Question about Maytag Ovens
My maytag oven stove part no w10243032 wht is locked pls tell me how to unlock it
4 Suggested Answers
  • 254 Answers
SOURCE: oven door locked and i have no idea how to unlock.
its not locked its got cracked internally.so it not getting opened and showing locked.click the link and check out http://www.applianceaid.com/micro2.html
Posted on Mar 09, 2009
ginko
  • 19396 Answers
SOURCE: we have a maytag gas single oven stove. Where do
Hi.
The beeping sound is a warning because the oven is in lock condition. The oven is not faulty, and the code is not 5AB, but SAB.
SAB means that the oven is in Sabbath mode, and the control board will be locked for 72 hours with SAB on display.
If power is disconnected a new 72 hours cycle will start.
Push and hold the Clock button for about 10 seconds, that will reset SAB mode.
If that does not work leave the oven connected and off for 72 hours. If the oven does not unlock after three days, then the electronic control may be stuck in SAB mode because it is faulty, in that case contact the manufacturer at the number listed on the owners manual.
Regards.
Posted on Mar 05, 2010
  • 25 Answers
SOURCE: Our frigidaire stove or the oven is locked and it just keeps making this beep noise and the oven wont unlock so we really need help unlocking the oven and stoping the been noise thanks
The "F1" error code indicates a failure of the Electronic Oven Control or EOC circuit board. You may find the oven gets too hot, fails to respond to input or acts irregularly when the EOC is malfunctioning or broken. While this code usually indicates a need for repairs.
Read more: How to Troubleshoot a Frigidaire Oven F1 Code ' eHow.com http://www.ehow.com/how_10004808_troubleshoot-frigidaire-oven-f1-code.html#ixzz2EhW21T4n
Posted on Dec 11, 2012
We have a maytag electric range/oven model #MER5770AAW .after baking some french fries ,with the oven open it made a beep and F9 message came up on the panel.everything still functions ,have hit the...
F9 Door Lock Warning Check door lock circuit or Replace Clock. If clock working don't do that.
ck here for the code.
https://www.repairclinic.com/RepairHelp/FaultCodes/31/Range-Stove-Oven
parts here....
https://www.repairclinic.com/RepairHelp/How-To-Fix-A-Range-Stove-Oven/19-4-93082-/new/Maytag-Oven-not-self-cleaning-MER5770AAW
you can call their 800# or use the chat for more info if needed.
first check that the latch is not a 1/4 or so closed.
open and close the latch a few times.
also you can turn off the breaker for a few minutes
and see if it resets the ecm.
Hope this helps a little
Jan 16, 2018 | Maytag MEW5530D Electric Single Oven
We have a maytag gas single oven stove. Where do
Hi.
Regards.
Mar 04, 2010 | Ovens
MY OVEN IS LOCKED
unplug the oven wait 5 minutes and plug back in usually that resets the controll panel then it will unlock
Jan 21, 2010 | Maytag MEW5527B Electric Single Oven
How do i unlock my stove, it is a ceran hotpoint stove. while cleaning it locked and started beeping a flashing F3 . what can i do.
f3 fault code / open oven temperature sensor .) this sensor tell the E O C ( clock ) oven tempts . it will have to be replaced .. ther could be other problems with oven but first things first replace sensor and see how it works .. **** . hop this will help .
Dec 04, 2009 | Ovens
F1 is displayed on Maytag Electric Oven I ran the self-clean cycle on my Maytag Model MER5530 oven yesterday; before it completed F3 was displayed and beeps sounded. I pressed CANCEL, the F3...
Hi
F1 error means that you have either a bad ERC (clock) or a bad touch pad. To check these please follow these simple instructions:
  1. Disconnect power to stove
  2. Gain access to the back of the clock (electronic range control or ERC).
  3. Unplug the touch pad ribbon connector from the ERC. This will be a flat wire approx. 1 1/2" to 2" wide.
  4. Make sure everything is clear and will not short out when power is turned back on.
  5. Turn power back on to stove.
  6. Watch for the F1 and listen for the beep.
  7. If you get the F1 and beep, replace the ERC.
  8. If after approx. 30 minutes you do NOT get the F1 and hear the beep, replace the touch pad...
thank u
rate me!!!
Aug 14, 2009 | Maytag Ovens
How do you unlock a whirlpool stove if it locks manual
I think you mean if it locks automatically not "manual". There should be small print next to one of the buttons that includes the word "lock". Hold this button down until the indicator goes out.
Aug 08, 2009 | Whirlpool RBS245PDS Electric Single Oven
My step daughter has pushed some buttons on the oven, and now it is locked.....it is a self cleaning Kenmore convection oven......how do I unlock it?
DON'T KNOW YOUR STOVE BE HERE IS AN SIMPLE FIX THAT MIGHT WORK ADVANCE THE TIME ON THE CLOCK 8 HOURS AND SET SEE IF HELPS IF NOT TELL ME MORE
Dec 20, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Jenn-Air stove locked
After the lock indicator light goes out, move the door lock lever to the left. The oven door can now be opened. Turn the selector and temperature knobs from clean to off AFTER THE DOOR IS UNLOCKED. If the temperature knob is turned to off BEFORE the door is unlocked, the door will not open. Forcing the lock will damage the lock mechanism. If this should happen, return the temperature knob back to CLEAN, unlock the door, THEN turn the temperature knob off. Source(s): Jenn-Air Grill Range with Self Cleaning Radiant Bake and Convection Oven models S136, S156, S161
Dec 10, 2008 | Ovens
F9 error
hi there,
can you tell me the model # on your stove please?
Sep 14, 2008 | Maytag CWG3100A Gas Single Oven
Oven is locked
press Clean again and add time the quickly open the oven . Before it lockes in clean mode it unlocks soo yea hope this helps.
Feb 22, 2008 | Maytag CWG3600A Gas Single Oven
Ovens Logo
15 people viewed this question
Top Maytag Ovens Experts
Oloyede Monsuru
Mack Baxter
Craig Butler
Craig Butler
Are you a Maytag Oven Expert? Answer questions, earn points and help others
