Setting microphone in berhiner BCD300 with tractor 2 on macbook pro
  • Guillermo
    Guillermo Oct 12, 2013
    Hello there, I am sorry if It wasn't explained enough. I want setting a microphone in Berhinger BCD300 with a Macbook Pro also I am using Traktor Pro 2. Somebody know how to do that. I will be eternally thankful .
Have a MacBook Pro and A Shure SM27 but the sound it's too low on Garage Band
hello paola go directly in your mac and open properties of the mic and adjust as you like obs this is making tests with the mic connected
yours antonio
Dec 26, 2013 | Shure SM27 Professional Microphone
I use the samson C01U usb microphone on my macbook pro for almost 4 years. Now I recently updated to mac os 10.6.6 (latest update) and Samson soft pre won't start up anymore. I can't configure the mic...
1. Try reinstalling the softpre software.
2. Read through their FAQ at: http://samsontech.com/products/productFAQs.cfm?prodID=1810&brandID=2
3. Contact samson directly at audio@samsontech.com with your problem.
Mar 03, 2011 | Samson C01U - USB Studio Condenser...
I am having problems recording with my new Samson G-Track Mic on my Macbook Pro. I use Premiere Pro for voice overs (to do the initial recorder) and Soundbooth to clean it up. I've noticed that my voice...
Start here
http://www.samsontech.com/products/productpage.cfm?prodID=1917
scroll down to set up vid, follow the instructions, if it still does not work then call dealer or maker support line.
Hope this helps
Thanks for using FixYa
Aug 18, 2010 | Samson G-TRACK USB RECORDING MICROPHONE...
Got a MacBook Pro...problem recording with external microphone
Hi
... sound issues like you are having do pop up occasionally ... the best thing to do is to reboot the system ... sorry.
Cheers.
Apr 29, 2017 | Apple GarageBand Jam Full Version for Mac...
Cursor and keys are unresponsive tryed 2 check if it was number lock witch its not
There has been a known issue with the first key (any key) of a Macbook Pro, not responding when typed and Apple appears to have addressed this with this software update for the Macbook and Macbook Pro:
Run the Macbook Pro Software Update v1.1 and the Macbook, Macbook Pro Keyboard Firmware update v 1.0 per this link:
Keyboard Issues with Macbook Pro
Let me know if this helps.
Regards,
-Mactechtrainer
Mar 24, 2010 | Apple MacBook Pro Notebook
We purchased a macbook and cannot get it to work properly with gmail chat. we can see and hear who we are talking to but they cannot hear us. Help please
First go the system preferences and then sound and then click on the input and ensure that the built-in microphone is selected and check the volume is set to whatever you need.
In google chat go to options and then down to chat settings. You can then go to microphone under Voice and video chat and under microphone select either default device or built-in microphone. You can then verify your settings.
Hope this helps.
Dec 25, 2009 | Apple MacBook Air
Mic problem
It may not work, but you could always try going into the audio settings and raising your microphones volume, so it comes through louder.
You can find that utility at:
Tools > Options > Audio Settings > Microphone Volume.
It should help, but it may not. I hope this works for you.
Please don't forget to rate my answer :3
Jul 05, 2009 | Apple 13-inch MacBook - Intel 2.0GHz Intel...
Microphone on Apple Macbbok 13" 2.4 GHZ,2GB
Check to see if the microphone works on the macintosh side of the computer, chances are it won't, microphone usage on Macintosh computers has been hit and miss, sometimes the microphone needs a pre-amp or USB interface like a Griffin iMic adapter.
Oct 23, 2008 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Open Questions:
Cervical Cushion- Pillows for Neck Pain Are you a very sedentary person? Do you have a classic office job and are 8 hours or more sitting in front of a computer? Then you most likely suffer from cervical pain. Cervical pain means having severe pain in the neck area because of an incorrect position of our cervix for quite some time. The cervical block or its numbness is due to the unnatural compression of the vertebrae. In this guide you will find all information about cervical pain, how to prevent them and how to cure them, but above all you will learn how to choose your cervical cushion that will help you lessen the pain or make it disappear completely. In the following table you will find some models of cervical pillows that can be found on the market, along with some of the major features that distinguish them. How to Choose a Cervical Cushion Since on the market you can find a great multitude of cervical pillow models, choose the most suitable one and certainly not a small business. First of all, choosing the most appropriate one is to understand what pathology you are suffering from. Although we often call it neck pain, cervical is not always the same in all cases. In this regard, it is understood that not everyone can use the same cushion. There are cases where the patient needs a more flexible pillow, others where there is a need for stiffer material, so before buying your new cervical cushion it would be interesting to consult your trusted physician, who can visit you and decide for you what is best suited to your pathology. Another factor could concern the price, but being in the medical field I recommend closing an eye on this item, ten euros more or less are nothing when it comes to health. Moreover, the price is directly proportional to the quality of the material used and of course there are materials that cost more than others. So as you see there are several factors to consider. Take care of all the advice you'll find on these pages and you too will be able to make the right choice. What is cervical pain and remedies? The area of ??the cervical vertebrae is that portion of our body that accuses so-called cervical pain when our neck or our head is in an incorrect position for several hours. This area is very important for our health and our well-being. In practice it connects our body and especially the spine to the head, with all the nerve endings that pass right in this particular area and very sensitive. When this area is subjected to a continuous stress, we do not only pain neck pain, but we also compromise the proper functioning of the head movement. Very often the pain becomes so strong that besides affecting the neck, it moves to the upper shoulders and joints, causing the famous head turns and also nausea. In the most severe cases a capatina is recommended by your doctor. Among the various factors that can trigger these severe pains are incorrect posture or an improper pillow. At the origin of this evil, however, there are also muscle contractions, trauma and stress. For this reason, the cervical pillow was born, which relieves the pain and allows the neck to be in the correct position. Structure, shape and material are designed to fit perfectly to the shape of the neck, sustaining it and giving it relief.
Oct 23, 2017 | Major Computers & Internet
Computers & Internet Logo
48 people viewed this question
David Payne
David Payne
