Question about Magic Chef MCD1311ST Microwave Oven
Microwave would not turn on
I have a magic chef microwave, model MCD1311ST and I do not get anything on the keypad when I plug it in. I tested the fuse and it is good. I found the light bulb to be burnt. I wanted to know if the light bulb would cause it not to work or do I have to buy another keypad. I have also tested to see that I have voltage all the way up to the transformer. Please let me know if you have a solution.
  • 1 more comment
  • Anonymous Feb 07, 2008
    Microwave oven is inoperable. Just quit during use. No lights, no clock/timer, inside light, etc. No smell evident. Power outlet is working. Moved to new location; no change. Does this model have a fuse? If so, where is it?
  • Lolalexander
    Lolalexander Feb 20, 2008
    I also own a Magic Chef MCD1311ST that stopped working while I was defrosting some meat. Nothing will turn on. It is only 3 months old. We tried to find a fuse, but of course there is no way to get into the microwave box to fix anything. I guess it must be a common problem with this model.
  • hollypowell Sep 16, 2008
    Just stopped working. It wouldnt even turn on for a few months. I tried it again before I trashed it, and it turned on and even half way popped a bag of popcorn, but then stopped again! Does anyone know the problem?
I too have the same problem. Nothing is working on the microwave. I have had it for four years but thought that wasn't really a long time in microwave years. I am currently looking to purchase a new one. Any thoughts on a new stainless steel model?
Posted on Aug 27, 2008
  • 473 Answers
Sounds like the control board is bad.
Posted on Oct 06, 2007
SOURCE:
Chef Banquet - turns off after 7 minutes? Why
It appears the problem is in the keypad controller board, it will only run for 7 minutes and give a loud beep, you need a professional for this, to assess the situation.
Mar 27, 2012 | Magic Chef MCD1311ST Microwave Oven
My magic chef microwave, model # iMCO160S,lost power, not during use. I have checked electrical connection and is OK. Do i need to change a Fuse ?
Fuses are a common failure part. If the fuse, you can purchase ceramic types from Electronix: http://www.electronix.com
Sep 03, 2011 | Magic Chef MCD1311ST Microwave Oven
Trying to locate microwave for odd size built in
It or any other counter top microwave can be placed into a "cubby hole" type of installation, as long as there is enough space on all sides of the unit for ventilation, as specified in the owner's manual.
(Yours is here)
Plus, there must be an opening for air flow.
Jan 29, 2010 | Magic Chef MCD1311ST Microwave Oven
No heat on magic chef microwave
Check the door safety interlock switches.
Dec 29, 2009 | Magic Chef MCD1311ST Microwave Oven
Where can I get a light bulb and base for Magic Chef microwave model #MCP13E1ST?
Bulbs can be had locally in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Just take the old one with you.
Dec 06, 2009 | Magic Chef MCD1311ST Microwave Oven
Cana I download an instruction manual for the MCD1311ST?
Go to this link to get your user manual:
http://www.devicemanuals.com/guide/Microwave%20Oven/Magic%20Chef/Magic-Chef-Microwave-Oven-CT-MCD1311ST-Instruction-==TVRJek16UTU=.html
When you get there, scroll down and enter the validation code.
Then on the next page, scroll down and click on Download Now.
If this was helpful, please select YES to the first two RATINGS questions. Good Luck!
Oct 17, 2009 | Magic Chef MCD1311ST Microwave Oven
Magic Chef MCD1311ST, no longer heats. Any suggestions?
Probably a bad magnetron tube. If you dont hear that tell tell buzz when it is running then that is a good indication of a bad mag tube.
Jul 29, 2009 | Magic Chef MCD1311ST Microwave Oven
Over the Range Microwave Oven
my microwave oven have inside a a metal papel i remove becouse sparks when turn on .this pece of paper is necesari
thanks
alexas
Jun 15, 2008 | Magic Chef MCD1311ST Microwave Oven
Turntable not turning
check control circuit, and related spares.
Oct 29, 2007 | Magic Chef MCD1311ST Microwave Oven
Magic Chef MCD1311ST Microwave Oven Logo
407 people viewed this question
Top Magic Chef Microwave Ovens Experts
William Miller
William Miller
gggg
Gerry Harvey
Gerry Harvey
Are you a Magic Chef Microwave Oven Expert? Answer questions, earn points and help others
