Question about Smeg WM16AAA Front Load Washer
Apell apwd126 need to change interlock but no screws on outside
My hoover dynamic wash 7+ door indicator flashes in spite of door being closed properly and machine wont start
the door interlock has failed and needs too be replaced
you can find this easily changed out part on ebay or from spares suppliers
you usually need to take the top off the machine
power off and open the door and remove the two screws at the lock
reach down and take out the interlock mecha
plug in a new one and put it back and screw it back on
very easy...
Feb 08, 2015 | Hoover Washing Machines
I get err01 which I think is related to the door interlock ,is this a matter of replacing the door interlock or something else
the code is for a door lock issue,it means the door isn't closing properly,most likely it will be the door switch,unplug the washer,remove the spring from around the outside of rubber boot,pull the boot off just on the side of the door switch enough just to change out the switch,put it back together.next time send the model number,i could have given you the part number,good luck
Dec 15, 2014 | Bosch Washing Machines
Hoover optima wont lock has new interlock
take clip of door seal to access the doorlock then it should be easy to change when you take the screws out of the lock from the front of the machine
Feb 05, 2014 | Washing Machines
How can i remove a screw with an interlock???? I need to replace the lamp in my hitachi rear projector t.v.
unplug the tv .then remove screw-> lamp door -> lamp..Interlock is going to be a swicth engaged by the lamp door that is supose to disable the parts that might give you owies when replacing the lamp. (incase you don't uplugg the tv first). ALSO you must to put the lamp door back on after replacing the lamp.(or else Mr. interlock switch won't let the tv turn on )
Oct 03, 2009 | Televison & Video
TRICITY BENDIX AUTOWASHER CAW 1000 will not operate
if not starting at all, fault is probably the door interlock - easy to replace.
disconnect from mains.
prise off the plastic clamp holding door seal to cabinet and peel back the seal in the area of the door interlock.
interlock is held by 2 screws from the outside and remove these so interlock comes away. remove electrical plug and socket connection and remove the small diameter hose at the bottom of the interlock. interlock can now be removed completely.
refitting is just the reverse.
Nov 10, 2008 | Washing Machines
Zanussi nexus washing machine
almost certainly the door interlock faulty. fairly cheap part and easy to replace.
remove plastic clamp holding door boot to cabinet and peel back in the area of the door interlock. door lock is held in by 2 screws from outside which undo and withdraw lock. disconect electrical plug and small diameter tube at bottom. fitting new one is just the reverse
Oct 18, 2008 | Zanussi FJS1225W Front Load Washer
Hotpoint Aquarius WF320
interlock is device which prevents door opening when machine is operating. why do you want to change it?
to access interlock. remove door gasket from cabinet in area of door handle and interlock is held by 2 screws from outside
Aug 08, 2008 | Hotpoint Aquarius WF000 Front Load Washer
My zanussi Aquacycle 1100 wont start. A clicking noise starts after I try and start a wash. I heard it could be a door interlock that requires replacing. Is this easy to replace?
door interlock is easy to replace.
undo the plastic clamp that holds door gasket to cabinet. peel back in area of door lock. door lock is held by 2 screws on outside. undo these ans lock comes off. there may also be a small diameter hose as well to door lock which take off as well.
reassembly is just the reverse
Jun 30, 2008 | Washing Machines
Door Interlock switch Maytag MDB4100 dishwasher
If the door is not latching well enough try adjusting the spring on the tub it's the male part that goes into the door latch. If that doesn't help you need to replace the latch. It's inside the door. The switch is mounted to the latch in the door so to get to it you have to remove all the screws around the outside edge of the inner door panel. Unhook power before replaceing latch or switch!
Apr 23, 2008 | Dishwashers
Hotpoint Door Interlock Switch
If it's anything like the WM65 then I did it myself this evening. Be aware that I'm no professional. POWER SAFE? Three screws on the back of the top cover. Top off Remove the soap/fabric softener tray. Four screws off around the gap that's left. Three knobs to pull off (it helps if you remember which way they are set when you do this!) Take the rectangular control panel off, which should now be loose - it has interlocks on the right hand side, so be careful not to break them. You may need to tie or tape the panel safely out of your way to te top of the machine. Three screws off the top off the door section. Open the door unscrew the two short screws holding the lock plate. The interlock switch will fall off the back of the door, held on by it's power supply. Stick your hand round the back and pull it clear. Swap the mechanism (mine cost £14) Reverse procedure. Good luck. This wasn't the fault on my machine in the end. boo hoo!
Jan 02, 2007 | Hotpoint Aquarius WD63 Front Load...
Open Questions:
See all Smeg WM16AAA Front Load Washer Questions
Smeg WM16AAA Front Load Washer Logo
54 people viewed this question
Top Smeg Washing Machines Experts
matt
matt
ray gallant
Owen Barnes
Are you a Smeg Washing Machine Expert? Answer questions, earn points and help others
