Question about Smeg WM16AAA Front Load Washer
Change interlock on apell/smeg washer dryer there are no outside screws
2 Suggested Answers
SOURCE: drying operation on WD16BA on smeg dryer
I think all you have to do (that's how I do it anyway), is turn the program knob so that the line is at the beginning of the drying stage (the little 'sun'), having first of course chosen the desired amount of drying time with the knob on the far left...
Hope this helps, good luck...
Posted on Oct 03, 2008
I have a smeg washer drier wdi 146 with error code e13. Can you tell me what the problem might be. Thanks
i beleve your door interlock is fautly
or the wiring too it can overheat and cook
so youll need a new one from smeg uk
and check out the connector for any issues
see here for some details
although its a different model i would assume the company uses the same error code setup for all its models
and i would order direct from smeg
http://www.ukwhitegoods.co.uk/forumsphpbb3/washing-machine-forum/error-code-e13-smeg-wdi12c6-washer-dryer-t75513.html
Dec 20, 2014 | Washing Machines
How do I change the outside door latch on a smeg integrated washer/dryer
Go to www.repairclinic.com and enter WDI12. With luck, you will be presented with a list of common repair parts and may be able to view a generic Smeg video showing disassembly
Jun 20, 2017 | Smeg WDI12 Front Load Washer / Dryer
Dryer doesn't warm up It's a smeg washer/dryer and doesn't dry the clothes
either the red/ orange wire to the high side limit switch is burnt off !1 of the limit switch itself is fried
Jan 14, 2010 | Smeg WDI12 Front Load Washer / Dryer
Smeg WD1 12C, error code 10
I have a smeg wd1 12c washer dryer showing error code e01 any idea how to fix it?
Gilly
Nov 06, 2008 | Smeg WDI12 Front Load Washer / Dryer
Hotpoint Aquarius WF320
interlock is device which prevents door opening when machine is operating. why do you want to change it?
to access interlock. remove door gasket from cabinet in area of door handle and interlock is held by 2 screws from outside
Aug 08, 2008 | Hotpoint Aquarius WF000 Front Load Washer
How to get access to door interlock mechanism?
WHAT YOU HAVE TODO TO GET THE FRONT OFF IS TAKE OUT THE SOAP DRAWER COMPLETELY THERE IS FOUR PHILLIPS SCEWS TAKE THEM ALL OUT THAN TAKE THE TWO KNOBS OFF THAN LIFT UP THE PANEL SLOWLY WATCH THE WIRES THAN UNSCREW THE THREE SCREWS ACCROSS THE TOP OF THE FRONT PANEL AND THE THREE ALONG THE BOTTOM YOU SHOULD NOT HAVE TO TAKE OFF THE RUBBER TO GAIN TO THE DOOR SWITCH
Apr 20, 2008 | Hotpoint Aquarius WD63 Front Load...
Smeg washer/dryer not filling
Check the pressure switch, aka water level switch. If this isn't the problem, it may be the water valve.
Mar 26, 2008 | Washing Machines
Power Surge and WD16BA
Door not shut Check that the door is properly shut.Faulty interlock A faulty interlock might not allow the door to shut properly. Find your door interlock here and replace, or contact a qualified repairer.
No power Check the flex, plug wiring, fuse and mains supply for faults.
Faulty on/off switch Check the power light if fitted. Replace your on/off switch.
Water supply disconnected or off If a washer dryer cannot load water it cannot start a wash cycle. Check water supply.
Sep 18, 2006 | Smeg WD16BA Front Load Washer / Dryer
Open Questions:
See all Smeg WM16AAA Front Load Washer Questions
Smeg WM16AAA Front Load Washer Logo
16 people viewed this question
Top Smeg Washing Machines Experts
Tom Chichester
Jorge Rendon
Jorge Rendon
Are you a Smeg Washing Machine Expert? Answer questions, earn points and help others
