Question about Danby DPAC12099 Air Conditioner
Diagram wiring is it possible to wire in a variable humidistat for the dehumidifier function of the airconditioner, according to tech support it is set for 60 % humidity, I want to go to a lower humidity setting
    Scholar:
  • 111 Answers
You could replace the Thermostat with one that allows you to to set it lower, or get a different humidistat that goes from 0-90 , There is always ways around, Thus this great website.
If you need more details or where to purchase let me know.
I’m happy to help further over the phone at https://www.6ya.com/expert/michael_341f3f9dee622e54
Posted on Oct 11, 2013
I have an lg dehumidifier LHD 45EL. The humidity reading reads 15% higher than a stand alone humidistat and the unit will go on for a short time even though the set humidity level is 70%. What gives?
Possibly the primary humidity sensor behind right side grill. Unit MUST be unplugged from outlet. Take right side grill out, unplug sensor from wire socket and plug back. If no help, you need new sensor.
Dec 30, 2009 | LG Dehumidifiers
Honeywell humidistat stuck
what i would do is make sure tha the hole for the wires that go to the humidistat is completely closed and that you are sensing the true humidity for the space also have the tech wire the so that the heat comes on instead of the ac for the de-hiumidification process.
Feb 10, 2009 | Honeywell CT87B ROUND HEATING&COOLING...
Wiring issue with the Honeywell HE360A Humidifier
Maybe I can help. this is 24v so it doestn't matter which wire goes where so here goes. 2 wires from humidistat go to furnace, split one of the wires(not both) so they reach the yellow wires on the humidifier. with marettsconnect one of the split wires to one of the yellow wires. do the same to the other split wire and yellow wire. what you should get is one wire from humidistat to furnace then one wire from humidifier to humidistat and one from humidifier to furnace. hope this helps
Jan 31, 2009 | Honeywell HE360A1027 Whole House...
Humidistat installation question
I suppose you are looking at the do-it-yourself model. Depending on the wire that is run up to you Regular Thermostat from your furnace. You may have to run a seperate line for the Humidistat. A digital thermostat that does Humidity and Temperature is recommended. Or you could just place a Humidistat near the furnace room. A wiring diagram will come with the Humidifier discribing the different ways to wire it.
Jan 09, 2009 | Honeywell Power Humidifier: Furnace...
NewAir AirConditioner on "Dehumidifier" Mode Only
I have a 3 ton a/c system that removes about 5-6 gallons of water from the air per day. Most portable dehumidifiers/air-conditioners rate at approx 1/2 to 3/4 of a ton. Your water output is pretty much normal.
Jun 23, 2008 | NewAir Heating & Cooling
Humidistat
the humidistat is inside the machine behind the control panel. it has a mylar piece that expands and contracts according to room humidity. one side is connected to a super sensitive switch that is part of the fan/compressor circuit. you could just jump this out with a piece of wire but you'll have no control over the humidity. the unit will just keep on running.
Sep 06, 2007 | Kenmore 54501 Dehumidifier
Does Not Collect Water
sounds like a faulty humidistat, but may also be nearly out of freon. I have a GE unit that is also a portable air conditioner...works great for 5 years now...
Jul 09, 2007 | LG DH404E Dehumidifier
Danby DPAC12099 Air Conditioner Logo
89 people viewed this question
Top Danby Heating & Cooling Experts
coolfelix
Level 1 Expert
1STHVACMAN
Dennis Boxerman
Are you a Danby Heating and Cooling Expert? Answer questions, earn points and help others
