Question about Kenmore Dryers
Kenmore model 11064972301 won't start - Kenmore Dryers
  • lou bonasso
    lou bonasso Oct 10, 2013
    further info is that when the start button is pushed a low hum is made by the timer element. There is a noticeable click when the start button is pushed but the unit will not start.
  • Kenmore Master
  • 2,180 Answers
First thing open the door and check the door switch,you should see a little paddle,push it in and out if it feels good and clicks it's good,now you want to go to the back of the dryer and where the cord connects to the dryer make sure you have 240 volts coming to the dryer,if you do go to the front .your lint filter is on the inside so you can do this from the front,unplug the dryer or kill the power to it,remove the bottom panel,get a screw driver and slide it in the hole between the bottom and door panel,you'll hit a clip,push the screw driver in on the top of the clip and pull the panel forwards,one on each side,then remove the lint filter and then remove the metal duct the filter slides into,clean this out,the reason why the dryer died is most likely from bad air movement,the dryer runs to hot and one of the thermostats will pop as a safety so you don't have a fire or anything like that,you'll need a meter,pull at least one of the wires off of the part you have to check for continouity,on top of the blower wheel housing you'll see a white piece,that's the thermal fuse,check that first,if that's good go to the heater box and check the t-stats on the left side of the box.you should find one of them bad.also when your done if your vent line is long go outside and make sure nothing is blocking the outside duct like a cage or screen,if it's clear go back inside remove the vent line from the back of dryer and stick a leaf blower into the vent line and blow it out.if you clean out the vent line the front cabinet and lint filter duct once a year you won't have to many problems with your dryer.let me know what you find
Posted on Oct 10, 2013
Kenmore washer model #111092581200 won't stop filling and won't agitate
Please recheck that model number. It is coming up as a microwave.
Oct 31, 2012 | Washing Machines
I have a kenmore 90 series elec dryer. Model # 110.64924200. When I turn it on it won't start, however I can hear it click. Like a car turning over but won't fire. Any suggestions? Already cha
the start relay in the control panel is bad,the relays coil is moving this is the click you hear,but the main contacts in the relay are bad there are 4 wires to it 2 for the start switch and 2 for the main contacts
Oct 24, 2012 | Kenmore Dryers
Kenmore dryer 592-89047 won't start
Sounds like the lint may have fallen into the fan and has jammed it. The motor will hum if that happens. Its an easy job to clean just take your time taking the blower cover off and reverse the process replacing it.
Apr 26, 2012 | Kenmore Dryers
I have a top loading Kenmore series 80 washer. The cycle starts, agitates, but won't drain and go into a spin mode. It just stops after the agitate is done and remain full of water. It won't...
This is usually a door closed switch that is either a bad Lid switch It is number 11 on the diagram on this page http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Washer-Parts/Model-11024032301/0582/0153200/K0403014/00001?blt=06&prst=&shdMod=
Hope this answers all your questions
Please remember to Rate/vote for any solution that helps you out.
Leave a comment if you need more help.
Thanks for using Fixya.
Aug 12, 2011 | Kenmore 24032\24036 Top Load Washer
Dryers Logo
47 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
