Question about Delta Cartridge Assembly RP46074
I'm trying to replace the cartridge and the back half of the cartridge is stuck. The grey part of the cartridge came out but the white part stayed. Any suggestions on how to remove the stuck cartridge? And was this caused by improper assembly?
My printer will only print in red. Even with a brand new black cartridge. What can I do?
Color cartridge faulty, if you want color printouts replace new color cartridge.. Select "print in grey scale" in printing preferences,if you want to print only in back & white.
Aug 12, 2012 | HP PhotoSmart 7760 InkJet Printer
Poor print quality
if cartridge and drum did not solved this problem, this meant that problem lies with mirror or tracking system and repair that bits is usually beyond home user.
firstly try to check and clean all rollers and traction system, work from tray catcher up, follow paper trail and check for stuck hair, bit of paper or any other debries, clean all rollers. then follow paper procedure below:
as this is easy, create a page of white and black about 10mm lines and then print full page on 120g watercolour paper (this is bit grainy paper which will work as "scrub" of the system), this will remove if any, debris from transfer drum in most cases.
if these solution do not work, if you game, remove back, mark all wires where they go, then remove motherboard panel, mark mirror position, clean it up and this will solve the greyness problem, or kill the printer totally...
Jul 20, 2010 | Brother HL 5250DN Laser Printer
My x4650 is not recognising when I refill the black 36XLA cartridge. Just keeps telling me it is empty. There is not a problem with the cartridge itself just the failure to recognise it has been refilled....
turn on/off, unplug, plug in2_bing.gif, should reset configs.
take all the paper out, put half as much back in.
check the rollers to make sure no paper or particles are stuck.
go to applications folder for your computer, dbl click printer icon for make of printer. check settings. print 'test document and clean cartridge heads', this should ensure proper printing formats. or take cartridge out and put back in to insure in securely.
lastly, go to web site of printer model and check site for trouble shooting if this does not work above.
hope this helps and good luck
Apr 29, 2010 | Lexmark X4650 InkJet Printer
Printer leaves a grey haze on the page.
If your fuser is not failing then someone probably didn't install the toner properly. Regardless, it is incredibly hard to clean toner out from all the guts and the gray won't go away as long as it is there. I would take it outside, wear a smock, and blow it out with an air compressor or half a dozen cans of compressed air. Wipe down and clean every part you can.
Replace the toner cartridge. Then run a couple dozen copies of something to pick up the remaining toner from the internal mechanisms. See if their is any more toner. If there isn't...then somebody messed up and you just need to work the last of the toner out of the innards.If there is more toner after you clean it out and replace the toner cartridge, start thinking about replacing the fuser.
Oct 02, 2009 | Dell 3000cn Laser Printer
Printer does not print color
Check preferences under printer properties and make sure print grey scale is not selected
Sep 08, 2009 | Dell A940 All-In-One InkJet Printer
HP 2600n grey background
Most Original cartridges are starter cartridges that hold only 1/3-3/4 ink. Drum maybe defective, and this usually causes the grey or black in your printing. Cartridges may need replacement along with the drum. Hopefully this helps
Aug 13, 2009 | HP Color LaserJet 2600n Printer
Toner light stays on despite replacing toner
Is this a remanufactured cartridge? if so the remanufacturedr may have neglected to install, or improperly installed the Reset lever? The initial cartridges that came in the printer didn't have them. On the left side of the new cartridge (if you're holding it as if you were going to install) you should see e white lever seated in sort of a half moon slot. this lever should be toward the front of the catridge when it is new and it gets pushed back as the new cartridge is engaged, to let the printer know it is new, and reset the counter. If this is not the case you should get a replacment
Feb 18, 2009 | Brother HL-2040 Laser Printer
Half the page is dark grey
Low toner.
Consider how often you print.
If you print more than twice a day, toner will tend to run low after half a year, so I would buy a replacement cartridge and see if this solves your issue.
They aren't terribly expensive, so it is worth a shot.
Sep 09, 2008 | Samsung CLP 300 Laser Printer
HP LaserJet 4 plus Printer
First try changing out the toner cartridges since it is the cheapest option. If this doesn't work check the fuser unit by opening the back door and see if there is a line worn down the miidle. One other option may be the transfer roller that sits under the toner cartridge. It may be worn.
May 22, 2008 | HP LaserJet 4 plus Printer
BLACK AND WHITE SCREEN AFTER AN HOUR
This is usually caused by the tuner which loses the chrominance part of the NTSC signal. Your did not say how you have it connected but it you try using a composite video input (yellow jack) and get the color OK than it must be the tuner which is not cheap but is worth having replaced.
Hope Ya Fix it!
Dec 28, 2007 | RCA 27V530T 27" TV
Delta Cartridge Assembly RP46074 Logo
Top Delta Plumbing Experts
Donni Steen
Ed Mac
bwbconstruct
Level 1 Expert
Are you a Delta Plumbing Expert? Answer questions, earn points and help others
