the iPod Touch. <br /> <p><br /> <p>3. Plug the iPod into the 110 volt outlet in the battery adapter for the iPod Touch. <br /> <p><br /> <p>4. Unplug the charger from the iPod adapter and the adapter from the outlet when the battery is charged. Unplug the USB cable from the iPod charger and iPod Touch. <br />
on Aug 09, 2011 | Apple iPod touch
How do I wire the plug to a Lotos plasma cutter for 220 volt ?
There are three wires on the machine, RED BLUE and YELLOW GREEN. In a standard US 220 VAC connection there is red, black and white. RED is connected to red, BLUE is connected to black and YELLOW GREEN is connected to white.
Sep 12, 2014 | Lotos LT5000D 50-Amp Plasma Cutter
How do I know if my Hotpoint oven 920 years old0 is on a 220 0r 120 line? The serial plate says 120/220.
An oven uses both 120 & 220 -- actually it would be 120 volts and 240 volts or nominally, 110 volt and 220 volt.
The 120 is used for the lights. The 240 is used for the heating elements.
A 240 volt breaker (nominally 220 volt) -- supplies both 120 and 240 volts depending on how the supply is connected to the appliance.
There will be a 240 volt (nominally 220 volt) breaker in the main panel for the oven. This is two 120 volt breakers side-by-side with their toggle switches connected together with a strap across the top of the toggles.
Charlie
Jan 11, 2011 | Hotpoint Ovens
Old electrical box has 3 black wires. new device has 4 colored wires (white, red, green-ground, black - hot), the box does not have a ground wire (that I can see) and the old device only had three wires. ...
Early installations grounded the neutral line at the transformer, but did not bring in a direct ground wire as required for modern installations. White is neutral and should be connected back to the transformer secondary center tap. You will need to drive an 8-foot grounding rod near the panel and bring the ground connection into the box grounding bar (tied directly to the box as opposed to the neutral bar which is insulated from the box). Red and black wires are for 220 volt connections back to the transformer and feed each breaker on that particular rail with 110 volts. Any dual 220 volt breaker will contact both vertical rails. Each light and outlet in the house should have a ground connection, a neutral connection, and a 110 volt connection. Always place a switch to interrupt the 110 volt connection, not the neutral connection. You will likely need to measure the voltage across the suspected two hot wires to confirm the incoming 220 volt lines. Hope this helps!
Dec 27, 2010 | Garden
Will it be okay to connect a 110 volt laptop to a 220 volt LCD projector?
What voltage is your mains supply?
The laptop's adapter should be a multi-voltage type 110 to 240 volts input.
If your mains is 110 volts AC then the 220 volt AC LCD projector won't work unless you connect it to a step up transformer (110 to 220 volt transformer).
If your mains supply is 220 or 240 volts then both the laptop and the LCD projector will work without any problems.
Aug 24, 2010 | Computers & Internet
Wirng connecions for 110v pentair pool motor???
There shopuld be a diagram on the nameplate of the motor, or on the cover for the wiring compartment, or there is some stamped indication at the wiring lugs that tell you where to put your feed and what position the internal wires are to be in or the jumper .. for 110 volts or 220 volts.
May 29, 2010 | Pentair 3hp Whisperflo Pool Pump In -...
3 wires black white ground from box from oven red black white ground what goes where
the appliance is 220 volt and the box you are describing is 110 volt. You cannot connect to this box. You need a new 220 volt circuit ran from your main panel box to the appliance with a 220 volt 3 prong outlet box like an electric dryer uses or make the connections in a box without using the plug system
Aug 17, 2009 | Frigidaire (FEB30S7D) Oven
I need a wiring diagram for a kobalt 60 gallon air compressor
If it's a 220 volt motor, hook l1 and l2 (220 volts) to the line terminals. If it's a'dual voltage' motor (120 or 220)and you want to use 120, hook 120 to the terminals marked 'line'. Make sure the motor is connected for the voltage you're using if it's dual voltage.
Jul 21, 2009 | Air Tools & Compressors
Grundfos MQ3-45  1 HP Pressure Booster Pump  Logo
81 people viewed this question
Top Grundfos Garden Experts
john h
jasbo
jasbo
Jay Finke
Jay Finke
Are you a Grundfos Garden Expert? Answer questions, earn points and help others
