Question about Sony DVP-NS575P DVD Player
How to hookup Sony DVP-NS575P player - Sony DVP-NS575P DVD Player
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Sony Master
  • 102,366 Answers
See the instructions beginning on page 17 of this manual: http://www.fixya.com/support/p229787-sony_dvp_ns575p_dvd_player/manual-15814
Posted on Oct 10, 2013
3 Suggested Answers
ginko
  • 19396 Answers
SOURCE: need unlock code.
I found this region hack here Sony DVP-NS575P region code , check it out:
"Warning
The following guide describes how I managed to make my Sony DVP-NS705V DVD player multi-region.
There are no guarantees that you will be able to do the same. Be aware that you will probably void any warranty you have and possibly even break the player.
Put shortly, you proceed at your own risk.
Introduction
First of all, the Sony DVP-NS705V can be made multi-region simply by applying appropriate service codes, you do not need to install a so called "mod chip".
This supposedly applies to the entire NS-series of Sony DVD players. There are some encouraging reports out there supporting this, but nothing has been verified by me. Again, if you choose to apply this guide to any DVD player, you do so at your own risk.
If you do find that this procedure works on another model, please drop me a line at sonyhelp@selen.org and let me know. Include the exact model number and original region of your player.
Update: Some users have reported success on the following players:
DVP-F21 (special thanks to Garry Self for this one)
DVP-LS500
DVP-LS755
DVP-LS785
DVP-NC615
DVP-NS300
DVP-NS305
DVP-NS310
DVP-NS315
DVP-NS330
DVP-NS333
DVP-NS355
DVP-NS360
DVP-NS400
DVP-NS405
DVP-NS410
DVP-NS430
DVP-NS433
DVP-NS575
DVP-NS585
DVP-NS590
DVP-NS700
DVP-NS730
DVP-NS765
DVP-NS900
DVP-NS905
DVP-NS930
DVP-PQ1 (thanks go to Michael Joy for this one)
DVP-PQ2
RDR-GX3 (thanks to Andreas Norman)
RDR-GX7 (thanks to Daniel Tapie)
RDR-GX300
RDR-GX700
RDR-HX900
RDR-HX1000
Please note that not all players behave exactly like the NS705. For example, some players do not display "success" when hacked.
Thanks to all who have contributed.
The infrared service codes required to make the update are available on the Internet. Unfortunately, not many people have an appropriate device to enter the codes into. You basically need a programmable remote (Philips Pronto, One-For-All) or a PDA (Palm, iPAQ) with suitable software.
This guide shows you how to make the update with a regular PC equipped with an IRDA port.
The procedure
1. Download the winsamp -package from Blank Frank's site.
http://www.veg.nildram.co.uk/remote.htm
This innovative piece of software allows you to send standard home electronics IR signals using a PC IRDA port.
2. Extract the package onto a bootable DOS floppy disk.
3. Download this IR code
http://www.selen.org/files/REMOTE.TXT
file and place it in the same directory as the package above.
This file holds the five necessary IR codes converted to the format used by Blank Frank's winsamp.exe. Please do not bother Frank with questions concerning this particular procedure.
4. Boot up your PC from the floppy disk and run winsamp.exe.
If your IRDA port doesn't appear as COM2 you may override this by using an appropriate command line switch. For example, use COM1 by running 'winsamp C1'.
5. Press the 'r' key to load up the codes into winsamp.
6. Make sure your DVD player is in standby mode and your IRDA port is within range.
7. Run the IR codes from 1 to 5 by pressing Enter on each corresponding button.
8. Your DVD player should start up and display the text "SUCCESS".
9. Repeat step 7. Your player should return to standby mode.
10.Your player is now multi-region."
Posted on Feb 10, 2009
SOURCE: I need Sony DVD player
i have no power supply problem then my dvd is also inside the dvd please solve the problem
Posted on Jan 29, 2011
I am not able to play pirated dvd in my sony ns575p dvp
The reputed models will not play these being pirated versions and so it is best to choose originals to be played in your Sony player.
Unfortunately most local models will play these and so must not be taken as fault in the player.
Aug 03, 2011 | Sony DVP-NS575P DVD Player
No power in dvd player sony dvp-ns575p
First check the fuse,then the power supply section.power supply problem.
Nov 08, 2010 | Sony DVP-NS575P DVD Player
I need Sony DVD player DVP-NS575P powersupply circuit diagram!
Aug 03, 2010 | Sony DVP-NS575P DVD Player
Sony DVP NS575P will not play pc burnt DVD
John~ check formats with dvd player can be found in mannual - then burn dvd to suit mp3 or mp4 would normally work~ you can go to Realplayer.com to get tool to download on pc to this job. also try
Divx .com / utorret.com
or if you can get a Silvercrest dvd player this can also play pc dvd.in may different formats.
Phil
Aug 08, 2009 | Sony DVP-NS575P DVD Player
I need to identify and replace the fuse in Sony DVP-NS75P
I think you are asking fuse in Sony DVP-NS575P DVD Player.
Its just next to AC wire connector and not ordinary glass tube type.
Locate it in below image of PCB of power supply board..
Mar 16, 2009 | Sony DVP-NS575P DVD Player
Sony dvd dvp ns575p
watch the cables of YcBcR and install them correctly.
Jul 26, 2008 | Sony DVP-NS575P DVD Player
DVP-NS575P fail for DTS system
I have an Transistor(Radio) of Sony but it does not play the AM signle
May 12, 2008 | Sony DVP-NS575P DVD Player
Can a Sony DVP NS575P play divx format? If so how does one set it up to do so?
I do not think so, it needs the divx software.  Units that can play divx have it listed on the box and in the manual.
Feb 13, 2008 | Sony DVP-NS575P DVD Player
Sony DVP-NS575P DVD Player Logo
53 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
