Question about Peavey PV10 USB Mixer
I need to know how to connect a powered subwoofer to my pv10
  • Rick Morris
    Rick Morris Dec 19, 2013
    I patched it in that way and work's great. Thank's Kevin.
  • 39 Answers
The most functional way to use a powered subwoofer with this mixer would be to plug it into the EFX Send output. Then you can add whichever channels you want to go to the subwoofer (i.e. YES for the iPod, NO for the mics) and how much by using the EFX knobs for each channel. Note that when you say "powered subwoofer," this assumes you mean "self-powered subwoofer," because this mixer will not provide power.
Posted on Dec 19, 2013
  • Rick Morris
    Thank's Kevin. I patched it in that way and it work's great.
I would like to connect my Philips subwoofer to my Pioneer multi channel receiver, but the subwoofer's input has only a 15 pin serial port connection. I need an inexpensive and easy solution?
Unfortunately, most subwoofers , like the one you're describing, need a separate amplifier. I don't know the model number of what you're working with but most Phlips subwoofers with that connection need an amp. Now, if you have the rest of the system that was originally with the sub then you can scavenge it's amp. But that's tricky if you don't know what you're looking at. Craigslist has tons of "powered" subwoofers that don't require a separate amp and u can therefore use your Sub Preout from the HT receiver.
Feb 13, 2016 | Pioneer Audio Players & Recorders
The voltage out from supply just jumping all time from about 38,1V constantly to 46,4V - WHY??? How many VOLTS should be????
1- Are you measuring with the mixer connected ? The supply needs a load to work right.
2- If so, you have a blown regulator inside the supply, or maybe a bad solder somewhere on the board, probably a condenser...
LUCK---
Feb 16, 2015 | Peavey PV10 USB Mixer
Why does the pv10 not come on?
You have a problem on your power supply panel a pcb inside the mixer.
Mar 30, 2014 | Peavey PV 10 USB
Well I have a Peavey pv10 mixer. I'm going out of the outputs on the mixer to my amp. Then the outputs on the amp go's to my main speakers. I'm not sure where to add the powered sub. If you need more info...
The easiest thing to do is add an outboard crossover; something like a Rane AC 22S. Set the mode for stereo 2-way & mono sub out. L & R mains out from the mixer to the crossover, mono sub out to the sub and high out's to the full-range speakers.
Oct 12, 2013 | Peavey PV10 USB Mixer
I want to know how to connect a powered subwoofer to the peavey 10 mixer
Connection is hooking up from mixer's main outputs (L,R) to
Subwoofer amp inputs.
Oct 10, 2013 | Peavey Electronics Peavey PV10 Mixer
How to connect a powered subwoofer to a lmt amp
Here's a diagram let me know if you need more.
https://picasaweb.google.com/lh/photo/iZN5bTGIA9FlitKfKylaof4HZ4IbM16viVeWg7zxgWA
Feb 29, 2012 | Velodyne Impact 12 Subwoofer Speaker
Subwoofer: Active or non active?
Hello Smegboy,
Yes, you are right. This receiver is rated at 100WRMS output in all 5 channels (2-front, 1-center and 2-surround) while in Dolby Pro Logic operation. The subwoofer output is line level only (not amplified), which means you need a powered subwoofer to be connected to this output. A non-powered subwoofer could be used but, you need an additional amplifier connected to the subwwofer output from the receiver to drive it.
Let me know if this helps.
cancerags
Dec 29, 2007 | Technics SA-AX710
Peavey PV10 USB Mixer Logo
336 people viewed this question
Top Peavey Audio Players & Recorders Experts
 Grubhead
Grubhead
Vito Vacirca Jr.
Michial Gueffroy
Are you a Peavey Audio Player and Recorder Expert? Answer questions, earn points and help others
