Question about HP ProBook Computers & Internet
Turns off suddenly
Sometimes when I lifte the computer it just turns off, like somebody have taken out the battery. This problem has occurred more and more the last week. If i try to lift it gently, it some times stays turned on.. What can the problem be?
    New Friend:
    Problem Solver:
  • 16 Answers
It is probably because you have it set to shut off when the laptop is closed. You should try to change it in the System settings
Posted on Oct 11, 2013
  • John Kasper Svergja
    John Kasper Svergja Oct 11, 2013
    Hi, and thanks for answer, but that is not the problem. I have gone through the power and system settings, and everything is how it should be.
    To clarify the problem: When I lift it up ( to move it) it just black out (it doesn't shut down, just blackout like the battery has been taken out). I have spent some time on google trying to figure out what could be wrong, but I have not found an solution yet.
  • 7 Answers
SOURCE: Computer turns off by itself
I have a toshiba laptop which was unexpectedly switching off. The laptop was 2 years old. I did lots of searching online to discover this is a VERY COMMON ISSUE. The problem is, dust blocks the heatsink. When I took my computer to pieces, I found a strip of dust half an inch (1cm) thick covering the back of the heatsink which prevented air flow. If your laptop is a couple of years old, this could be the problem. When I removed this dust, the problem disappeared. If you are computer savvy, then try the following - if not, take it down to a computer shop! 1) Remove the 5 screws holding down the heat sink cover and processor cover. These are on the bottom of the laptop, in the centre, at the back. 2) Remove the 3 screws which hold in the heat sink in place. 3) Remove the heatsink 4) Take the dust out 5) Re-assemble a note: be careful not to get dust in the thermal paste on the cpu - unless you have replacement paste. Good Luck!
Posted on Aug 02, 2007
voodoomox
  • 1689 Answers
SOURCE: HP Pavillion DV5000
Hmartinez, there is a strong possibility that the power management on your computer has failed or is failing. if you have not replaced the battery ever since, i suggest you have the battery checked, or replaced.
you may also try to isolate the problem by plugging the charger to the machine without the battery to check if you will have the same issue, if yes, then there is a possibility that the machine is overheating.
if you have other questions just lemme know./
Posted on Sep 19, 2008
I had the same problem. I installed a CPU temperature monitor and realised my CPU was overheating and that is why it kept on switching off. I opened up my ACER 5720Z and cleaned the vents which were (very) clogged up, even though my laptop is only 6 months old
Posted on Mar 09, 2009
parrotheadpc
  • 2600 Answers
SOURCE: Laptop Won't Turn On (Toshiba Satellite U205-S5057)
Try a new power adapter before you try the other expensive tests and repairs. The adapters are notorium about failing after being used continuously . If you can check the outgoing voltage at the tip where it fits into the DC jack on the laptop would be good. Match the output to the rated voltage needed to peoperly power the laptop.
Posted on Sep 07, 2009
  • 20 Answers
SOURCE: HP Pavilion dv2125nr, seems like the system is
Here are some great source where will will get any kinds of HP,ACER,DELL and COMPAQ laptop Solution and any kinds of Driver download.
» Hp Laptop's Solution
» Compaq Laptop's Solution
» Acer Laptop's Solution
» Dell Laptop's Solution
» Toshiba Laptop's Solution
» Asus Laptop's Solution
» Hp Driver's Download
» Compaq Driver's Download
» Acer Driver's Download
» Dell Driver's Download
» Toshiba Driver's Download
» Asus Driver's Download
jakauiay28
Posted on Jan 03, 2010
I have been using my Acer Aspire 4520 laptop for four years. Recently while working, it turned off abruptly, and when I tried to restart it, it didn't turn on. Upon pressing the power button to start...
Have you come up with a solution yet? Mine does the same exact thing nothing seems to be helping. I'm at a loss here and I feel helpless, and hopeless!!!
Sep 10, 2011 | Acer Aspire 4520 Notebook PC
My Grand Cherokee 1996 suddenly stalls running good and suddenly stops. Sometimes turns on right after. Sometimes it takes a couple of hours. sometimes works fine for a couple of days and suddenly turns...
Richard Scordino Dec 17, 2010
I can't give you a cure for your problem online as testing MUST be done. Computer scanning and individual Component tests are the only way to verify a failure. If a shop is doing the work, I certainly hope they aren't charging you for iteems replaced that did nothing towards making an adequate repair.
Off hand, I'd be looking for a bad connection such as inside the ignition switch or since you mentioned a timing sensor (there is no such thing) either you replaced the crank position sensor or the cam sensor. Whichever was replaced, check the other one.
Wiring failures most often happen at the connector pins or behind the connector plug where moisture gets in and corrodes the internal connection. All of that needs to be tested for continuity and resistance.
Aug 30, 2017 | 1996 Jeep Grand Cherokee
My computer powers on, and works just fine for abo...
This is not a software issue but more of a hardware fault - the battery and charging circuit all rechargeable batteries laptop ones get to become useless after x amount of charges. What is the battery condition? Do you get sufficient charge remaining for atleast 1 hour? Or also it may be overheating due to insufficient ventilation.
=======================MENTOR======================
May 20, 2010 | Toshiba Satellite A205-S4617 Notebook
Turns off suddenly
Hi guest, if your computer turns off suddenly, try these steps:
Turn off your pc, remove the cables on the battery, remove the battery on the pc. Then push the power button for 5 seconds and then reinsert the battery and the cables. Then turn off the pc.
If symptoms persist , please call your technical support of the brand you brought for possible repair.
May 15, 2010 | Toshiba Satellite M55-S331 Notebook
Xbox 360 controller turns off at random, yet has new batteries
The battery indicator found when pressing your xbox logo button is temperamental. It might say 2 bars, or 3 or even full battery but this is not a good indicator of a full battery.
The problem IS low batteries(or more specifically - bad batteries) - when the batteries become low the vibration function can cause the controller to disconnect. This is happens because the vibration function uses extra battery power.
So basically... Every time your controller vibrates, it disconnects. This occurs when firing a weapon in most games, grenades in COD, landing heavy tricks in Skate 2, the list goes on, you'll find many complaints from people stating their controller disconnects specifically with these events.
The simple solution, turn off the vibration function when this occurs. It'll never happen to you again ^_^
Thumbs this up when it proves correct for you. I'd recommend a recharge while you play pack. ALWAYS by the official products too. They're much more reliable and aren't prone to this kind of behaviour.
Jun 26, 2009 | Microsoft Xbox 360 Controller
My Blackberry will not respond to commands from the keys. The keys do not work .. even the trackball does not work. I can not answer the phone and I can not turn it off. This just started suddenly. I have...
try a firmware restore, a guide on how to do that ishere: Blackberry Firmare restore. If that fails it looks like you need to clean the logic board from any waterdamage that might have occured which in theory you can do yourself. Here's a guide on how to disassemble a blackberry. Just clean out any residue you may find from water. Maybe a tech savy friend can do it for you. If you want to have somebody else do it for you there are third party Blackberry Repair Services.
Mar 08, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
Booting problem of my PC.
i think u have not use bootable cd to reformat..
if u use bootable cd such problem will not occur.
once u format means u r system becomes new.. but i donnot know why such problem occurs..
it also depends on type of sevice pack u use
use service pack2 , it is stable.
if the problem is in harddisk .. consult u r customer sevice.
Jul 25, 2008 | Computers & Internet
Computers & Internet Logo
80 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
